#51 |
Member#: 8247
Vehicle:2016 Outback 2005 Lotus Elise |
![]() Quick question. Pin 7 of the 741.. is it tied to the output as well as ground or straight to ground. I'm assuming ground but its always good to be sure. Pin 7.. thats Vcc right? I'm thinking it is.. but I'm not sure.
-- Steve
#52 |
Member#: 25796
Vehicle:2012 Impreza |
![]() Pin 7 is Vcc, yes. Do not hook it up to ground! It should be connected directly to the Illum(+) input. This way the circuit will be powered when the headlights are on, and will not be powered when the headlights are off.
In the schematic, where wires cross, they are only actually connected if they have a dot at the joint. |
#53 |
Member#: 16738
Vehicle:2015 WRX Limited CWP |
![]() Just to let everyone know the setup that vrg3 designed works perfect for my three Omori gauges, they dim(with the factory dimmer) and match very well with my dash lighting now. Anyone electrically inclined(not me) should try this out, it does work well.
BTW i don't think there is much to worry abouyt with three gauges, I took a reading toward the beginning of this thread and I was only seeing about .5 amp with all three gauges hooked up. If someone who knows what they are doing and has three omori's could verify this i would really appreciate it. -James Last edited by jjunior887; 04-29-2003 at 08:37 PM. |
#54 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
![]() i nominate this thread for a sticky, or a FAQ submission, since it seems like a fairly common problem and an elegant solution!
ken |
#55 |
Member#: 6204
Vehicle:2002 WRX Sedan WR Blue |
![]() Don, when you nail this little black box down, can I get one please?
Cheers, Scoob. |
#56 |
Member#: 16738
![]() Hey vrg3, where did you get the blue plug in the pic? It looks like it would work for our cars too.
#57 |
Member#: 25796
![]() I just looked in my tub o' Subaru stuff.
![]() If it wasn't off an engine wiring harness, it must have been a stock speaker connector for some car. |
#58 |
Member#: 35693
Vehicle:03 wrx wagon white |
![]() I made the Omori meter light dim with the stock lamps by using a transister to invert the variable voltage; so when stock lights are dimmed meter lamp dims ~ applies a varying positive voltage controled by the varying neg voltage.
#59 |
Member#: 6204
![]() Can you post a circuit digram for us non elec. engineers? Thanks!
Scoob. |
#60 |
Member#: 33979
South East
Vehicle:2006 STi WRB |
![]() Bump for those looking to dim Omori lights.
#61 |
Member#: 11544
RMIC
Vehicle:93, 05, 16 Taco TRD 01 RS 02 WRX 06 XT 08 STi |
![]() Would anybody be willing to make and sell one of these transistor/converter things, like the one vrg3 made?
I just want to get my gauges and dash to work in sync. Any help of further insight is appreciated. Thanks Joel |
#62 |
Member#: 8929
Vehicle:2002 WRX Sedan Silver |
![]() (*really* glad I found this thread as it helped me immensely on my Omori install in my WRX)
Thanks vrg3! and the rest of you (jehcpa, jjunior887, Thaison) for your input. I just made the do-hicky with the 741 and TIP31 transistor--works great! I'm using it to dim my Omori EGT and boost gauges mounted in an Autometer instrument bezel pics here ![]() One question... I left my EGT sensor unplugged since I don't have the manifold tapped yet. Is it safe to do that? The EGT registers its max when I do this...... |
#63 |
Member#: 25796
![]() Joel - I know I'm a month or two late... but I just PM'd you.
breed - Awesome. Glad it's working for you. ![]() It should be okay to leave the EGT sensor unplugged, but why not just cut power to the gauge itself to be safe? |
#64 |
Member#: 29719
Vehicle:'06 WRX Wagon Silver |
![]() Someone really needs to submit a circuit diagram for this to Scoobymods.com! My gauges are coming in next week, so if no one steps up before i get them installed i'll do a write up.
#65 |
Member#: 6204
![]() Check page 2, there's a link with a circuit diagram in there.. I missed it too, only found it yesterday! Duh!
