Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Old 10-05-2009, 09:22 PM   #1
Type2
Member#: 200436
2004 Forester XT
Default Build your own slip plates for alignment?
I did a few searches online and they are EXPENSIVE. I plan on doing my own alignment this weekend after I get my rear brakes/struts on and instead of using greased vinyl tiles, which will be messy and a pain to store, I'd like to possibly make my own. Has anyone done this? It doesnt look too terribly complex - Just two plates, ball bearings, grease, locking pin(s).
Type2 is offline   Reply With Quote
Old 10-05-2009, 09:23 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
use old playboys
no...really
Old 10-05-2009, 09:56 PM   #3
ProDarwin
Member#: 134943
94 SW2, 95 SW2
9(?) Lemons Car
5 or 6 plastic shopping bags under each wheel works fantastic.
ProDarwin is offline   Reply With Quote
Old 10-05-2009, 10:15 PM   #4
Type2
Member#: 200436
2004 Forester XT
actually, that sounds much better than greased up vinyl tiles. I'll probably go that route.
Old 10-05-2009, 10:26 PM   #5
GrundleJuice
Member#: 165749
works especially good on a hard smooth surface, not so good on asphalt. a couple drops of oil between the bags makes it super slippery.
Old 10-06-2009, 01:23 AM   #6
kwak
Member#: 73476
I'm curious to hear how well the plastic bags work.
I have seen a race team use thick aluminum plates with grease smeared between the two. They now use slip plates from Harbor Freight. Those are relatively inexpensive. They are steel and very heavy to lug around.
kwak is offline   Reply With Quote
Old 10-06-2009, 06:28 AM   #7
renhoek
Member#: 71339
1995 WRX STi RA
1995 WRX STi LS1
Originally Posted by Uncle Scotty View Post
use old playboys
no...really
OK. But how do we make 'em slippery?
renhoek is offline   Reply With Quote
Old 10-06-2009, 07:29 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
the glossy paper does the trick.....put the closed end towards the rear
Old 10-06-2009, 09:20 AM   #9
Type2
Member#: 200436
2004 Forester XT
How "inexpensive"? Can you post a link? Thanks.
Old 10-06-2009, 09:44 AM   #10
wantsti
Member#: 134764
04 sti
java black pearl
what a waste of a playboy
wantsti is offline   Reply With Quote
Old 10-06-2009, 10:04 AM   #11
joker75
Member#: 168516
2008 Imprexa 2.5i
Spark silver
+123456
There are so many other magazines that you could use. Why would you waste 4 good playboys for a wheel alignment.
joker75 is offline   Reply With Quote
Old 10-06-2009, 10:04 AM   #12
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Two 12x12 plates of steel. Grease between them. Bam instant slip plate.
Old 10-06-2009, 12:52 PM   #13
teslamaster
Member#: 152906
2007 Impreza 2.5i SE
Obsidian Black Pearl
^^ this. It works very well. It's slick enough I can push the side of the car a little bit and it will slide sideways on the plates.
teslamaster is offline   Reply With Quote
Old 10-06-2009, 01:00 PM   #14
.one lane
Member#: 114528
2002 Space Shuttle
Discovery
I have used two pieces of title (smooth side facing each other) with salt between them. I had them in the garage, and it's decent.
.one lane is offline   Reply With Quote
Old 10-06-2009, 01:23 PM   #15
kwak
Member#: 73476
I did a google search for you. The manual for them is: http://www.harborfreight.com/manuals...5999/45742.pdf
They are called Turn Plates, made by Central Machinery, model 45742. One forum said they were $149. I did not find them in the Harbor Freight catalog though.
Old 10-06-2009, 02:21 PM   #16
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
Here's a DIY link using greased tiles. Seems pretty easy...
SonicWRX is offline   Reply With Quote
Old 10-06-2009, 03:24 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
discontinued by HF
Old 10-07-2009, 12:25 PM   #18
ULL_WRX
Member#: 201252
Alum. tiles work well. I have tried them will oil, grease, trash bags, and wax paper between them and the paper and bags have worked the best and there's no mess.
ULL_WRX is offline   Reply With Quote
Old 10-07-2009, 12:59 PM   #19
SonicWRX
Member#: 24464
2007 WRX STi (SWP)
Surgeline Tuned
And where would one find aluminum tiles?
Build your own sub box for the Baja! moonzie Baja Forum 20 09-12-2020 01:45 PM
Build your own gaming computer for under $800 Kenji815 Off-Topic 62 06-15-2018 09:48 AM
build-your-own ignition coil for ej22? SubarNoober Service & Maintenance 2 01-06-2010 09:39 PM
Build your own catch can for $25. Here is how: txl146 Service & Maintenance 5 04-10-2006 08:57 AM
Build your own rally car for cheap! B D Off-Topic 25 06-29-2005 10:04 PM
