Welcome to the North American Subaru Impreza Owners Club Friday December 14, 2018
Old 10-08-2015, 04:25 PM   #2951
TheRedStig
Member#: 339781
2002 WRX Sedan
Originally Posted by no694terry View Post
peak torque timing is similar for gas and e85, you just cant get to it on gas before knocking. I run about 18-21 at peak torque tapering up to 30ish by redline. So ya 10 low for E85 but its only at 10 becasue your knock sensor is picking up noise, sounds like your tuned for 16/17 which is a safe ideal for a 2.5L.
I dont know what area your in but its also pobbible that your getting into a lower class "E85" and tuned for 85% ethanol, if thats the case, if your pumping 70% ethanol and tuned for 85% your may be seeing noise from that too
Really great info man. I appreciate it. I'm actually a 2.0. Going to go ask around and see what's being pumped out here. The search continues but with some better info. Thanks
TheRedStig is offline   Reply With Quote
Old 10-08-2015, 04:45 PM   #2952
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
I asked about 2.0's a few months ago on E85, not too much info. I'm 2.2 so figured for tuning it was closer to a 2.0 than a 2.5.
http://forums.nasioc.com/forums/show....php?t=2722277
I have a broken ringland right now, have for a few thousand miles now. I dont know how it happened, combo of aggresive driving, low oil and my muchroom combustion chamber maybe. But i still push it everyday while i prep my 2.5 block. Then once 2.5 block is in, im going to rebuild the 2.2 block with forged slugs and some upgraded rods
no694terry is offline   Reply With Quote
Old 10-08-2015, 07:06 PM   #2953
TheRedStig
Member#: 339781
2002 WRX Sedan
Awesome thread. I seem to see 10* before it pulls timing. Anyway I hit up the gent in that thread to pick his brain too. Going to do one good pull when i get my wideband installed this evening and have a look.
Old 10-12-2015, 10:30 AM   #2954
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
84% Ethanol giving me some **** lately in the mornings. Not ready for 45 i guess
Old 10-27-2015, 03:48 PM   #2955
desii
Member#: 349470
2013 WRX
What kind of issues do you have? does it just crank longer before firing up?
Weather here is starting to change and getting around 30s in early morning..damn
desii is offline   Reply With Quote
Old 10-27-2015, 04:52 PM   #2956
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
cranks longer. I added a little more gas. E70 fires right up even with frost the last couple mornings
Old 11-24-2015, 08:19 PM   #2957
Edgardo
Member#: 427184
2003 Impreza wrx
Wrb
Hey guys back again. Quick question according to my mods which is
Stock ej205 (56k)
750cc dw
Blouch 16gxt
3 inch catless turbo back
Walboro 255
Mishimoto tmic
Protuned on E-85 at 280whp 275wtq
Should I be pulling hard on e46 m3's?
Or is my car just quick? I feel like my car is not that fast but I thought the m3 should have given me a better run.
Sunday night I raced a 2012 v6 Camaro and felt like that kept up with me better but still took it. Thanks!!
Edgardo is offline   Reply With Quote
Old 11-25-2015, 09:13 AM   #2958
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
My E46 M3 put down 260 hp to the wheels stock 305 modded and weighted 3600 lbs. Your car has more power to weight ratio and more hp average throughout the power band.
gaby is offline   Reply With Quote
Old 11-25-2015, 09:30 AM   #2959
ShinjiML
Member#: 257231
2011 STI ShinjiTuned
Stock ej205 (56k)
750cc dw
Blouch 16gxt
Walboro 255
Mishimoto tmic
Low reading dyno? You should be putting down much more than that, ie around 330-340whp on a normal mustang.
ShinjiML is offline   Reply With Quote
Old 11-25-2015, 09:53 AM   #2960
Edgardo
Member#: 427184
2003 Impreza wrx
Wrb
I believe so.. It's a dynapack
When I went in for the tune my baseline pump tune was only showing 215whp and once the e85 tune was done it went from 215-275whp.
Thanks guys.
Old 11-25-2015, 10:03 AM   #2961
Edgardo
Member#: 427184
2003 Impreza wrx
Wrb
Also the dyno tuning was done in 4th gear only. Would that make the power show lower as compared to 3rd gear?
Thanks guys.
Old 11-25-2015, 10:22 AM   #2962
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
my 4th gear pull showed less torque and a few less hp than my 3rd gear pulls. the 750's are probably limited you. I'm at 100%DC on 850's
the two odd lines off to side were the 4th gear
Old 11-25-2015, 11:00 AM   #2963
Edgardo
Member#: 427184
2003 Impreza wrx
Wrb
Yea I know my injectors are maxed out lol. I've been wanting to swap in 1000's but I spoke to my tuner and he strongly suggests not raising the power anymore and that it's at my own discretion.
