Welcome to the North American Subaru Impreza Owners Club Tuesday February 25, 2020
Old 11-12-2018, 06:57 AM   #176
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Originally Posted by shake-rattle-n-roll View Post
i guess a samsung galaxy s9 isnt modern
The S9 still comes with mirrorlink?
SirBrass is offline   Reply With Quote
Old 11-12-2018, 08:47 PM   #177
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Originally Posted by SirBrass View Post
Sounds like it could just be a CP thing in the HU and not affect AA.
The issue with AA is if you do something like restart your phone in the middle of a drive, AA may not want to reconnect without you restarting the car (only way of canceling figure out to hard restart the HU) at least once.
From the read (various sites) AndroidAuto appears to work with these new HU's.
I didn't buy the car for CarPlay so it's fine, but would be nice if it worked properly. I was about to pull the trigger on a 2018 Limited with HK, but found damage on the new car so passed and picked up my 19 Limited with HK at another dealer.
oichan is offline   Reply With Quote
Old 11-12-2018, 11:04 PM   #178
kenef
Member#: 493122
2019 WRX
Wow hopefully no damage on my new 2019 this Friday, just getting here.
Where was the damage, how noticeable was it?
Luckily my 2019 will have this so I don't have to worry... but hopefully I won't have an urge to upgrade.
kenef is offline   Reply With Quote
Old 11-12-2018, 11:27 PM   #179
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Take it from a guy whose last 3 Subarus never went a month before he pulled the trigger on an audio system overhaul: the 2019 HU is perfectly fine fine especially with HK for most of what you'll probably want.
I have the base model HU in my 19 Limited (got mine unoptioned intentionally) and I think I can go a year or so at least before I begin overhauling it, starting with the HU.
Audio isn't muddy (neither is it really good, however), AA works fine with only a minor HU hiccup. Only major major gripe is something they included as a feature (and something my wife's 2010 Malibu had as well, BTW), and that is that when you turn the engine off, the radio not only stays on, but drops to the radio, which you may not have been listening to. That's annoying. If it's going to have a "keep audio on till the door opens", it should be for connected media as well. Keep playing over AA/CP or BT as well.
That's the only massive beef I've got with the stock HU, and in the larger scheme of things, that's not really all that big of a deal. Just find an inoffensive FM, AM, or XM station, set it as preset 1 and let that be what keeps dropping back on when you shut the engine off.
Old 11-13-2018, 12:46 AM   #180
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
The 18 had damage on the rear quarter panel. It was pretty bad too, like a chain got caught up between the tire and arch when they backed it off the truck or something. Dealer said theyíd fix it but I wasnít in any rush so decided to check another dealer the following day. Thatís where I found my 19. The CarPlay was supposed to be a plus, but oh well.
GL with the delivery on your STI!
Old 11-13-2018, 04:30 PM   #181
Nahoward
Member#: 486869
2018 WRX CVT Stage2
Lapis Blue
So, has anyone tried the (potentially bad idea) of exporting the '19 HU firmware and importing it into an '18 HU?
I'm curious what would happen, especially if you had a way to export the '18 HU firmware first so you overwrite the original firmware back onto the device should things go sideways.
Nahoward is offline   Reply With Quote
Old 11-13-2018, 05:06 PM   #182
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Probably wouldn't work. Internal electronics are different as processing is faster and sound is better. Also, USB inputs are different as well.
Old 11-14-2018, 12:53 AM   #183
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Not sure why you 18 and earlier guys want the 19 HU when it doesn’t even work properly..
Unless for the new NAV and HK which is improved from earlier models. If for CarPlay forget it.
Old 11-14-2018, 02:42 AM   #184
kenef
Member#: 493122
2019 WRX
Yeah I have had that experience since I drove a Crosstrek for a while and noticed that, but seemed to happen at random times. More often than not the HU was ok. I will see how it is when I get it! I honestly didn't even play with it.
What kind of extra features would you want into an upgraded HU? The 2019 seems like it has plenty for me(CP, BT, XM, touchscreen)..I'm coming from an S2000, definitely not known for its sound quality I just know if I want to upgrade it I'd be likely to want a good one and I am sure they are at least $700+
The 18 had damage on the rear quarter panel. It was pretty bad too, like a chain got caught up between the tire and arch when they backed it off the truck or something. Dealer said they’d fix it but I wasn’t in any rush so decided to check another dealer the following day. That’s where I found my 19. The CarPlay was supposed to be a plus, but oh well.
Ah ok, well looks like it played out in your favor! Thank you, its just a WRX though. I waited about 5 weeks for this one so hopefully it goes well. Do you not have CarPlay? 2019s have it...
Old 11-14-2018, 07:41 AM   #185
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
I would like the HU (or better yet the MFD) to display individual tire pressures, BU camera to change parking lines when the wheels turn to show your backup path, and android auto wireless support.
I do like how the USB ports are all 2.1A though.
Old 11-14-2018, 08:57 AM   #186
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Oh, well WRX is cool too so GL with the delivery! mine does have CarPlay on its HK stereo, just doesnít work correctly.
Old 11-14-2018, 09:17 AM   #187
littledrummerboy
Member#: 94408
Ď17 STI Sport-Tech
The USB inputs afaik, just have higher amperage so you can do more battery intensive things through the phone while using CP/AA without draining battery. I'm leaning towards previous years USB inputs would still work data-wise, but won't charge as fast and could possibly slowly discharge your battery if you use multiple apps at the same time like maps and stream music... as I've read elsewhere happening to Outback owners.
