#201 | |
Member#: 468078
Vehicle:2014 WRX S4 white |
![]() Quote:
#202 |
Member#: 462039
E. Canada
![]() Anyone have updated pictures for doing this on 2015+ wrx? The pictures on the first post don't work anymore.
#203 |
Member#: 413221
Vehicle:2009 Wrx STi Black |
![]() I just found this thread and want to do this but same, pictures are no longer available to view. Help!!
#204 | |
Member#: 410767
Vehicle:2012 Legacy GT 2009 Forester XT |
![]() Quote:
I have pictures around Post #30 in my build thread for my '09 Forester XT over on www.subaruforester.org. Gonna be the same as your car. http://www.subaruforester.org/vbulle...teaser-533601/ |
#205 |
Member#: 413221
![]() Thank! Appreciate it
#206 | |
Member#: 464530
Vehicle:2017 Impreza Ice Silver |
![]() Quote:
If I am seeing your setup right...you relocated the relay and then ran wires to it from the relay socket. Then ran a single wire from the fog relay itself to the DRL harness. Right?? |
#207 |
Member#: 410767
![]() I didn't do anything with any DRL harness. Did you see the diagram?
#208 |
Member#: 464530
#209 |
Member#: 410767
![]() IIRC it goes to the wire that normally powers the stalk fog switch when the headlights get turned on. That way it has constant power from the fuse tap even when the headlights are off or the high beam are on. It is what makes the fogs independent of the other lights and the stalk switch work at all times.
#210 | |
Member#: 464530
![]() Quote:
#211 |
Member#: 410767
![]() DRL and fog light circuits are 2 separate circuits. I disabled the stock DRL circuit by unplugging the DRL resistor.
#212 |
Member#: 254317
Vehicle:2011 STi |
![]() Thanks for this thread, OP
I found it easier to do the mod thru the side vent.. |
