#1 |
Member#: 65609
SCIC
![]() I'm buying an ej257 shortblock that was attached to WRX DOHC heads...am I going to have a problem mating this ej257 to stock usdm sti heads? I'm going to call Axis tomorrow just wanted someone to assauge or confirm my concern tonight.
#2 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
![]() im thinking the pistons are different for the wrx heads. if you put the usdmsti heads on, i think you'll be way down on compression....there are some threads on here about this swap. www.crawfordperformance.com i believe has some info about this. hope this helps.
#3 |
Member#: 84912
SCIC
Vehicle:2003 2.5L bugeye now with 6 spd 20g! |
![]() Im thinking that if they used wrx compression pistons that you will be down compression as well.
#4 |
Member#: 95840
NWIC
![]() i checked and crawford makes a set of 2.5 pistons for the wrx head and the sti head. the dish looks deeper for the wrx head. call them and they will tell you. Its more than likely not a bolt on or a direct fit.
#5 |
Member#: 56791
South East
Vehicle:06 OBS |
![]() It's a good idea to call one of the engine builders for advice..
#6 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
![]() The volume of the combustion chamber is 51 cc with WRX heads vs. 57 cc with the STI heads. When you put the WRX heads on the 257 your compression ratio will be 8.7:1 versus 8.2:1 for the stock EJ257.
You really don't want to go any higher on the compression ratio unless you are going to run race gas all the time. So, don't 'deck' the block and don't buy pistons that raise the CR further (some aftermarket pistons are 8.5 CR). |
#7 |
Member#: 65609
SCIC
![]() I called Axis today--Ron confirmed that I would be running stock ej257 compression with a stock sized headgasket and usdm sti heads. The WRX heads that were previously attached gave the motor a decently higher compression ratio...so I'm in the clear. Thanks guys.
My motor build 07 wrx shortblock 2.0L heads | subydude02 | Built Motor Discussion | 50 | 09-28-2010 03:05 PM |
Cusco Motor Mounts for wrx or sti! | snowcrzy | Engine/Power/Exhaust | 9 | 09-26-2009 02:39 PM |
TW/FS - Megan Street coilovers for WRX, modified to fit BG/BD | mranlet | Legacy Specific Parts | 12 | 06-28-2007 11:41 PM |
Where to buy and how to wire levelling motor switch for STi EDM lights? | Orson | Electrical & Lighting | 22 | 02-02-2005 09:24 AM |
Anyone want to trade RS OEM mudflaps for RS cut to fit WRX ones? | Undepelo | Interior & Exterior Modification | 2 | 10-15-2004 04:00 PM |
