Welcome to the North American Subaru Impreza Owners Club Sunday September 27, 2020
Old 11-16-2019, 09:22 AM   #1
riggy30
Member#: 158321
2010 WRX STI
Default How to know if the engine block is the original block that came with the car?
Hey, so I'm just wondering if there's anyway to trace the engine block's serial number to the car's vin #? The reason I ask is because I have a sneaky suspicion that SOA never replaced the block when I took the car in under warranty for a spun bearing... I know for a fact that these dealerships cut corners, especially when cars get brought in under warranty. Any help would be greatly appreciated.
riggy30 is offline   Reply With Quote
Old 11-16-2019, 02:50 PM   #2
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
Why do you suspect it wasn't replaced? Is the block not shiny clean?
I can tell you with certainty the warranty claim will not go through if there aren't old and new serial numbers recorded on the repair order. In other words, if the tech and the dealer want to get paid, they'll actually do the job.
Additionally, if they were to split the block and just replaced the bearings, that's actually WAY more work than simply replacing the short block. Since the technician would only get paid to replace the short block, I see no reason why a tech would do that much more work for less pay.
I just want to try to reassure you that not all dealers are scumbags!
So to answer your question, running your VIN through Subaru's vehicle inquiry system will show the engine's serial number.
CaptainSlowbaru is offline   Reply With Quote
Old 11-16-2019, 05:06 PM   #3
carnz-pj-410
Member#: 110994
1990 ED7
I work at a dealer and sometimes we are instructed to replace crank/rods/bearings rather than a complete shortblock on some bearing failures. It doesn't happen very often, but it does happen, and that could be a possible explanation for why you dont have a "new" block.
And to CptSlowbaru above, if you are asked to do an overhaul rather than shortblock replacement it does pay more labor to cover the block disassembly, clearance checks, etc..
carnz-pj-410 is offline   Reply With Quote
Old 11-16-2019, 10:16 PM   #4
GK1707
Member#: 373868
'04 STi
Off topic question, but based on your experience do most techs actually go thru the process of clearancing all of the pasages. Such as using a dial bore and micrometer to measure bearing clearances (or even plasti-gauging) when overhauling an engine.
Or do they just slap in new bearings and throw the block together to hit book times and get paid? I've always been curious as to what dealer techs actually do when rebuilding parts that require clearancing and measuring.
GK1707 is offline   Reply With Quote
Old 11-16-2019, 10:24 PM   #5
carnz-pj-410
Member#: 110994
1990 ED7
I can't speak for everyone, I've worked at the same shop for 12 years so I've only directly dealt with a handful of techs regularly. Every engine I've overhauled has been measured using mics and bore gauges, I've never been a fan of plastigauge personally.
I've seen techs replace with all new parts and never measure, and I've seen a few techs use plastigauge to check clearances, can't say if they've done it correctly though.
Old 11-17-2019, 11:39 PM   #6
riggy30
Member#: 158321
2010 WRX STI
Yeah, pretty much. I haven't really drove the car at all since it got repaired a few years back- it's been sitting in my garage collecting dust. Well, I'm finally starting my build and noticed when I pulled the motor that it looked very, very dirty and definitely didn't look like a new short block. The repair invoice stated that the block was replaced but I'm 95% sure it's the original block, which had 50k on it.
Old 11-17-2019, 11:45 PM   #7
riggy30
Member#: 158321
2010 WRX STI
The work invoice says "replaced short block" and nothing else regarding crank, rods or bearings.
"Installed 10103AC050 : SHORT BLOCK ENG AY"
Old 11-18-2019, 08:01 AM   #8
carnz-pj-410
Member#: 110994
1990 ED7
Well then you're good
Old 11-18-2019, 09:41 AM   #9
bizzlezx10r
Member#: 439586
2015 WRX
ISM
I don't think he is good though because if he has a filthy looking motor then it sounds like they didn't actually replace it despite what the invoice says.
bizzlezx10r is offline   Reply With Quote
Old 11-18-2019, 11:59 AM   #10
carnz-pj-410
Member#: 110994
1990 ED7
Lol **** it, i was just giving input for possible repair options we have to take, if he's that worried about it not being actually replaced then it's his job to take it up with them
Old 11-18-2019, 02:37 PM   #11
Jack
Add Lightness
Member#: 13699
not my president
(From General)
How dirty is it? We had the short block replaced in a Crosstrek and it looks very, very shiny and new.
