09-07-2013, 01:07 PM | #1 |
Member#: 292520
Vehicle:13 WRX STI limited WRB |
2013 sti Maintenance question
Im doing and oil change/tire rotation, im picking up oem 5w-30 and an oem filter. But my question is when i rotate my tires do they cross or front to back? They are dunlop sp sport 600s
09-07-2013, 01:13 PM | #2 |
Member#: 97135
09-07-2013, 01:57 PM | #3 |
Member#: 272675
Vehicle:2011 WRX 2002 Corvette Z06 |
09-07-2013, 02:00 PM | #4 |
Member#: 346557
Vehicle:2013 WRX DGM |
They are asymmetrical so they have an outside and an inside. I typically do the first rotation cross, and front to back on the second rotation and repeat the pattern. It ensures the tire ends up on all the corners of the car at some point, and it gets the most even wear and usually the longest tire life.
09-07-2013, 02:03 PM | #5 | |
Member#: 272675
09-07-2013, 02:16 PM | #6 |
Member#: 153088
Vehicle:2005 Baja Turbo 95&96 Sambar 06 Forester |
Email Dunlop and find out what they recommend for that tire/car.
09-07-2013, 02:19 PM | #7 |
Member#: 123843
Vehicle:2016 STI LTD CWP Let LED's light your way! |
09-07-2013, 02:55 PM | #8 |
Member#: 366240
SCIC
Vehicle:2013 Impreza WRX DGM |
I just go with what's in our manual (11-29) which is the same as the x-pattern on that Tirerack page for non directional tires.
If the tire is directional there's usually an arrow with the word "rotation" nearby on the sidewall in which case you just do front to back and back to front but keep the tires on the same side of the car. This method is also in our manual, same page as above. |
09-07-2013, 07:36 PM | #9 |
Member#: 292520
Ok and do you guys recomend t6 5w40? i cannot find 5w30 online
09-07-2013, 09:04 PM | #10 |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
NASIOC's favorite oil is Rotella T6 5w40.
09-07-2013, 09:08 PM | #11 |
Member#: 341903
Vehicle:2016 STi Hyperblue |
Yea and even after 26752578 threads about it I still dont use it. Maybe I am just missing something.
OP as others stated if you have a "rotation" arrow on the tires they go front to back, otherwise use the X cross method for rotating tires |
