Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-16-2013, 11:46 AM   #701
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
Shhhh! I've been eyeing the 7163 as a potential candidate for a low mount TS setup. Currently waiting to see if my letter for modifying the front bumper beam gains any traction. If so, then eventually I'll have something a little different on my car.
Currently, my goal is 400 ft/lbs of torque at 4000 rpm or before. Ideally, I'd like 400 ft/lbs of torque at 3,200 rpm while holding 400+ hp to 7,500 or more.
Money is speed, how fast do you want to go?
subydude is offline   Reply With Quote
Old 07-16-2013, 11:49 AM   #702
Funky
Member#: 11520
2005 STi (retired)
Obsidian Black
I've autocrossed my STI with the fuel light on, it doesn't starve prematurely.
Funky is offline   Reply With Quote
Old 07-16-2013, 11:54 AM   #703
Leafy
Member#: 330625
2006 WRX
The EFRs are glorious.
Any chance that you could fit it next to the tranny if you were running a 5 speed? With the exhaust coming in from the top? Would still end up needing a stockish length header, but would keep the weight down and further back. You would probably end up needing a pump for the oil and the turbo would be kind of exposed to road hazzards.
Leafy is offline   Reply With Quote
Old 07-16-2013, 11:56 AM   #704
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
Even with a modified beam there isn't a lot of room, does the GC have more room in front of the motor compared to the GD?
WRX8XB is offline   Reply With Quote
Old 07-16-2013, 12:07 PM   #705
subydude
Member#: 80649
Dusty
When I bought the 1.5xtr it was late 2010 or early 2011 and I don't think they had anything small enough (or small enough for my purposes) to fit in the stock location or I would have gone with an EFR. Now that they do, it's tempting, but I'd rather stick with what I have until I really go elbows deep into making my own setup.
I doubt a rearward mount would work, but the 5-speed is a lot smaller after the bellhousing. I've looked around back there, but nothing really jumps out at me as a good relocation point. Mostly because it defeats the purpose of shortening the length of the headers.
Actually, it has less The core support arms going to the frame rails actually have a shallower angle than the GD's meaning the radiator sits closer to the front of the engine on mine. I had to trim the fan shroud to fit both fans on the radiator.
However, I'm thinking of a 3/4 length radiator mixed with modifying the bumper beam. Those two things would allow a low mount turbo, a nice FMIC, and a rotated intake manifold to happen. You could have the turbo up high enough to not need an aux oil pump and the reduction in both hot and cold side tubing compared to most FMIC setups would be almost 10 feet.
More weight on the nose, but I'd trade the 35-40 lbs moved forward for the reduction in spool and greater power output.
Old 07-16-2013, 12:20 PM   #706
Leafy
Member#: 330625
2006 WRX
When I bought the 1.5xtr it was late 2010 or early 2011 and I don't think they had anything small enough (or small enough for my purposes) to fit in the stock location or I would have gone with an EFR. Now that they do, it's tempting, but I'd rather stick with what I have until I really go elbows deep into making my own setup..
The B1 Frame EFRs might fit there, but they still only come with T2 flanges and 3"gt v-band outlets. So you have to make a UP and DP anyways (or pay full race an absurd amount of money).
Old 07-16-2013, 12:20 PM   #707
WRX8XB
Member#: 45323
Have you been following the killer b low mount thread?
Old 07-16-2013, 12:25 PM   #708
subydude
Member#: 80649
Dusty
Yes, and I've gleaned a few ideas from it. I think his setup will be great for the GD cars, but would have fitment issues on something like mine. Plus, the cost is a bit high. I'd rather build my own (and probably spend just as much ) and have it fit the way I want it to. Not to mention I can spec my own radiator and build my own bumper beam setup.
Old 07-16-2013, 12:42 PM   #709
WRX8XB
Member#: 45323
Figured your car would need some tweaks, the thread brings up a good point about the "depth" of the EFR turbos were you thinking of running it the same orientation or mounted the other direction?
Old 07-16-2013, 12:52 PM   #710
subydude
Member#: 80649
Dusty
Space would determine orientation and final location. Changing the radiator and bumper beam/skin would open up PLENTY of room for the EFR. You'd have to figure out the intake/exhaust/charge pipe routing, but those are minor details to me
It's all hogwash if the SMAC comes back and says "NO BUMPER BEAM MODIFICATIONS FOR YOU!!". Then I'll continue on with my OE location and TMIC.
Old 07-16-2013, 01:39 PM   #711
WRX8XB
Member#: 45323
could do one of the EFR stock location turbos.
Old 07-16-2013, 03:43 PM   #712
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
That's gonna be the bitch of it...i hope you get your exemption...may have tried and failed.
Squidz is offline   Reply With Quote
Old 07-16-2013, 03:48 PM   #713
Leafy
Member#: 330625
2006 WRX
Honestly it should only cost you $100 in materials tops to make the new up pipe and another $200 to make the down pipe. If you were going to keep the stock header.
Old 07-16-2013, 03:54 PM   #714
WRX8XB
Member#: 45323
It's a tempting option.
Old 07-16-2013, 04:48 PM   #715
subydude
Member#: 80649
Dusty
And if the no bumper beam thing stays in place then I might do the EFR to get the decreased spool time.
The way I asked wasn't "can we remove it", it was "can we modify it, but keep it the same weight and mount in the same location". I figure that's still reasonable
Old 07-16-2013, 05:00 PM   #716
WRX8XB
Member#: 45323
I agree, 2 solid 2" thick "mounts" for a nice light weight bar.
Old 07-19-2013, 10:18 AM   #717
*Ulimited*
Member#: 139249
16.1.M No portion of the splitter may extend beyond the widest part of the front
bumper/fascia as viewed from above.
If I have the kartlon fender flares on the car can I make the splitter extend out to the widest part of the flare or do I have to keep it to the stock bumper?
*Ulimited* is offline   Reply With Quote
Old 07-19-2013, 10:42 AM   #718
subydude
Member#: 80649
Dusty
Street Mod allows you to make your own bumper covers, so assuming the Kartlon flares attach to the bumper you could say the splitter could be that wide. I probably wouldn't make it that wide myself since the gains at autox speed wouldn't be enough to offset the fact that the car is now x inches wider at the front.
Old 07-19-2013, 10:47 AM   #719
*Ulimited*
Member#: 139249
Hmm good point, My thoughts were to maximize the area of the front splitter to make it as effective as possible since we never really see too much speed, but I see your point, thx.
Old 07-19-2013, 10:50 AM   #720
Leafy
Member#: 330625
2006 WRX
I'd wait till V2 of your aero for that. I know I need more front now but my wing makes significantly more downforce than any of the typical off the shelf options.
Old 07-19-2013, 10:57 AM   #721
*Ulimited*
Member#: 139249
Ciro?
Old 07-19-2013, 11:02 AM   #722
Leafy
Member#: 330625
2006 WRX
Ciro?
No, Joint effort between Legit Products and Davis Race Engineering. And by that I mean my roommate and I engineered and fabricated it. Car certainly tends towards push with above 60ish even with a legal limit sized splitter. Thankfully its designed to be 85% of the allowable wing area so I can add kanards.
Old 07-19-2013, 11:08 AM   #723
*Ulimited*
Member#: 139249
speaking of kanards I like the look of these
Old 07-19-2013, 11:08 AM   #724
Leafy
Member#: 330625
2006 WRX
I dont think the endplates are allowed.
Old 07-19-2013, 11:55 AM   #725
subydude
Member#: 80649
Dusty
Is the wing adjustable? Twin element and all?
Canards don't do as much as you think they do.
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