Also how much boost can I run until the stock map sensor starts reading inaccurate?
Old 11-25-2015, 11:26 AM   #2964
krisk
Member#: 333048
2013 WRX
VF52+E85+TP Road Tune
This can be fixed - talk to your tuner.
If you open source you might be able to do this yourself.
See Post #6 from Phatron -
http://forums.nasioc.com/forums/show....php?t=2175462
krisk is offline   Reply With Quote
Old 11-25-2015, 04:04 PM   #2965
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
i am my tuner, im just running a piggyback on an NA ecu so it is what it is
Old 01-19-2016, 08:06 PM   #2966
bnelson748
Member#: 432310
dont trust your tuner, look at logs.... jsut my $.02
bnelson748 is offline   Reply With Quote
Old 01-25-2016, 05:11 PM   #2967
project_high_boost
Member#: 413877
I don thave time to read through the whole thread but can someone enlighten me on how long you can leave e85 in the tank for without running the car? My tuner had mentioned no more than 3-5 days? Does it need to be started every day to keep the injectors from clogging?
project_high_boost is offline   Reply With Quote
Old 01-25-2016, 08:18 PM   #2968
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
i never had an issue, but i got an evo buddy that blows motors a lot and ends up needing injectors too from them sitting with e in them. id start it at least once a week
Old 01-25-2016, 11:27 PM   #2969
Vinnymau5
Member#: 438926
2005 Sti
You should have no issue leaving e85 in your tank for a few months at a time. I've had it in my racecar for 3 months now and plan on firing it up when I take it to the track next month with no issues.
Vinnymau5 is offline   Reply With Quote
Old 01-25-2016, 11:45 PM   #2970
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I store two cars with E85 for 5-6 months a year. I also did the same with my supercharged SHO when I had it as well. No issues in the last 4 or 5 winters.
The STi had ID1000's in for most of those winters and now has ID1300's. The SHO had ID1000's and the S2000 has OEM WRX/STi 565cc injectors in it.
yamahaSHO is offline   Reply With Quote
Old 01-26-2016, 02:15 AM   #2971
StiLimited
Member#: 121212
2007 Sti Limited
Urban Gray Metallic
I converted my 07 to e85 in 2008 and parked it in 2009. It sat with only the occasional start and run around block 2-3 times a year for 5 years with the same fuel in it. It has had no problems. Once I started driving it regularly I ran out the tank that was in there w/o incident and filled it back up. One reason I parked it was the only e85 station closed down and I have to drive an hour to get fuel so I get 50-100 gallons at a time. All that I have found is the e85 in those plastic fuel jugs will go to e90 or even e95 as the gasoline evaporates, but the ethanol stays in the jug. I did not test the fuel in the car, but it ran fine.
So if anyone is telling you "a few days" I'd recommend not taking any advice from that person regarding e85 as they are ignorant of the fuel.
StiLimited is offline   Reply With Quote
Old 02-04-2016, 04:52 PM   #2972
thedizrector
Member#: 439722
Thanks for the how to. This helps!
thedizrector is offline   Reply With Quote
Old 02-10-2016, 01:10 AM   #2973
Qbo707
Member#: 432065
Default E85 fuel FAQ
I have a good one. I am currently having to fill 55g metal drums with e85 since the nearest station is 4.5hrs away one way. 9hr trip. So I filled 110g the first time. It lasted 5 days. (Country living so town is 25miles one way.) I got 165g this time and I think will last 8-10 days. Possibly 2 weeks since I'll be using my truck a little more also. I bought the good Fill-Rite electric pump and a good nozzle like at gas station. Tanks on pallets and pump grounded. is it ok to leave pump in? The drum is used within a few days normally. But they are outdoors but out of direct sunlight. I even tarp it. Is this ok? Can anyone give me good suggestions on best ways to store? I should have my Cobb flex fuel kit installed soon so I will get ethanol readings. Currently waiting for my ethanol test kits to arrive. I'd like to make sure I don't have them absorb moisture. Other tanks are tightly sealed.
Qbo707 is offline   Reply With Quote
Old 05-16-2016, 08:44 PM   #2974
Slo.Wrx
Member#: 447089
Very helpful considering that I'll be doing E85 very shortly.
Slo.Wrx is offline   Reply With Quote
Old 05-23-2016, 07:11 PM   #2975
IVannaCupCak3
Member#: 447500
Default good to know
didn't know a lot of this!
IVannaCupCak3 is offline   Reply With Quote
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 02:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 08:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace 08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 02:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 03:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 02:32 PM
