Welcome to the North American Subaru Impreza Owners Club Saturday June 3, 2023
Old 03-13-2007, 03:18 AM   #1
TENAZ
Member#: 89049
04 STI 400 WHP
ORCA
Subaru Stars Check engine and cruise control light on
I just got 06 Wagon WRX It happens twice so far no even driving close to 3,000 RPM ; It looks the power got lost for a second and both ligths got on the check engine and the cruise control light .
Any suggestions to fix it will be appreciatte it .
Thanks
Tenaz
TENAZ is offline   Reply With Quote
Old 03-13-2007, 03:26 AM   #2
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
if you dont have a tactrix cable, maybe you can go to a local meet and have someone with the cable check it out.
druxboyz is offline   Reply With Quote
Old 03-13-2007, 08:24 AM   #3
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Could be the CEL for overboost. You will need to reset the ECU or use an OBDII scan tool to reset. The code on an STI is P0244 for overboost.
I'm not sure without looking what the boost limit for CEL is on a stock? 06 WRX.
Any mods?
blkscooby is offline   Reply With Quote
Old 03-13-2007, 10:33 AM   #4
TENAZ
Member#: 89049
04 STI 400 WHP
ORCA
It is stock The only thing I put is Short Ram with Blow valve.
When I disconnect the battery it reset itself ,But I never know when is coming back again .
Thanks,
Tenaz
Old 03-13-2007, 10:39 AM   #5
gte123v
Member#: 114481
2006 Sti
^^^um, there's your problem right there...short ram and blow off valve. Either one of those is bad for the car, take them off and reset your ecu.
gte123v is offline   Reply With Quote
Old 03-13-2007, 11:05 AM   #6
TENAZ
Member#: 89049
04 STI 400 WHP
ORCA
I going to try to remove the Blow valve first see what happens.
Thanks for the Advise I'll keep post it .
Tenaz
Old 03-13-2007, 01:16 PM   #7
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
if the bov was full recirculation and 0***37; vent to atmosphere, would it be pretty much the same as stock ?
06 sti check engine and cruise drive lights on. Black hawk 06 Newbies & FAQs 11 01-09-2009 11:15 AM
check engine and cruise control flashing AWD0425 Electrical & Lighting 2 03-04-2008 07:09 AM
check engine and cruise control AWD0425 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-04-2008 04:08 AM
Check engine and cruise control light?? autvincereautmori Service & Maintenance 14 05-09-2007 09:23 PM
Any body ever have check engine, and cruise control blink? stealthblksti Subaru Conversions 1 08-19-2005 11:15 AM
