Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 07-19-2002, 12:13 AM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Did anyone running a BOV on stock wrx consider the spool up hit of the stock bov?
It seems that Suabru put the BOV vent tube right before the turbo impeller for a reason - - when you release the gas - a blast of air heads right before the wheel - and thats got to help that wheel get spinning again when you shift fast and then hit the gas trying to build that boost back up
interesting idea - tap a vac gauge in the intake tube near the turbo inlet and see what that air comming through the bov tube does to the pressure in that tube
IF you think I am smkoing crack on this point - then look at Cris Rado's new Celica drag car and see where he vents his BOV to - - he sure ain't looking to impress anyone with loud sounds
alfriedesq is offline   Reply With Quote
Old 07-19-2002, 11:36 AM   #2
Z1 Performance
Member#: 9327
not sure how much it helps on a WRX given its ultra small turbo, but it certainly doesn't hurt!
Now on Chri's car, his turbo is the size of my head roughly, so it's a different ballgame when he shifts!
adam
www.z1auto.com
Z1 Performance is offline   Reply With Quote
Old 07-19-2002, 12:21 PM   #3
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
adam
www.z1auto.com
Your prob rightg - - but i can feel that air comming off my HKS blow up valve - it should help at least to reduce the vacume in the intake hose when it releases air into it - and that must help the wheel to spind a bit quicker - (every little bit helps)??
Old 07-19-2002, 02:07 PM   #4
dRu18
Member#: 4034
2005 Infiniti G35c
Ivory Pearl
i hope there isn't such a thing
-Andrew
dRu18 is offline   Reply With Quote
Old 07-20-2002, 04:29 PM   #5
WizardBlackWRX
Member#: 14979
Al, the DSM guys actually modify their intake tract to dump the BOV closer to the turbo inlet, and at less of a right angle for optimum effect. There are other reasons they do it, but that is one.
http://users.erinet.com/40666/images...IP-1gB_blk.jpg
WizardBlackWRX is offline   Reply With Quote
Old 07-20-2002, 04:38 PM   #6
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
The 2nd gen DSM did something similar. The BOV dumped in the intake right before turbo. Unfortunetly, they put this dump tube inside the intake snorkel which inhibited air flow to the turbo.
ChrisW is offline   Reply With Quote
Old 07-22-2002, 12:26 PM   #7
Austin
Member#: 7089
2016 STi
Austin is offline   Reply With Quote
What would be the spool up difference between a bolt on gt30r vs a roatated gt30r? silver07sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-06-2008 07:11 AM
Did anyone watch 20/20 on Friday? It was about the state of U.S. Healthcare. nepawrx Off-Topic 69 09-19-2007 12:21 PM
Has anyone run six points on the stock my00 rs seat? JTJ 2.5 Interior & Exterior Modification 1 01-25-2006 10:22 PM
Anyone running over 20psi on stock BOV V REX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 05-26-2005 01:42 AM
Anyone see the WRX on the sidewalk in front of the Wiltern last night (Tues 11-5)? Mako Southern California Impreza Club Forum -- SCIC 4 11-07-2002 05:18 PM
