Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Old 01-06-2010, 12:35 PM   #1
SubarNoober
Member#: 133261
Default build-your-own ignition coil for ej22?
My '96 Legacy has--at 166k--finally started to show signs of ignition coil failure. The usual, intermittent bucking symptom has been occurring, with the occasional low idle. (The sparks are spec and only 15-20k old).
As we all know, the replacements are over $100, compared to 1/4 or less of that for standard coils. I don't know the arrangement of this coil pack (and am kind of puzzled by the 3-wire-only harness), but wondered if a ubar-cheapskate like myself couldn't rig up something with a few standard coils--assuming of course I can find the space and aesthetic humility to do so.
Any ideas?
SubarNoober is offline   Reply With Quote
Old 01-06-2010, 02:26 PM   #2
XanRules
Member#: 157348
I Thlammed My
Penith in the Car Door
I have a friend who used the MSD ignition module for a Mustang V8. I think that's probably more expensive, though.
XanRules is offline   Reply With Quote
Old 01-06-2010, 09:39 PM   #3
anothernord
Member#: 193703
The ignition coil from a Dodge Neon is an excellent replacement. It sounds silly, but lots of us Legacy guys are using them. The stock coil puts out 28K volts, and the Neon coil puts out 34K.
An even better alternative would be an MSD 8239. This swap requires the newer type of spark plug wires on the 99' year, and the pigtail from a late 90's Dodge Neon.
Here's a link that deals with everything:
http://sl-i.net/FORUM/viewtopic.php?f=39&t=5195
anothernord is offline   Reply With Quote
Build your own sub box for the Baja! moonzie Baja Forum 20 09-12-2020 01:45 PM
Build your own gaming computer for under $800 Kenji815 Off-Topic 62 06-15-2018 09:48 AM
Build your own slip plates for alignment? Type2 Brakes, Steering & Suspension 18 10-07-2009 12:59 PM
Build your own catch can for $25. Here is how: txl146 Service & Maintenance 5 04-10-2006 08:57 AM
Build your own rally car for cheap! B D Off-Topic 25 06-29-2005 10:04 PM
