11-28-2016, 08:45 PM | #1 |
Member#: 230730
E. Canada
Vehicle:05 FXT 18GXTR black |
New fp blue htz
Somebody have this ?
68hta/71hta... Now 73htz ? Flow 57lbs, green htz is 61lbs/min I want to replace my 18g xtr... 2.5 build engine and full bolt-on on 94. I want something near 375 whp on a mustang, im about 345whp right now. Htz blue or green for 769$ or 1.5xtr for 1500$ Help please! Thanks |
11-28-2016, 08:50 PM | #2 |
Member#: 239335
W. Canada
Vehicle:2011 WRX WRB |
Get the Green so you don't run the car on the ragged edge to hit the power you want.
11-30-2016, 09:53 PM | #3 |
Member#: 452971
Vehicle:2008 STi DGM |
The Blue HTZ, to me, looks a lot like a journal bearing GTX3071R equivalent. The 'new' FP54 turbine they advertise is roughly the size of the standard GT30R turbine and while the Blue's compressor wheel is 73mm, it looks to be rated (in lb/min) roughly the same as Garrett's 71mm GTX wheel. I'd expect somewhere around 350+ whp on a Mustang dyno on pump gas. Their website shows a 2.1 making ~355 on pump and 408 on E85, Mustang dyno.
That said, for the numbers you want, go Green HTZ. Unless you are convinced you absolutely 'need' a ball bearing turbo, skip the Blouch. I've never been all that impressed with their performance to cost ratio. I'm planning on running either the Green HTZ or Blue on my '08 STi. I've leaning towards the Blue as I'm a fan of the GTX3071R as is and it looks like it will spool better than the Green HTZ without making a whole lot less power. That said, I've seen 440whp on a Dynojet out of a Green HTZ on 91 octane, which would be ~387whp on a Mustang. If you can deal with full spool around 4k, then you cannot go wrong with the newest Green. |
12-01-2016, 01:35 AM | #4 | |
Member#: 230730
E. Canada
01-30-2017, 08:24 PM | #5 | |
Member#: 451168
thanks |
02-10-2017, 12:30 PM | #6 |
Member#: 453767
E. Canada
Vehicle:2011 STI Hatch Blue/Purple |
FP Blue will be installed in March 2017
Hi guys i am here in Toronto and I got a FP Blue and i will be installing it in March
Neetronics will do the job for me and Tune also My Goal is 94 Oct 340 to 350 WHP with a good spool, i will post my results here Wish me luck |
02-11-2017, 02:53 PM | #7 | |
Member#: 230730
E. Canada
18g xtr is a 43lbs/min vs blue 57lb/min |
03-16-2017, 08:57 PM | #8 |
Member#: 453767
E. Canada
Up date on my Dyno
March 16th 2017 List of mods injectors 1000cc Fuel pump Headers Downpipe Intake Turbo out let TGV Delete Turbo FP Blue 19 PSI 320 WHP 351 WTQ I don't have a Exhaust, just a cut of valve and this is the reason i did not get abou 330 to 340 WHP on the top end , but i can tell one thing,my car drives amazing and is almost no turbo leg i love it, there is about 40 to 55 WHP between 4000 RPM all the way to 6700 RPM i could not be more happy Last edited by stivf48; 03-19-2017 at 12:38 PM. Reason: forgot a mod |
03-16-2017, 09:16 PM | #9 | |
Member#: 453767
E. Canada
12-02-2016, 06:52 PM | #10 |
Member#: 452971
No problem.
01-30-2017, 07:46 PM | #11 |
Member#: 94748
South East
Has anyone else run the blue yet?
Some promising new info posted at FP. "JR Tuned Review of the Blue including dyno sheet above. Our Project Toilet Bowl (2000 Outback sports) hit the dyno today to do some testing on the new Forced Performance TurbochargersBlue stock location bolt on turbo. We have had it for weeks to test at the track, but the weather has really ****ed that up for us. So we decided to thrown it on the dyno and see what kinda of numbers it could produce. Full boost by 3800rpm and able to hold 27-28psi to redline(7200) This thing spools like the HTA71 but makes power like a HTZ Green Pumpgas 93 = 430whp / 445tq E85 = 524whp / 527tq" Last edited by scottD; 01-30-2017 at 08:37 PM. |
02-10-2017, 12:56 PM | #12 |
Member#: 448862
Vehicle:2011 WRX Dark Gray Metalic |
I went with the Green and am pulling 370hp and 370ft-lbs on 91 and 420/411 on E60 winter blend. Im limited by injectors, MAF and my transmission right now. I'm only at 18psi of boost right now on both fuels. Im making full boost by 4300 rpm.
02-11-2017, 02:54 PM | #13 |
Member#: 230730
E. Canada
Which injecteur, maf size ,5speed ?and dyno jet ?
02-11-2017, 08:14 PM | #14 |
Member#: 448862
02-13-2017, 09:46 AM | #15 |
Member#: 244028
South East
Vehicle:2011 base WRX SWP |
I wonder how that will compare to the don 1.5xtr.
02-13-2017, 10:13 AM | #16 |
Member#: 230730
E. Canada
03-17-2017, 07:22 AM | #17 |
Member#: 230730
E. Canada
19 psi but on 91 or 94 ?
40 whp gain but no wtq ? You need à catback !!! |
03-19-2017, 01:42 AM | #18 |
Member#: 453767
E. Canada
03-22-2017, 04:48 PM | #19 |
Member#: 418229
03-22-2017, 06:06 PM | #20 | |
Member#: 453767
E. Canada
Now is 240whp with the new hardware that Neetronics got for the Dynojet |
03-19-2017, 09:52 AM | #21 |
Member#: 453767
E. Canada
Actually is very easy to make torque with a cut off valve where I have mine, at 17psi was making 375WTQ, I asked to lower the torque, I don't want to blowup my block yet lol Andy my tuner told me this turbo will easy make over 400WQT
03-19-2017, 10:48 AM | #22 |
Member#: 230730
E. Canada
Cool, because you ask to your tuner. But the power could be there !
03-17-2017, 07:49 AM | #23 |
Member#: 280693
Vehicle:15' Launch Edition WRB on Gold BBS |
yea something is off man, my 71hta (not the new HTZ center section from xona) made with your same mods, 368hp on 93 and 416 on ethanol. Also I ran out of injector on e85, Nate said I should have been able to hit 425 reliably on their mustang dyno. Also I have ej255 heads on my LGT not the better flowing 257 heads like the sti
03-17-2017, 10:54 AM | #24 | |
Member#: 230730
E. Canada
03-22-2017, 09:40 PM | #25 | |
Member#: 453767
E. Canada
What city did you tune? Elevation is a big factor I asked my tuner and he told me if I make 368Whp on his dyno my spark plugs would come out from my exhaust Last edited by stivf48; 03-22-2017 at 09:59 PM. |
