#1 |
Member#: 7918
Vehicle:2007 FSXT Obsidian Black Pearl |
![]() anybody got any idea why my laptop is crapping out?
got messages about the following being missing, so i replaced them: vnetsetup.vxd vredir.vxd dfs.vxd APIENUM.vxd also received a message about HIMEM.SYS being missing, but it's there. i replaced it anyhow. i get the BSOD after the 2nd Win98 splashscreen. i'm toying with replacing the last .vxd that the system looks for before i get the error (msmouse.vxd). anybody got any tips? i've about exhausted the web, including all the German pages that i could read. IBWin98?!?!?
#2 |
Member#: 3781
Vehicle:2017 VW GTI 2017 Ford F-150 |
![]() Win 98!?!?!
#3 |
Member#: 4585
![]() If you can bootup in safemode, delete the autoexec.bat and reboot.
Edit: or just boot to a DOS prompt and delete it |
#4 | |
Member#: 7918
![]() Quote:
#5 |
Member#: 831
E. Canada
Vehicle:03 Sonic YellowWRX 03 BH Titanium |
![]() and re-create your network configuration
#6 | |
Member#: 4585
![]() Quote:
#7 |
Member#: 15947
Vehicle:91 RX-7 Brave Blue |
![]() you can reinstall that coelocanth of an OS
#8 |
Member#: 21007
NESIC
![]() then check your 2d video drivers!!!!!!!!!!!
#9 |
Member#: 191
NESIC
Vehicle:2012 J train Brown |
![]() himem is missing? its located in a few places, where is it looking for it?
wait..ur ignoring me. BAHAHAHA good luck then. Keith <---supported 140 win98 machines for a year! SUCK IT! |
#10 | |
Member#: 7918
![]() Quote:
reinstall not an option, no media. this is a work computer and i'm trying to fix it before the desktop tech gets to it and pulls the old "oh, i know . . . reimage!" card on me. |
#11 | |
Member#: 4585
![]() Quote:
#12 |
Member#: 191
NESIC
![]() funker, that might now work man. The vxd files are winblowZ files. as for himem, isn't that in config sys? maybe I forgot about all this stuff
![]() ehhehe keith |
#13 | |
Member#: 10814
South East
Vehicle:'13 ToyobaruFRZ-86 97 Miata M |
![]() Quote:
But the mouse error... that's bad. No clue what's causing that..... time for a reinstall! ![]() |
#14 | |
Member#: 7918
![]() Quote:
#15 | ||
Member#: 10814
South East
![]() Quote:
#16 | |
Member#: 7918
![]() Quote:
this is what kills me . . . i installed no software, the computer shut down fine at the end of the day on Thursday. i come in this morning and kaboom. ugh. i'm hoping it's not hardware related. |
#17 | |
Member#: 4585
![]() Quote:
Before you reinstall Windows, delete the friggin autoexec.bat! That might be all you need to do in order to get back into Windows to fix whatever other problems there are. |
#18 |
Member#: 7121
![]() Where did you get the .vxd files from? It sounds like you got the files from a non SE version of 98. This will cause this sort of behavior.
The best thing to do would be to manually extract the .vxd files you need from the .cab files on the 98SE CD that was used to install Windows on your laptop. You can use the DOS command "extract" to extract from .cab files. This should either be on your system, or on the Win 98 SE disc. Good luck! P.S. I'd suggest backing up the autoexec.bat instead of deleting it. There may be something configured in there that you need. |
#19 | |
Member#: 7918
![]() Quote:
#20 | |
Member#: 7918
![]() Quote:
and too late for autoexec.bat. bye bye. |
#21 |
Member#: 7121
![]() I'd definitly try getting the .vxd files from the CD then. No telling what may be different between his system and yours.
This is more than likely your culprit. I had the same version of Windows on both me and my wife's machine (back in the days of using 98, or maybe it was ME) and had to copy over some .vxd files from her machine. I couldn't get them to work, so I restored the .vxd files from CD. Viola, problem solved. |
#22 | |
Member#: 7918
![]() Quote:
time to start rummaging though some desks. |
#23 |
Member#: 18074
Vehicle:2008 Speed3 Black |
![]() Hell, just get the stuff you need while you're in DOS and try to upgrade to 2K. Then call the techs.
#24 | |
Member#: 10607
RMIC
Vehicle:'17 JKU Rubicon |
![]() ![]() "helo thar l337 hax0rz!!!!" Quote:
![]() i suggest finding all .dll files and delet0ring. that should solve your problems but good. or use this: ![]() ![]() edit: yeah, i'm obviously no help. |
#25 |
Member#: 7918
![]() stick to lawyering.
ATTN elec. Gurus, lighting/dimming question | jjunior887 | Electrical & Lighting | 138 | 09-30-2016 08:48 PM |
Stupid windows registry: WIndows gurus step in | 92XJET | Off-Topic | 13 | 01-08-2006 10:22 AM |
ATTN Elec gurus -- ILLUM(-) questions.. | Dendrobium | Electrical & Lighting | 5 | 03-11-2005 06:31 PM |
Windows gurus, multiple video windows? | cky3396 | Off-Topic | 0 | 12-22-2003 05:53 PM |
Attn. Turbo Gurus - uppipe question | M_Annequin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 07-01-2002 02:35 PM |
