10-17-2013, 10:16 AM | #46876 | |
Member#: 152726
SCIC
Vehicle:The 2003 pwrFAP thing |
im jsut worried about the 5speed. my friend recently blew up 3rd in his TR wrx just crusing on the highway. his only mods were vf39 and tune I'm currently sitting at 300awhp give or take since the weather temps are coming down and i need to settle in my winter tune.
10-17-2013, 10:32 AM | #46877 | |
Member#: 261612
Vehicle:2002 WRX - 750WHP 9.5s @ 150mph |
Depending on power level the 5 speed gearing can be better for drag, but not always. The 07+ 6MT ratios will do about 140MPH in 4th at 9k, so they can still be good even on a pretty quick car. I do not agree that a built 5 speed is necessarily stronger, in fact I would argue that the 6MT is probably more robust. |
10-17-2013, 11:53 AM | #46878 | |
Member#: 21339
HIIC
Vehicle:2002 LHD STI V7 6MT 12.9@103MPH EJ205 4EAT |
10-17-2013, 02:09 PM | #46879 |
Member#: 40742
Vehicle:2002 WRX WRB |
I have had a build 5 speed and now have a 07 US 6 speed. I can tell you that the 6 speed is far more usable on the street with closer gear ratios, ESPECIALLY on the 2.0! I can shift as hard as I want, and not have to worry about anything, and I am in the the sweet spot a lot more!
When you do a 6 speed swap, you also get a much better front and center diff, not to mention DCDD, which makes the car handle better in every which way. |
10-17-2013, 02:31 PM | #46880 |
Member#: 21339
HIIC
I believe the problem with the 5MT was the casing. It flexes which causes things to move internally which causes broken gears and such. I LOVE my 6MT but it's extremely heavy like my 4EAT was. My next upgrade along with a clutch will be a stage 4 SD clutch setup. may also consider the HD version as well. I wanted to do a lightened flywheel as well but this takes care of both one shot!
10-17-2013, 03:04 PM | #46881 | |
Member#: 95823
Vehicle:2003 Imprezza Wrx WRC BLUE |
Most folks blow gears powershifting and sidestepping the clutch. And you can avoid most of this by just using a lightened flywheel and taking the inertia out of the mix. I shelved my original 5 speed after 260,000 miles because the center diff failed. Auto-x Road Course I would definitely go with the 6 speed... lightened flywheel and a solid clutch surface. Do not do a puck clutch for non drag strip use, its just not necessary. Buddy who was the lead tech over at Andrewetech had the straight cut dog, and he abused the living crap out of it and it was fine... well fine until we welded up his center diff and made him a RWD drift car lol. But if you really want the in's and outs there is only 1 place to ask. Call Andrewtech and talk to Sam. |
10-17-2013, 03:58 PM | #46882 |
Member#: 354303
SCIC
Vehicle:2002 Impreza Wrx PSM |
With a catless downpipe its normal to hear the turbo? Or all the air being forced through? Im thinking i have an exhaust leak
10-17-2013, 04:01 PM | #46883 |
Member#: 289445
10-17-2013, 04:16 PM | #46884 |
Member#: 115459
NESIC
Vehicle:2002 WRX Sedan Atomic Orange |
Wangless...me gusta.
10-17-2013, 04:17 PM | #46885 |
Member#: 115459
NESIC
10-17-2013, 04:19 PM | #46886 |
Member#: 20492
Vehicle:4 -valve Derper Let's JDM styling! |
Truthfully, you could probably make those. Get a small amount of .010" thickness adhesive back carbon sheeting for like $5, and just cut to fit with scissors.
10-17-2013, 04:34 PM | #46887 |
Member#: 97460
NWIC
10-17-2013, 04:42 PM | #46888 |
Member#: 296133
AKIC
Vehicle:2002 Impreza WRX WRB |
10-17-2013, 05:47 PM | #46889 | ||
Member#: 152726
SCIC
all in the works. i think my plan is to put in it as awd, have some fun on track and what not. take advantage of awd. then save up, fit a well built r-180 or buy my buddy's cusco r200 2way lsd rear diff and then do my rwd conversion. |
10-17-2013, 05:56 PM | #46890 |
Member#: 21339
HIIC
Buy the Cusco center diff for RWD too? Less rotational mass and weight
10-17-2013, 06:07 PM | #46891 |
Member#: 21339
HIIC
10-17-2013, 06:13 PM | #46892 |
Member#: 289445
10-17-2013, 07:24 PM | #46893 |
Member#: 167244
TXIC
Vehicle:2k3 WRX MBP Clean & Simple |
almost ready for paint (maybe by saturday)
i told 'em to shave the front side markers too |
10-17-2013, 09:23 PM | #46894 |
Member#: 317304
Vehicle:2002 impreza wrx blue |
My beautiful bugeye |
10-17-2013, 11:39 PM | #46895 |
Member#: 40742
ok. so back to the 06/07 wagon side skirts. This works and fits correctly?
That looks PERFECT. By far the best I have seen in that pic. Do you have more?? Just to confirm, those are off the WRX WAGON 06/07) I think STi sideskirts really make the car look nicer, but this is just as good! Last edited by JASWRX; 10-18-2013 at 01:03 AM. |
10-18-2013, 01:33 AM | #46896 |
Member#: 296133
AKIC
The skirts aren't a direct swap to the bugeyes, they require some modification.
There is a little dog leg that extends upwards behind the front wheels that has to be trimmed. Never done it, but I've seriously considered it! Lol It's a good look, not as aggressive as the sti skirts. |
10-18-2013, 01:39 AM | #46897 |
Member#: 356276
Vehicle:2002 WRX Wagon PSM |
10-18-2013, 01:45 AM | #46898 | |
Member#: 40742
It is a good look, but I don't want to fuss with mocking it up. I think I might just pickup STI sideskirts, and apparently they come painted? |
10-18-2013, 02:06 AM | #46899 | |
Member#: 296133
AKIC
Another option are spats and strakes, if your just looking for some flare. |
10-18-2013, 02:50 AM | #46900 |
Member#: 354303
SCIC
Does a 3 way bcs require a protune? Or a map through the ap
the Bugeye thread | 5spdfrk | Member's Car Gallery | 18633 | 05-20-2010 12:18 PM |
Where's the bugeye lip thread?! | yankdanger | Interior & Exterior Modification | 0 | 04-06-2009 09:43 PM |
