Old 05-31-2010, 09:14 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Default HID on = radio reception off
ok, this one got me... I noticed that when I turn on my headlights (HIDs wired in through a relay with proper ballast grounding) my radio reception kinda "dims" and gets more noise
anyone has any theories?
the ballasts do make the quiet buzzing sound when they work, so I can only assume this frequency creates noise?
*mods related:
HIDs, roof mounted active antenna, JDM frequency headunit
Hyper is offline   Reply With Quote
Old 05-31-2010, 09:27 AM   #2
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
Ballasts, especially aftermarket ones, do create RFI/EMI. If the housings are plastic instead of metal it will be worse. The noise can get into your radio two ways, by radiated RF and power line noise. If it's being radiated, your amplified antenna may be making it worse.
Old 05-31-2010, 09:30 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
ballasts are metal, I got myself one of those "more expensive" HID kits
would disconnecting the power wire from the antenna make it better, or would this worsen the general reception?
Old 05-31-2010, 12:00 PM   #4
Mulder
Trust no one
Member#: 11170
02 RAV4 MT
15 WRX/11 CRZ
If the antenna is made with an internal preamp that requires power, then disconnecting it will probably make your reception worse. You can certainly try it.
Also if you have a portable FM radio you can try holding it near the antenna with the lights turned on to see if the noise is in fact being radiated and picked up by the antenna.
Old 05-31-2010, 12:30 PM   #5
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
HIDs kill FM radio reception.iPod integration FTW
colin1234567 is offline   Reply With Quote
Old 05-31-2010, 12:32 PM   #6
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
now I know if I am going home and night and there's a good song, I have to switch my headlights off and pray
Old 05-31-2010, 10:06 PM   #7
suby09
Member#: 217985
I have after market HIDS and dont have this problem. I did have a reception problem when I first changed out my head unit. Once I added a relay to the power antenna wire my issues went away. Try adding a relay to the power antenna and also check your ground wire. make sure the paint is scraped off the metal and that it is solid. Good Luck
suby09 is offline   Reply With Quote
Old 06-01-2010, 01:24 AM   #8
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
There is never a good song on the radio.
Also this is God's way of telling you to take out your HID kit.
XanRules is offline   Reply With Quote
Old 06-01-2010, 07:17 AM   #9
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
care to elaborate what's wrong with HIDs installed in proper projection lenses?
bad radio reception and hd radio ? sittinsideways Car Audio, Video & Security 5 03-25-2010 07:16 PM
Bad Radio Reception on Headunit Upgrade DeathPool Car Audio, Video & Security 3 07-11-2009 11:32 PM
Problem on radio reception on my 04 STI STI808 Electrical & Lighting 10 12-29-2003 09:42 PM
Is it possible to increase radio reception? TrunkMonk Car Audio, Video & Security 3 01-24-2003 03:12 AM
Fuzzy radio reception Keiho Car Audio, Video & Security 2 03-02-2002 10:06 PM
