#1 |
Member#: 456
NWIC
Vehicle:2008 Forester XT Steel Gray Metallic |
![]() Make: Matsu****a (Panasonic?)
Model: 86201FC080 (Subaru part number, actually) Reference Number: CQ-EF7910A So what is the connector on the left? (one on the right connects to the car) Glenn |
#2 |
Member#: 12374
Vehicle:2002 Impreza WRX ASPEN WHITE |
![]() im thinking that its for the sub/amp for under the seat every thing is pre wired just needs to be hooked in
#3 |
Member#: 456
NWIC
![]() Seems like a lot of pins for that.
Speaking of which, any of THIS stuff look familiar? http://www.maco.panasonic.co.jp/maco...p08e/car3.html |
#4 |
Member#: 351
Vehicle:97 Legacy GT White |
![]() could be output for amp, input for changer, or steering wheel controls. depends on what other cars use that radio. could be for inputs for a nav unit. it looks like the plugs for ford factory changers to be honest.
Kevin www.subee-sound.com |
#5 |
Member#: 456
NWIC
![]() Go to http://www.pasc.panasonic.com/epartr/
and enter CQEF7910A - you get a parts list! No manuals listed though. Glenn |
#6 | |
Member#: 6070
South East
Vehicle:2015 STi Dark Gray Metallic |
![]() Quote:
I would like to modify this for a direct ipod plug in. It should be simple to connect the ACC to a small cheap transformer to reduce the voltage to 5V for charging the ipod. The only thing that has me confused is how to fake the CD changer to think it has a CD changer installed. Ground the Bus input? If it is that simple then a small switch would work. I would like to order a raw input harness and do some experimenting, so we can hook in our MP3 players. It would be nice to have a switch to change from MP3 to CD. Anyone have any thoughts? Thanks Chuck D. |
#7 |
Member#: 456
NWIC
![]() bump
#8 |
Member#: 8804
South East
Vehicle:2008 Impreza STi Dark Gray Metallic |
![]() Don't know what it is but it's more likely that it's the sub woofer plug. It's not pre-wired though.
I just ripped apart my WRX today (seats, carpet, gauge cluster, console, and dash) and didn't see any pre-wiring for the stock sub. There was also another harness connector that was bundled with the stereo harness but not plugged in. Didn't even think to see if that would have fit in the receptacle. |
#9 |
Member#: 9837
RMIC
Vehicle:2015 Forester XT Blue |
![]() It's not for the sub. The sub for the MY02 WRX comes with a harness that fits between the right connector and the car's stock harness.
#10 |
Member#: 456
NWIC
![]() And to be clear, there is nothing existing in the car that plugs into this connector.
Glenn |
#11 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
![]() How about for the Satellite Navigation System/TV System as found overseas? I know from speaking with a gentleman with a grey market STi import in England that the Nav System connected to the radio on his STi 6. Granted, Japan uses a different set of radio frequencies than we do, but it's probably the same head unit with a different crystal for their frequencies. Just a guess
![]() Brian http://www.northursalia.com http://www.imprezamods.com http://www.scoobymods.com |
#12 |
Member#: 9611
![]() when you hook up the sub, you use the plug with more pins, the other one remains unused
#13 |
Member#: 9793
Vehicle:2002 2010 legacy gt red |
![]() speaking of plugs anyone have the plug for the subwoofer lying around unused.. I bought a subwoofer from someone but the connector was for an aftermarket head unit.. thus cannot use it easily in my wrx.
or save that anyone know the part number for the connector that comes with the subwoofer kit.. either from subaru or panasonic. thanks |
#14 |
Member#: 456
NWIC
![]() The service manual for the stock head unit from Panasonic is $6 ish + tax + shipping.
I ordered one. Glenn |
#15 |
Member#: 9793
![]() can you post the part number and where you got it from ..
thanks |
#16 |
Member#: 8857
Vehicle:2002 WRX Silver |
![]() While what I am offering has already been posted, I found some useful info at the subarparts.com site. As mentioned by previous replys, the sub hookup plugs in between the existing wiring connector and the 14-pin receptacle on the right hand side of the radio (orientation via Glenn's picture). This info can be found in the installation instructions for the subwoofer which are posted on the subaruparts.com site....There are install instructions for all sorts of stuff. Just find the part that you want to purchase and there should be a link to a .pdf for the install instructions.
#17 |
Member#: 9793
![]() as I said before IU have the subwoofer kit and the instructions but apparently the guy I bought it from they hacked it and didin't have the factory cable and cut the wire instead..
ie mine has a connector into the subwoofer that goes to 4 wires cut - fuse and power, ground and right and left channel. I do not want to install it in this hacked manner and cannot find a part number fora the correct connector that is supposed to come with it as per the install instructions. |
#18 |
Member#: 456
NWIC
![]() I ordered the manual from Panasonic. No part number, just called 800-833-9626 and asked for the manual for CGEF7910A.
They only had one. Dunno what the wait will be now. Boy, I'm really hogging the WRX documentation; first the shop manual supplement, now this. ![]() For the guy missing the sub cable, call Subaruparts and see if they have the p/n for the cable by itself. It isn't in the instructions. Glenn Last edited by ANZAC_1915; 12-04-2001 at 10:57 PM. |
#19 |
Member#: 456
NWIC
![]() The answer from the Panasonic service manual which arrived today:
This 16pin connector is for an external CD changer!!!!!!!!! I guess 6 CDs isn't enough! It has L+R inputs, mute, bus signals etc. You use the "CD" button to roll between the internal changer and external. I assume it must detect it first on the bus. I assume it must be a Matsu****a/Panasonic changer. Pity. You could use these external inputs for something. Glenn |
#20 |
Member#: 9412
Vehicle:2002 WRX Wagon Silver |
![]() I wonder if you'll use a 10 disk changer, how would you select disks # 7-10?
#21 |
Member#: 456
NWIC
![]() I was wondering that myself. Suspect it only really supports +6, based on the display and keys. No mention in service manual.
Glenn |
#22 |
Member#: 717
NESIC
![]() With the Pioneer 12 disc changer, buttons 1-6 select those CD's. Push and hold button one selects CD 7, etc....
#23 |
Member#: 456
NWIC
![]() Looking at the display, there may be other (>=7) LCD elements there.
#24 |
Member#: 13143
![]() Can you share any relevant specs from the manual you ordered for the factory radio such as watts RMS?
Thanks |
#25 |
Member#: 12654
Vehicle:02 WRX Sdn, 2.5L Element Tuning GT65r/hdrs |
![]() How about a function table of the connectors ... or at least which pin is "mute"? My Nokia hands free cell phone cradle can use it to automatically mute the radio when a call is received.
Also, what are the specs. for the mute line? Mute when grounded I'd guess. |
What is this connector? | WRexxer | Electrical & Lighting | 1 | 06-20-2006 09:23 AM |
What is this connector for? | subysouth | Transmission (AT/MT) & Driveline | 6 | 09-27-2004 01:35 PM |
What is this connector? (photo) | 66666 | Electrical & Lighting | 0 | 08-12-2004 09:15 PM |
What is this connector, and why is it unplugged?? | Kwyjibo | Electrical & Lighting | 7 | 09-24-2003 01:21 AM |
What is this connector called ? | brunetmj | Car Audio, Video & Security | 3 | 06-14-2002 12:12 PM |