Scoob. |
#66 |
Member#: 39552
BAIC
Vehicle:2003 WRX Wagon WRB |
![]() I tried to get my circuit to work with my electrical Omori gauges but couldn't. Can those that are running the electrical Omori's tell me how you hooked up the Omori harness? There are five leads on the Omori harness. White, Red, Brown, Black (2pcs). To get the gauges to read properly, I made the following connections. White to the switched light power in the Subaru harness. Red to an ignition power source in the fuse box. Black leads were grounded, and brown wasn't used. The gauges read and work fine. The gauge lights turn on and off with the car lights, but do not dim.
Any help would be greatly appreciated. Thanks. |
#67 |
Member#: 33979
South East
![]() You have connected properly.
They will not dim because Subaru dims dash lights through the ground & Omori does not provid a backlight ground as both black wires are connected internally - kind of the topic of this entire thread... You would need the circuit being discussed which will convert the ground based dimming into a v+ source dimmer to dim your gauges. |
#68 |
Member#: 25796
![]() Uh, Moondongle did build the circuit to reverse the illumination voltage, so he doesn't need a separate backlight ground. He just needs a clearer explanation of which wire is which than is provided in the Omori "documentation."
#69 |
Member#: 33979
South East
![]() That was not entirely clear in his post given the connections he made, I apologize.
The red is the power for the gauge and if an electrical gauge also for the sender. White is the power for the backlight. The black provides ground to both the gauge power (sender) and also the backlight. The brown is for an external warning light for the 60mm gauges but is included on all harnesses even ones that don't have the output. The white would need to receive its signal through the circuit if it is being used - the current connection does not sound like the circuit is being used. |
#70 |
Member#: 25796
![]() So connecting red to +12v, white to the output of the circuit, and black to ground should work?
#71 |
Vendor
Member#: 40645
![]() OEM lighting + goes to illum +
OEM lighting ground goes to illum - Omori white wire would go to out Ground of course goes to ground Omori red will go to an ignition on hot wire Omori black goes to ground If the circuit works as advertised and is connected properly then you should get the expected results. |
#72 |
Member#: 29719
![]() I've got pics and am working on a write up for this right now, expect it this week.
#73 |
Member#: 39552
BAIC
![]() turboICE: Sorry I wasn't clear in my post regarding my connections. After much frustration, I just gave up the dimming circuit and connected the gauges to work, hence my connections direct from Omori harness to Suby harness.
Thanks for clarifying the Omori harness. I couldn't make heads or tails of the brown lead. Now it makes sense. Let me just reiterate with Charged Perfomance posted here to make absolutely sure. OEM + (Switched lights) connects to VRG3 circuit Illum + OEM - (Dimming Lights) connects to VRG3 circuit Illum - Omori White connects to VRG3 output lead Omori Black is grounded Omori Red connected to ignition switched power Omori Brown connects to external warning lamp if desired Thanks for the help. |
#74 |
Vendor
Member#: 40645
![]() turboICE is my personal account - sometimes when checking PMs I end up posting along without realizing the user id I am under.
Yes your reiteration is accurate - adding that the VRG3 itself has a constant ground connection that needs to be made as well at the bottom of the schematic. We have not tested this circuit but others said it had worked. You did connect the gauges properly for use without the circuit in your original post - the only wire you change when using the circuit is the one that the white wire connects to. Ed. |
#75 |
Member#: 39552
BAIC
![]() OK. I'm now clear and thanks for your help. I'll try these connections when I have the new circuit. I may have fried a chip either soldering or trying different connections, so I'll try it with a fresh one.
head light dim question | wrxturbo04 | Electrical & Lighting | 1 | 08-26-2007 11:00 AM |
ATTN Elec gurus -- ILLUM(-) questions.. | Dendrobium | Electrical & Lighting | 5 | 03-11-2005 06:31 PM |
hod di i get my omori elec.gauges to dim?? | StarDogChampion | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-24-2002 07:27 PM |
Attn. Turbo Gurus - uppipe question | M_Annequin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 07-01-2002 02:35 PM |
Attn Paultg!!! Trunk Light question | kevinsUBARU | New England Impreza Club Forum -- NESIC | 3 | 09-05-2000 12:15 AM |