Anyway, a USB module swap isn't hard to do either.
An OEM look is important to some; there's so much negative space in aftermarket bezels and it just doesn't look right to me. Also, I'm in Canada and I haven't really heard of CP issues -- maybe its our lack of telematics that helps? I also have it in my impreza and I have no issues using CP there.
littledrummerboy is offline   Reply With Quote
Old 11-14-2018, 11:29 AM   #188
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
HK HU does look good that is for sure.
Old 11-14-2018, 12:12 PM   #189
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
Standard STARLINK with the 19s is the same look, just sans NAV and preamp outputs to the HK system.
That's something I'm going to be very picky about in selecting an aftermarket HU: the ability to get the screen as close to flush with the bezel trim as possible.
I don't mind the negative space that will be there as I don't reach for those buttons often or at all (and only when I must) when driving, and they all have their touchscreen equivalents which are just as speedy in response.
And an aftermarket HU with the bezel will give me some flat space to mount the AP that isn't on the soft touch dash or partially obstructing a vent.
Now if only the HU makers would get with the program and up the available output on their AA/CP USB ports to support USB C spec charging (5V/3A).
Old 11-14-2018, 09:15 PM   #190
oichan
Member#: 492327
19 WRX / 16 STI
17 Golf-R / 16 FiST
Is it? Then more to you!
Old 11-26-2018, 11:46 AM   #191
obiwantoby
Member#: 428773
2018 WRX Limited
WR Blue
Originally Posted by Daijoubo-yo View Post
I too have this problem with my 18 limited and so have a few others. I turned down the treble and it helped a bit but other than that itís still there. Just learned to tune it out for the most part. Pretty pathetic for an Ďupgraded stereo.í Havenít complained to the dealer yet.
A guy on clubwrx had his head unit changed and didnít fix the issue. I might push them to change out the amp on mine see if it does anything.
I have started s few threads on this. Sorta glad to see others with this issue. I wonder if the alternator fix would fix it - or similar. I want I get some ferrite cores on the back of the radio next.
obiwantoby is offline   Reply With Quote
Old 11-26-2018, 09:36 PM   #192
Daijoubo-yo
Member#: 252612
2010 WRX 5dr
97 Lude Sh,99 Durango 5.2
Itís most likely coming from the alternator. Iíve gotten it to increase and decrease with RPMs. Itís drown out at higher volumes which is nice but for talk radio and switching between stations itís easily noticeable. All sources. Iíve gotten the dealer to acknowledge itís there and not normal. Said they will get their electrical guy on it when I want to schedule something. Donít really want it ripped apart but Iíll have them take a look next service and update you on it.
So far I know for sure itís not the battery, headunit, or dash tweeters.
Daijoubo-yo is offline   Reply With Quote
Old 12-05-2018, 05:53 PM   #193
brettjson
Member#: 490337
So, did anyone end up plugging in the 2019 head unit to a 16-18 and see if it works?
brettjson is offline   Reply With Quote
Old 12-10-2018, 05:01 PM   #194
RPW44
Member#: 466961
Ditto. I have the Ď18 w/ HK and Nav and while the sound is good, the Nav and hands free stuff is trash. Was really excited at the prospect of getting Apple Play into my car.
RPW44 is online now   Reply With Quote
Old 12-10-2018, 05:20 PM   #195
JerseyKid
Member#: 135901
2017 STi
Crystal White Pearl
My biggest complaint about my 17 is no Android Auto - thats literally all i want extra in this car. I will be patiently waiting and watching this thread to see if the MY 19 units will work - or if subaru throws us a bone and offers a software upgrade.
JerseyKid is offline   Reply With Quote
Old 12-11-2018, 12:28 PM   #196
phd12v
Member#: 432497
18 Sti
ISM
there will be no update, the radios dont have the capability to do it... i wish i could tell you it could happen, but it wont.
Could it be adapted over from a 2019 unit?? most likely it could...but with the cost of it, it might be better to just put a new unit in for your application.
phd12v is offline   Reply With Quote
Old 12-11-2018, 12:46 PM   #197
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
With what it would cost to buy and fit one of the new HUs into an older WRX, one can get a better-than-HK audio system with a AA-supported HU.
Old 02-04-2019, 12:06 PM   #198
protivakid
Member#: 265148
2001 Legacy
As soon as I can find a used '19 radio from a WRX owner who upgraded to aftermarket I plan to try exactly this in my '16
protivakid is offline   Reply With Quote
Old 02-07-2019, 11:45 PM   #199
Onoman
Member#: 497145
Default Maestro
Any word on the Maestro units supporting the 2018 and up yet?
Onoman is offline   Reply With Quote
Old 02-18-2019, 10:45 PM   #200
Subie Muchacho
Member#: 490151
2018 WRX STI Limited
Ice Silver Metallic
Originally Posted by caschnd1 View Post
I wanted Apple CarPlay in my 2018 STi so I installed a Pioneer AVIC 8200NEX head unit. It's Android based. $620 for the HU and about $150 for the harness bits, dash surround, etc. No modifications needed to the OEM harness.
Can you provide a list of the accessories and harnesses that you used? Also, does your 2018 STI have a Harman Kardon system? Thanks.
Subie Muchacho is offline   Reply With Quote
