04-07-2012, 05:40 PM | #1 |
Member#: 220158
RMIC
Vehicle:02 bugeye medamullet tuned |
boost issues
2002 wrx cobb ap tuned stage 2
It started off i was only hitting 5psi, i was missing the restrictor pill. i put one in and now I'm only hitting 10 psi. I done the following to try and figure this out. -swapped wastegates -cleaned MAF -Checked for leaks -Loaded the stage 2 HWG (high waste gate map) -Swapped BCS with one that I'm pretty positive is still good. I disconnect the vacuum hose to the waste gate and i can hit 15 psi with ease.. what else could the problem be? the car drives fine, its just pissing me off that i can't hit the target boost! |
04-07-2012, 05:53 PM | #2 |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
Did you check the hoses for leaks?
04-07-2012, 06:30 PM | #3 |
Member#: 220158
RMIC
yeah thats on the list haha maybe I'm missing some.
04-07-2012, 06:57 PM | #4 |
Member#: 193412
RMIC
Vehicle:1985 pumas. white |
Check the vacuum hose of the ebcs off the inlet tube for any damage. Also make sure that restrictor pill is 1 inche away from the 90 degree elbow off the cold side of the turbo! Not the wastegate if that pill is near the waste gate 2/3's of your pressure is just being sent to the ebcs. If that does not work try pulling the compressor bypass valve off and pressing the piston in. If it is easy to press in that could be your problem. If none of that fixes your problem. Download a map that has a higher wastegate duty cycle map
04-07-2012, 07:24 PM | #5 |
Member#: 220158
RMIC
the pill is on the cold side of the turbo.. compressor bypass valve? sorry is there another name for that I'm not sure what that is haha..
i did download/flashed a map from cobb that is for this problem. nothing happened when i loaded the map, its still hitting the same boost. |
04-07-2012, 09:45 PM | #6 |
Member#: 220158
RMIC
tested the BCS with a battery and its working. I'm lost! i don't hear any exhaust leaks but i need to feel around for one.
any other ideas? |
04-07-2012, 10:08 PM | #7 |
Member#: 183634
RMIC
Vehicle:02 wrx/ 92 ss Booze fueled :) |
You could just go to a blocking type soleniod, then find or get a map for that.
04-07-2012, 10:08 PM | #8 |
Member#: 162108
RMIC
I have the same issue with my wagon, not sure what the issue is either.
04-07-2012, 10:38 PM | #9 |
Member#: 220158
RMIC
id like to stick to the maps from cobb, just because i don't want to pay for a new tune haha.
so when i unhooked the vac line from the waste gate and got normal boost, i assumed bad waste gate. is there something else i could gather from that? |
04-07-2012, 11:07 PM | #10 |
Member#: 99397
RMIC
Vehicle:15 WRX, 83 DR30, 93 R32 GTS-T, 93 R32 GTR |
Do you have the right size restrictor pill in the line? You can change boost pressure with different size pills.
04-07-2012, 11:08 PM | #11 |
Member#: 289115
RMIC
Vehicle:2002 WRX WRB |
My bugeye is acting ****ed up too. My boost gauge will hit 15psi than it will bounce all over to and from 15...
04-08-2012, 12:25 AM | #12 |
Member#: 157721
RMIC
Vehicle:2003 WRX White |
Damn another one, I gave up on figuring out my issue. Haha
04-08-2012, 10:00 AM | #13 |
Member#: 220158
RMIC
I just assumed it was the right pill... Maybe I'll just go buy the hose kit from Subaru
04-09-2012, 11:40 AM | #14 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
just buy a MBC and call it a day....
04-09-2012, 04:16 PM | #15 | |
Member#: 85327
RMIC
04-09-2012, 04:23 PM | #16 |
Member#: 220158
RMIC
Alright. I just don't want that to cause further problems later. If you guys did it and think its a good idea I'll look into it.
04-09-2012, 05:22 PM | #17 |
Member#: 289115
RMIC
Mbc?..
04-09-2012, 05:50 PM | #18 |
Member#: 99442
International
04-09-2012, 05:30 PM | #19 |
Member#: 284636
Vehicle:2002 Wrx wagon White |
Have you recently taken off the turbo or uppipe or exhaust manifold?
04-09-2012, 06:49 PM | #20 |
Member#: 289115
RMIC
Lol...
04-09-2012, 09:39 PM | #21 |
Member#: 220158
RMIC
I haven't taken anything off. I bought the car from a member with a shop and they put a new motor in it. It runs awesome I'm just not hitting target boost.
So thinking MBC? |
04-09-2012, 10:18 PM | #22 |
Member#: 183634
RMIC
The stock unit is a bleed type and they have their pro's and cons but a big con is not being able to run more than say 12-13lbs of boost unless you re-size the pill. Jason is right either go with a blocking type Manual controller (look up the downsides) or go with an electronic controller. Either way pushing more load and more into an untuned portion of the map will lead to more risk. If your running an intake the risk increases as odds are the maf scaling will be even further off.
Suggest getting some parts and getting a roadtune. As spending the money for this will be cheaper than a new motor. |
04-10-2012, 01:05 AM | #23 | |
Member#: 99442
International
04-09-2012, 11:33 PM | #24 |
Member#: 220158
RMIC
Well if I went with the MBC I wouldn't exceed the psi that the Cobb map is tuned for. So ~14psi? Maybe 15
I don't want to go above that, because of the tune. I'd like to stick with the AP, since it's safe and I want safe instead of power. So if I go MBC and stay within the limits of the stage 2 Cobb map..I should be safe right? Because its tuned for that psi but it's just not hitting it. At least that's my understanding, if I have that wrong correct me. I don't want to do something stupid haha. |
04-10-2012, 12:05 AM | #25 |
Member#: 154117
RMIC
Vehicle:2021 STI CBS |
If you do go that route let us know how it works out. Im just curious...
Similar Threads | ||||
Boost issue - unsteady at max boost | sry110 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 04-14-2011 11:30 PM |
Boost issues /Boost in neautral? HELP PLEASE!!! | miket430 | Newbies & FAQs | 18 | 07-25-2010 06:15 PM |
idle issues and boost issues | jdgrimm | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-05-2006 09:45 PM |
Boost issues or Gauge Issues? | IwantONE | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 1 | 06-12-2006 05:18 PM |
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? | ImportVenom | Engine Management & Tuning | 2 | 06-23-2004 12:22 AM |
