#1 |
Member#: 40306
NWIC
Vehicle:2007 STi, finally! Suby # 4, UGM |
![]() I have an 04 WRX and the dealer claims that my window tinting affected my radio reception. This was after I complained that it didn't work very well (AM almost nothing) and they replaced several parts ( including the stereo for the 3rd time). Anyone else have a problem with this or does my window tint suck?
#2 |
Member#: 15106
![]() wave lengths. aren't you using the antenna on the a-pillar? |
#3 | |
Member#: 32493
South East
Vehicle:2002 Impreza WRX rock chipped blue |
![]() Quote:
#4 |
Member#: 40306
NWIC
![]() The 04 WRX has the antenna built into the rear window with the defroster.
#5 | |
Member#: 37785
Vehicle:2016 Mazda 3 White |
![]() Quote:
I have an 04 with 32% tint and do not have any reception problems. |
#6 |
Member#: 36255
Vehicle:04 WRB WRX Drive 2 Work,Work 2 Drive |
![]() I have dealer installed tinting on my windows. With my stock hu I couldn't pick up any AM stations, none!! I have recently installed a new hu and haven't checked the AM on it yet. The only time I want to listen to AM is for ball games on ESPN Radio. FM signals are fine, better than my truck with a regular antenna suprisingly.
I also don't see how the tinting can interfere with the reception of the signal on the antenna since it is not between the antenna and the window. Well, I checked this morning coming home from work and with the aftermarket hu I still can't pick up any AM stations. I'm sure that I don't have metallic tint. Last edited by skyhawk; 01-20-2004 at 09:48 AM. |
#7 | |
Member#: 32434
Vehicle:05 Outback XT 5EAT Gold/Black |
![]() Quote:
Craig |
#8 | |
Member#: 37785
![]() Quote:
#9 |
Member#: 34204
Vehicle:2004 WRX WR Blue |
![]() Are you sure? An experienced tint shop told me not to go full metallic tint on the rear windshield because it can affect reception (AM especially). I'm pretty sure metallic tint does affect reception with the rear-glass antenna. An analogy would be putting metal objects near an antenna.
#10 |
Member#: 37785
![]() No, I actually am just guessing.
![]() So you might be right. What kinds of tint are full metallic? Just the reflective stuff? And by full metallic is that 0%, or 20%, etc.? |
#11 |
Member#: 44621
Vehicle:2002 RSX Type-S White |
![]() Well this is just a thought, Dont tint the whole rear glass. Tint the defroster area and leave the strip at the top with out tinting for the antenna.
#12 | |
Member#: 34204
![]() Quote:
#13 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
![]() Remember, too, that no AM reception but OK FM reception is a classic sign of the antenna being unplugged from the HU or otherwise not working properly. Since the '04 window antenna is amplified, make sure that the antenna lead is correctly plugged into the HU *AND* that the window antenna amplifier has not been disconnected from its power connection.
#14 | |
Member#: 32434
![]() Quote:
Antennas work by being immersed in wave fields (the waves flow through and around the antenna). If you shield off one entire side of the antenna plane, you're pretty much blocking the antenna all together. Craig |
#15 |
Member#: 18713
Vehicle:06 CRV 04 STi |
![]() the last two posts above are both correct. Since most people don't listen to much AM, many people who use metallic tint on their rear window may never know whether or not it affects their antenna's performance, since they'll still get FM reception.
You can search, because this topic has been discussed before. I believe AM performance was negatively affected by the metallic tint, which could mean that FM is also. Of course, you might get enough FM performance leaking to your receiver for it not to matter. |
#16 |
Member#: 3457
International
Vehicle:2008 STi DGM |
![]() I have like no AM on my STi as well. I'm also tinted, but there's a thread on imprezawrxsti.com where like everyone was complaining about bad reception so it's not the tint's fault.
#17 | |
Member#: 32434
![]() Quote:
Make sure you supplied power to the antenna. That's a common mistake. The in-glass antennas have an amplifier that requires switched power from the radio harness. Most people skip that connection, thinking it refers to the power up/down antenna. But in fact, the in-glass antenna does need to have that power lead connected. Otherwise, you get really crappy reception. Craig |
#18 |
Member#: 54942
South East
Vehicle:2004 WRX |
![]() I just got tinting on my 04 (antenna inside rear windshield), and as I drove out of the shop, my AM reception was zilch. I'm one of the old farts who likes (some) AM, so I can affirm that the tint really attenuated AM reception. I think FM was affected as well, but nowhere as badly.
I'm contemplating grabbing an Xacto knife and cutting the film on either side of the antenna grid and seeing if I can peel back a narrow strip of film, where it contacts the grid lines...it's not as big a job as it sounds, the antenna is only three or four lines deep, at the top of the window. This would probably look better than removing the top 4" of film, too. Not sure how tightly that film adheres to the grid...maybe this weekend I'll try it. Steve |
#19 |
Member#: 18713
![]() you could also think about adding an external mast type antenna, like the 2002-2003 models have.
#20 |
Member#: 56015
RMIC
Vehicle:02 WRX Wagon 05 XT Forester |
![]() I have a 02 legacy (antenna in glass) with 5% Semi-metallic tint and all is good on both bands. I think it can effect it somewhat but with the antenna on the outside it is not that big of a deal. Now the alarm remote is a different story since it has to go through the tint to get to the brain. Maybe this is a WRX thing?
#21 |
Member#: 58105
Vehicle:2004 WRX WRB |
![]() I have 20% full metal tint and have no reception problems. I may also have one of the few 2004's with a pillar mounted antennae as well as the rear glass antennae although I don't know for sure which one is actually connected to the radio. Anybody else out there with an 04 and the pillar mounted antennae?
#22 |
Member#: 60071
Vehicle:2004 STi Java Black Pearl |
![]() A metallic or semi metallic tint could easily be a big ground plane dramatically shielding your antenna. It doesn't matter that the film is behind the antenna, it still will dramatically alter (reduce) your antenna's reception.
I'm not an RF engineer (just an audio geek), but I am a Ham, and this one will really FUBAR your reception. I haven't had my STi tinted yet, but I'm glad to hear this in time to ensure that I don't get metallic or semi metallic film on my back Window. Actually, if I turned the back window into a ground plane it might help my 2m/70cm reception though. |
04 WRX w/ poor radio reception | tfields04 | Car Audio, Video & Security | 3 | 06-16-2009 05:41 PM |
02 wrx window and 04 wrx window | co_hatch | Interior & Exterior Modification | 1 | 03-14-2009 03:12 PM |
Window Tint/AM Reception problem | hellraiser | Newbies & FAQs | 14 | 07-03-2006 07:21 AM |
Poor AM reception... caused by window tint?? | e28fixer | Car Audio, Video & Security | 4 | 08-28-2004 04:26 PM |
Anyone tried tinting just the rear windows on a wrx window? | SILVERWRXWAGON | Interior & Exterior Modification | 1 | 07-22-2001 09:59 PM |
