03-09-2005, 09:17 AM | #1 |
Member#: 75078
South East
Vehicle:2011 Forester 2.5X Dark Gray Metallic |
Jdm Ea82t
i have been looking at jdm EA82T motors. does anyone have any experience with these motors? any comments on their reliability or performance? i drive a 93 impreza with a naturally aspirated 1.8L and was looking for a replacement if the original ever craps out. before i try and post any questions about a possible swap, id like to hear from someone who has had experience with this kind of engine.
03-09-2005, 11:13 AM | #2 |
Member#: 54398
NWIC
Vehicle:1980 CB400 Hawk 1996 GrandCherokeeLimited |
I have a bit of experience with the EA82T
The first thing I can tell you is that it won't just bolt in to your impreza. Its a different family of motors. YOu would be better off finding an EJ20G and stuffing it in there. Either way you would need the wiring harness and ECU for whatever motor you decided to use. If you decided to go with the EA82T, you would need a trans adapter plate as well. How much HP does the EJ18 produce. The EA82T only produces 111-115 stock |
03-09-2005, 01:33 PM | #3 |
Member#: 44652
BAIC
Vehicle:16 Colorado diesel ATC Bobcat Pop-up |
Yeah, true that.
Here here,
I am also afflicted with an ej18 NA in a 96 imp. If I was going for an engine swap, I would seek out (for all the effort and expense involved) an ej20 or ej22. Seeing as how a wiring harness swap is imminent, you may as well have that ej20 in there, reliably, as it is much more at home and has a huge aftermarket and user knowledge behind it. And our little imprezas are smaller and lighter that those bugeye guys too. Here in the Reno tahoe area, ive not seen anyone have a very long shelf life with one of those type turbo subys either. I sure have passed a plenty of them with my 150k ej18 NA going up winding old highway 40. Of course, it aint cheap neither, but engne swap arent. I myself am just rolling my pennies, canning and bottling, and just waiting until i finish nursing school and get to work to create my monster, the world will then be sorry. Until then ive concentrated on the stuff I can piece together with smaller funds: suspension from cooler models, brake swap, 86-ing those 14x5.5's, and other universal stuff. Another option thats cool but maybe less reliable is the EJ18t do it yourselfer, do a search, i found some guys doing obscene things to ej18s with some seeming success, as they tout the block as pretty darn strong, and there seems to be no wiring harness mess. Underdog Arkies unite! Dylan |
03-09-2005, 01:35 PM | #4 |
Member#: 44652
BAIC
Durp!
I meant to say ej20 or ej22t.
An ej22 na, now that would be just silly.... |
03-09-2005, 04:26 PM | #5 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
you should just do an EJ series turbo swap...be it the EJ22G (legacy turbo) or a WRX of any form...
03-09-2005, 04:45 PM | #6 |
Member#: 2780
MWSOC
Vehicle:junk yards rule! Project FrankenSTien |
'96 Brighton Ed.
03-12-2005, 04:01 PM | #7 |
Member#: 44652
BAIC
10-10 on the side, snowman
ah yep! my car is now masturbating to pictures of your car. consider the links saved. thanks frankenshteen
04-14-2005, 09:32 PM | #8 | |
Member#: 13910
NESIC
Vehicle:2005 Legacy GT blue |
Qq
110HP 110FT. LB TQ |
04-15-2005, 10:49 AM | #9 | |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
As for the topic at hand. Take a look at SubaChad's build in the AFI forum. He started out with boosting an EJ18, and then worked up to an EJ20 block with EJ22E heads. We did a similar build in Bugman's car recently. If you go with an E-manage, the wiring is much simpler than a full blown engine swap, and over time you can put in better and stronger engines with more boost. Far less limiting than say an EJ22T swap, which has an upper limit of around 230Chp, even with the additon of a custom intercooler... |
Similar Threads | ||||
ej18 turbo pic | scubydrew | Normally Aspirated with bolt-on Forced Induction Powertrain | 66 | 07-31-2012 11:24 AM |
RE:USDM EJ18 swap to EJ22 JDM or JDM EJ18 | cbrkp | Subaru Conversions | 2 | 12-06-2006 03:07 PM |
JDM EJ18 Swap... problems... | Unsung Boxer | Subaru Conversions | 2 | 04-02-2004 08:44 PM |
My EJ18 turbo project | scoobyimprza | Subaru Conversions | 31 | 08-16-2003 08:57 AM |
My EJ18 turbo project | scoobyimprza | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 08-03-2003 10:33 PM |
