Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-19-2009, 12:48 PM   #1
Jncominco2
Member#: 170212
Default How do you fix a stripped seat bolt?
k well i was in my car the other night and noticed the back screw on my passenger seat, the one closest to the center console, is totally loose
i have no clue how it happened cause i havent taken my seats out or touched the bolts, but its stripped and is completely out now
i get the bolt all the way in, try to tighten it, and it just slips
is there any way to fix it that you guys know of?
or would i have to drill a bigger hole?
Jncominco2 is offline   Reply With Quote
Old 02-19-2009, 12:55 PM   #2
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
if the hole isnt really bad you can try re threading it. but chances are its bad and you might have to tap to a bigger size. not sure how much room is in there for tapping tho.
bhhamblin is offline   Reply With Quote
Old 02-19-2009, 12:55 PM   #3
Subr-man
Member#: 169211
into a gearhead."
Goin' Back Old Skool
I would try manually running a tap through it first to see if you can get lucky on repairing the threads.
Worse cause step up one size and tap new treads and find corresponding bolt from hardware store(grade 8)[thats how I would roll]
Damn Brody!!
Subr-man is offline   Reply With Quote
Old 02-19-2009, 02:44 PM   #4
Not-EWRX
Member#: 158043
2013 Wrx Hatch
Hmm. I have one of these. Does anyone know what size tap the OEM bolt is?
Not-EWRX is offline   Reply With Quote
Old 02-19-2009, 03:02 PM   #5
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
would a helicoil work in this instance?
06HAWKMAN is offline   Reply With Quote
Old 02-19-2009, 03:23 PM   #6
Subr-man
Member#: 169211
into a gearhead."
yes but why waste a helicoil when you dont need to.
Old 02-19-2009, 04:51 PM   #7
Jncominco2
Member#: 170212
where would i buy a tap at?
and what size is the next size up?
Old 02-19-2009, 05:05 PM   #8
Subr-man
Member#: 169211
into a gearhead."
harbor freight you can get a basic tap set.
I havent had time to find out the bolt size I may have the taps necessary. if you can find out let me know and Ill check taps.
I just saw where you are located, buying from harbor frieght would be cheaper than meeting me twice haha. you can buy invidual taps aswell at certain places autozone checker
some may even rent sets out, im not sure
Old 02-19-2009, 05:56 PM   #9
Jncominco2
Member#: 170212
k ill be sure to check autozone and checkers
any ideas on where i could find out the size?
Old 02-19-2009, 06:14 PM   #10
Gonz#75
Member#: 101841
1998 2.5RS
mostly black
That is an odd size if I remember correctly. Normally for a 10mm bolt is a 1.5 thread pitch and a 12mm is 1.75 but the bolt seems to be a tighter pitch than that. I am going to swap my seat tonight and look at the thread. I don't know that there is enough meat on there anyway for a heli-coil, it's only the thickness of the transmission tunnel I believe.
Gonz#75 is offline   Reply With Quote
Old 02-19-2009, 07:14 PM   #11
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
Hit lance up I know my Pa has them tools in West Haven
medamullet is offline   Reply With Quote
Old 02-19-2009, 09:32 PM   #12
Jncominco2
Member#: 170212
speaking of lance, i think i saw him on 4000 today hah
would he know what to do meda?
How Do You Fix Wheel Bearings Cheap? ChungerSuby Transmission (AT/MT) & Driveline 2 08-23-2005 04:11 AM
How do you fix the dents/dings subimp6u08 Interior & Exterior Modification 10 04-27-2003 08:35 PM
Winter gas + UTEC.. how do you fix? mightbewrx Engine Management & Tuning 12 04-04-2003 10:55 AM
How do you fix a crooked steering wheel??? RedBull555 Bay Area Impreza Club Forum -- BAIC 8 03-06-2002 12:17 PM
Unorthodox Pulley Install - how do you break that F*&#ing bolt???? Tim Harris Technical Forum Archive 19 06-02-2000 10:55 PM
