#1 |
Member#: 101730
South East
Vehicle:02 WRX Stage III+ PPG Reppin! |
![]() Alright
I know my lightweight flywheel throws an engine misfire code, because it changes the timing slightly or something. I was told that having a LW flywheel and LW crank pulley is just too much. I already have a Fidanza 9.5# flywheel and want to add either an UR pulley or a Perrin (had one and sold it because of previous information) I just want a little more pickup and to be able to rev match a little easier. Anyone heard anything like this?
#2 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
![]() forget the pulley
#3 |
Member#: 101730
South East
#4 |
Member#: 16200
![]() ...then stop making SO MANY useless threads
#5 |
Member#: 125884
VIC
Vehicle:06 Evo IX MR Black 76 Datsun ZZZZZZZ |
![]() Don't do the flywheel either. CEL codes, higher rpms need to start smoothly...not worth it.
Buy the biggest BOV ever though. |
#6 |
Member#: 101730
South East
#7 |
Member#: 101730
South East
#8 |
Member#: 120152
![]() LW FW plus a LW pulley seems to cause some spun bearing issues. don't do it.
#9 |
Member#: 112928
Vehicle:2004 WRX Sedan WR Blue |
![]() You may want to re-think that response and understand who Uncle Scotty is before you ramble out something like that...no useless info comes from him, PERIOD.
As stated though, you have no need to install either of those items on your car. |
#10 | ||
Member#: 101730
South East
![]() Quote:
#11 |
Member#: 56321
NESIC
Vehicle:2006 Honda El Camino Green |
![]() I have the fidanza flywheel on my ej207. I had a Worx pulley on my ej205 and decided that it would be better to now use it with the new flywheel. I don't like the idea of turning a motor to 8k+ rpm and not having some sort of dampening on there.
If you have the flywheel already, I'd skip the pulley. |
#12 |
Member#: 12454
Vehicle:10 Toyota Taco K8 SV650SF |
![]() I had GFB pullies and a JUN flywheel together at one point on a stock ej205. It was AWESOME, really made the motor rev happy, easy rev matching, quick shifting! However after having the motor rebuilt i started throwing crank sensor codes, positon codes etc.
Put big heavy crank pulley back on and it went away. So you canr always get away with it. By far the biggest difference is the flywheel so if you have to choose one go with the flywheel IMO. Also your flywheel is very very light at 9.5lbs., you sure that thing can soak up enough heat? probably not the best for drag racing.. ive put hot spots in larger flywheels which means its trashed and you cant use it again, turns into a $400 paper weight as for the comment about spun bearing.. who spun their bearings and contributed it to using a certain flywheel or pulley? I must have missed that thread? goodluck |
#13 | |
Member#: 136675
![]() Quote:
Isn't replacing the stock harmonic damper (pulley) bad? Subarus do not come with a harmonic damper or balancer like some other vehicles do. For other manufacturers' vehicles, this is a legitimate concern. Proof: "Thank you for your patience as I checked with our Technical Services Department regarding your message below. They advised that the crank pulley is a pulley and nothing else. It is not used as a harmonic damper/balancer. Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us again." Best wishes, John J. Mergen Customer Service Department Subaru of America, Inc |
#14 | |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
![]() Quote:
That rubber layer in the stock pulley isn't there just for looks (see: torsional vibration). |
#15 |
Member#: 136675
![]() i was reading your other post in the built motor side and i feel that this is
like the evo sti battle.... theres never an end.... everyone has there views but next time give me something more reliable than Wikipedia. |
#16 |
Member#: 70395
![]() Seriously,just stop.Nothing wrong with a lightweight flywheel or crank pulley.Used together, especially with such a light flywheel,can be overkill and cause alot of phantom misfires.Most people run around a 13-14lb flywheel.Lightned flywheel can be a great upgrade when the OEM clutch and flywheel need to be replaced.Makes the car very zippy and rev happy.
#17 |
Member#: 27108
![]() Torsional vibration isn't something that is "made up". It absolutely exists.
![]() http://www.indiacar.com/infobank/tor..._vibration.htm http://www.prosig.com/signal-process...Vibration.html |
#18 |
Member#: 101898
SCIC
Vehicle:1905 NINETWO EX AIRO Prodriv.Hotchkis.Stromng. |
![]() ![]() not the harmonic balancing pulley thread again !!!! 9.5lb flywheel is too light , you may get away with a 14lb or something like that , but that combo will give you cels. ( but as far as anyone has posted, no damage, still I would personally not risk it ) |
#19 |
Member#: 138653
Vehicle:05 WRX grcrygttr it's been ROMRaided |
#20 |
Member#: 147972
Vehicle:2004 wrx hybrid 18g [email protected] dd |
![]() Ive been running my exedy lwfw for like 3+ years now with no cel's. Ive been running that in conjunction with the perrin lwcp for just over a year now with no problems at all. I beat on it too
#21 | |
Member#: 101730
South East
![]() Quote:
Yeah I have a PPG gearbox with ACT HD Clutch (street disc) and a Fidanza LW flywheel (9.5#) Saying this, I already get phantom misfires on 3 cylinders. However I suppose it is not enough of a problem to actually illuminate the CEL. I think I might try a LW crank pulley for a little and see how it does. |
#22 |
Member#: 147972
![]() Supposedly its like dropping a 100 pounds off your car with the pulley, not enough for the butt dyno but im sure it plays a role in why my stock turbo car is so fast
#23 |
Member#: 27136
![]() It may have something to to with each individual car. I've read many times that most people have issues with less than 14lbs.
I don't know what makes my car (and some others) a bit different. I have an 04 WRX that has 92k miles, and a Cusco 10lb flywheel since 60k. No problems. Although if it sounds odd, the car seems to have gotten used to the flywheel. The rpm's drop slow(er) over the 30,000 miles. |
FS in CO: P&P Headers, Crank Pulley, Stock DP | charlesdixon | Engine/Power/Exhaust | 4 | 06-04-2010 09:11 AM |
Cams + LW Flywheel + LW Pulley = CEL...? | fastenova | Legacy Forum | 2 | 07-15-2008 08:43 PM |
LW Pulleys and LW flywheel combo bad? | PhilSine | Built Motor Discussion | 7 | 11-06-2007 08:55 PM |
FS in NJ: CHEAP BRAND NEW PERRIN LW CRANK PULLEY | nothingclub | Engine/Power/Exhaust | 4 | 07-29-2007 06:48 PM |
Consensus on LW crank pulley and LW flywheel? | Compressed | Normally Aspirated Powertrain | 23 | 07-17-2003 01:13 AM |
