#1 |
Member#: 98962
South East
Vehicle:2006 OBP WRX 42Autosports tuned vf39 |
![]() So I just had my windows tinted Friday and now my radio reception is really bad, AM stations are pretty much gone so no local sportstalk radio.
![]() Thanks for any help.
#2 |
Member#: 93205
![]() Did you get metallic tint? That can interfere with radio reception since we have our antennas mounted inside the windshield.
#3 |
Member#: 847
South East
Vehicle:'18 Titan Crew Cab '16 Sienna XLE |
![]() Check and see if the installer unhooked the antenna plug from the glass while installing your tint.
#4 | |
Member#: 40581
Vehicle:04 STi Blue |
![]() Quote:
#5 |
Member#: 98962
South East
![]() No metallic. Don't really like how that looks. Where does the antenna plug into the glass?
#6 |
Member#: 100204
VIC
Vehicle:2006 STI (retired) WRB |
![]() The same problem happened to me. I got Huper Optik ceramic tint installed and lost my AM reception. FM still comes in strong and clear, but AM is really bad. If I touch the antenna wire (or even the defroster lines) on the glass from inside reception improves. Even if I wave my hand near the glass without touching it, reception improves.
A portable AM radio plays clearly resting underneath the tint. Something happens to the antenna once the tint touches the glass--metallic or not. Anyone know how to attach an external AM antenna to the OEM head unit? (I tried taping an AM anntenna loop to the wires on the back window, but that didn't work ![]() |
#7 |
Member#: 100470
Vehicle:2005 2.5 RS OBP |
![]() that sucks ... should i be worried about getting tints now?
#8 |
Member#: 98962
South East
![]() I went back and checked. It was metallic based tint.
#9 |
Member#: 90094
RMIC
Vehicle:2002 Pathfinder Merlot Perl |
![]() CDs? ipod?
#10 |
Member#: 82147
SCIC
Vehicle:2005 WRX Sedan Aspen White |
![]() Maybe an inline antenna booster? Not sure if that would work, but maybe it would...
~REVNU |
#11 |
Member#: 98962
South East
![]() Mount my XM radio near the rear window?
#12 | |
Member#: 51370
RMIC
Vehicle:a leaf, a yamie DCAWD |
![]() Quote:
And given the freq response of most tuners anyways I'd say now is a good time to look at upgrading to sat radio or at least some other source to quench your audio needs. my .02usd. (Does anyone else remember when Alpine separated the tuner packs for their units?) |
#13 |
Member#: 89912
Vehicle:2006 wrx wrb |
![]() omg what a pita
#14 |
Member#: 102145
Vehicle:'04 STi/Cobb St. II 18L Java Black Pearl |
![]() I might be wrong but here's what I think is the problem....
The signal is not being "Blocked" by the tint since the tint is actually behind the antenna element. Because the tint is metallic it conducts.... the element in your window is also a metal trace on glass. Ordinary car antennas are of a specific length (34" I think) since that supposedly recieves radio waves (¼ wavelength I think) Anyway, somehow the length of the antenna determines how good it recieves. If you look at the back window, the 3 or 4 lines at the top are the antenna element. The tint is probably shorting them together, and depending how the film is applied might even be shorting them to ground. Might not be any signal to boost to begin with, so any kind of antenna adapter would be pointless..... What might work better is this..... http://www.crutchfield.com/S-dpxryRI...0&I=12044UA200 A universal window mount antenna may get decent enough antenna reception, though most likely not as good as the original. Should also allow you to keep the tint on too... Anyhow, for $20 might be a last resort to try before peeling all that tint off..... |
#15 | |
Member#: 100204
VIC
![]() Quote:
![]() Thanks for the Crutchfield link. It looks like a viable option. I've been trying to listen to more CDs but it's just impossible to get traffic reports and hockey games on them ![]() |
#16 |
Member#: 82147
SCIC
![]() I used to have my Sirius Satellite antenna where the 3rd brake light was and the reception was good. After I got it tinted with a 50% (really light) SolarGard HP True Grey which is a semi-metallic, the reception from the satellite wasn't so great. So for now I've moved it outside the car and attached it onto the window with some 3M double sided tape just above the trunk and the reception is great! I'm going to try moving it back inside the car onto the dash right behind the clock and see how that works also. I'd rather have it inside the car if possible.
As far as FM reception I didn't notice any degradation in the quality... still sounds crappy as ever. I really don't listen to it much thanks to Sirius. I flip it on for my drive home and listen to Tom Leykis and that's about it. ~REVNU |
#17 | |
Member#: 102145
![]() Quote:
Want proof? Next time your remote for your car alarm isn't working well range-wise, stick the remote to the tip of your chin and press the button.... you should see increased range in many cases (since you are using your head as an antenna)..... ![]() Perhaps the ceramic based tints still conduct? Not sure, I'm not a chemist.... I just hunt illegal aliens for a living.... At least your heart is in the right place (GO REDWINGS!!!!) |
#18 |
Member#: 66235
Vehicle:2005 WRX Silver |
![]() they might have cut the thin att line in the glass when they cut the tint to fit...
#19 | |
Member#: 83473
TXIC
![]() Quote:
#20 | |
Member#: 98962
South East
![]() Quote:
#21 |
Member#: 102145
![]() If so... they owe you a new rear window....
#22 |
Member#: 86518
SCIC
Vehicle:2004 WRX STi Stage 2 |
![]() It's new window time!
#23 |
Member#: 85356
Vehicle:'05 2.5 RS-S Obsidian Black |
![]() I don't know about that theory. I have 8% on the whole car including the rear window and my radio reception is crystal clear AM & FM. Even my sirius sat. radio comes in great and that antenna is in the back ledge against the window. Must be the type of tint used or botched job.
'05 RS |
#24 | |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
![]() Quote:
![]() ![]() ![]() This is a classic issue with the the Subaru's in-glass antannae. Tint=poorer reception. Did you try a search? I chose to install an aftermarket antannae behind my rear view mirror. Can't see it, works great. |
#25 |
Member#: 66235
![]() I have my rear window tinted for a few months now and no noticable difference in radio reception. Just had to make an update
Radio reception is worse after installing aftermarket head unit. Help please! | SkylineR35GTRx | Car Audio, Video & Security | 19 | 03-24-2013 09:00 PM |
Fix your tinted 04+ radio reception! | qoncept | Car Audio, Video & Security | 27 | 05-10-2010 02:45 PM |
06 WRX loses radio reception after headunit swap | Guru Imakuni | Car Audio, Video & Security | 2 | 08-20-2008 07:29 PM |
Bad radio reception after Headunit install? | pearl | Car Audio, Video & Security | 3 | 08-13-2007 11:51 PM |
New tint job = messed up radio reception | doobyscooby | Interior & Exterior Modification | 18 | 05-25-2005 08:42 AM |