Old 11-22-2019, 12:38 AM   #12
riggy30
Member#: 158321
2010 WRX STI
It looks like a block with 50k on it. Also, there was a white substance (salt/oxidation) accumulation on the top of the block under the water coolant crossover that I remember seeing and it's still there. Wish I inspected the engine as soon as I got the car back and looked over the work invoice but i used to have 3 jobs, worked 70 hour weeks and simply didn't have the time. Car just sat and was only driven once every few weeks.
Old 11-22-2019, 12:40 AM   #13
riggy30
Member#: 158321
2010 WRX STI
Block is dirty as **** and I don't think they actually replaced it... That's the issue.
Old 11-22-2019, 10:38 AM   #14
Jedi03
Member#: 491095
2009 STi Blue
is that number the block serial number or the part number? a warranty will require a return attached to the order for the tech to get paid and reimbursement of parts to the dealer...
Jedi03 is offline   Reply With Quote
Old 11-22-2019, 03:38 PM   #15
Supraru
Member#: 23313
99' 2.5Rs
black
I have a feeling you're looking at the heads and not the block. They don't replace the heads just the short block.....
Supraru is offline   Reply With Quote
Old 11-22-2019, 03:40 PM   #16
Supraru
Member#: 23313
99' 2.5Rs
black
When has this been? We've never done that and we're a very large dealership. Always a short block especially on a spun bearing. We've done pistons when the fb first came out with oil consumption issues until they fixed the problem. Now it's all short blocks.
Old 11-22-2019, 07:55 PM   #17
willowlee
Member#: 358533
2013 sti sedan
wrb
Because some dealership are shady as ****, thats why. Off topic, but my friend once took his car in for an oil change and tire rotation at a toyota dealership and they never did the tire rotation. But on the receipt invoice it clearly said tire rotated. He knew his tires were not rotated because he marked the wheels before going in. After calling them out on it, the mechanic guy said that the tires did not need to be rotated. But if it did not needed to be rotated, then let the customer know that it has not been rotated. I doubt they even bother changing his oil either, but he just drove the car home and never return back to that dealership again.
Long story short.... There ARE shady dealerships out there.....
willowlee is offline   Reply With Quote
Old 11-22-2019, 08:02 PM   #18
Supraru
Member#: 23313
99' 2.5Rs
black
Cool story?
Old 11-23-2019, 01:22 PM   #19
willowlee
Member#: 358533
2013 sti sedan
wrb
Cool story?
On the bright side, there are alot of good dealers out there. Only a handful that are bad.
Old 11-23-2019, 02:14 PM   #20
Supraru
Member#: 23313
99' 2.5Rs
black
Awesome! I'm glad you were able to share you story with everyone. Now they know. You just saved everyone from all that headache.
Old 11-23-2019, 02:37 PM   #21
carnz-pj-410
Member#: 110994
1990 ED7
our former DPSM would always have us overhaul rather than replace, he has since been replaced and it's been all short blocks, but from 2013-2017 we had to overhaul many blocks
Old 11-23-2019, 02:57 PM   #22
Supraru
Member#: 23313
99' 2.5Rs
black
That's interesting. We did pistons in the infamous piston slap cars and rings in the newer oil consumption cars until they figured everything out. 3 of our guys went to tech line and all but said to many people had no clue how to put piston rings in and jacked it all up forcing a short block to go in anyway.
Old 11-25-2019, 02:02 AM   #23
riggy30
Member#: 158321
2010 WRX STI
I know what I'm looking at and I never said anything about the heads. Block is almost completely disassembled at this point. Serial numbers are on the top of the block-halves where the trans/bell-housing attaches.
