Welcome to the North American Subaru Impreza Owners Club Monday November 11, 2019
Closed Thread
Old 02-20-2002, 10:07 PM   #176
sailingwagon
Member#: 15010
2002 wrx wagon
Default passport 8500 installation
the escort passport 8500 radar detector has an optional permanent wire installation kit, and the wire has a remote mute and LED warning unit.
this remote piece fits perfectly in the unused switch to the right of the cruise control and foglight switches. the wires running into the piece route through the back and hold the piece in place. the other bonus of this installation is that the fuse box is right there, so finding a grounding point and a power wire to tap into are no problem.
i know the escort is no valentine, but with a sailboat in tow, i don't have the extra $.
sailingwagon is offline
Old 02-20-2002, 10:13 PM   #177
GreyBeard
Member#: 13870
2002 WRXSportWagon
Platinum Silver
What tow receiver did you use for your hitch ? I thought only the sedan could be fitted....
GreyBeard is offline
Old 02-21-2002, 10:03 PM   #178
james_stocks
Member#: 15403
2002 WRX Wagon
Here's my Subie Wagon, only a week old!
Jim
james_stocks is offline
Old 02-22-2002, 12:54 AM   #179
sailingwagon
Member#: 15010
2002 wrx wagon
Default tow hitch
i got the hitch from the dealer. it fits perfect, even with the dual exhaust tips. other than the wiring, the installation was easy. you do have to trim the bottom 1/4 inch of the plastic bumper, and i did a crappy job, but who cares? you've got a sportwagon with a tow hitch. unless you really look, you can't see the jagged edge i made.
the hitch comes with a wiring adapter box that easily plugs into the base impreza wire harness. but not so for the wrx. you need to tap into 5 of the wires under the right rear storage compartment, and run a dedicated power wire from the battery. this prevents drain on the electrical system. i paid and watched a hitch installer do the wiring. it was pretty easy. i installed the hitch.
Old 02-22-2002, 02:54 AM   #180
WagonRX
Member#: 7480
WRB WRX 5 Door
VS2 12.9 @105 MPH-4EAT
Here's my entry
WagonRX is offline
Old 02-22-2002, 03:35 AM   #181
amolaver
Member#: 13301
2002 WRX Wagon
Bashed in rear-end Silver
Thumbs up nice wheels wagonrx
what are they?
no pics yet of silver baby - but i guess that's just as well as some ricer changed lanes weaving in and out of traffic at 75mph and clipped my rear bumper. by the time i got it straightened out (and removed the seat from my sphincter), the d*ck had bailed off the exit we were going by.
morrete's and seperate HID's for hi and lo on the way oem painted rockers, and a bunch of whiteline parts as well!
should have whiteline parts this weekend (rear sway, hd mounts, links, front/rear strut bar), morrete's and HIDs a few weeks out. gotta love a GB for HID's @ 335/pair!
since i'm getting the bumper repainted, i'm going to paint the morrete's to match, and pics will follow. too bad that's probably a month away
ahm:
amolaver is offline
Old 02-22-2002, 11:56 AM   #182
nixima
Member#: 15654
2002 WRX wagon
Default trailer hitch
I got my Draw-Tite hitch for the WRX wagon from
http://www.hitch-web.com/vhitch.asp?...L1&bumper=None
No cutting of the bumper was needed. The install was very easy once I stuck the hitch in the vice and bent one of the side brackets to fit I also got the wiring from the site but I haven't wired it up yet, I figured I'd wait and do the stereo at the same time since I have to run a lead from the battery. The hitch hides nicely under the bumper and can barely be noticed. The stock muffler does not rub either but an aftermarket muffler might rub on the hitch without dinking around with the hangers. The hitch is the only way to go to haul bikes.
nixima is offline
Old 02-22-2002, 12:40 PM   #183
mlambert
Member#: 13831
Can we get the part # for the carbon fiber rear tower bar?
I love this thread
mlambert is offline
Old 02-22-2002, 12:54 PM   #184
darmom
Member#: 15205
2002 WRX SuperWagon
Hyper-Mega-Ultra-Silver
I too just put a hitch on my WRX wagon. I got it at The Sports Rack (www.gearonthego.com) for about $100. It's made by DrawTite, and fit without ANY modification. There is a little sheet of metal that hangs behind the gas tank (heat shield or something perhaps?) that got in the way, but as I tightened the hitch down, it bent into place nicely. I love the fact that this hitch is almost invisible. Another installation note: I had to pop off the rubber exhaust hanger on the right (passenger) side of the muffler in order to squeeze the hitch into place - the directions only have you remove the one on the left. NO vice-bending or bumper cutting required. This hitch fit perfectly.
darmom is offline
Old 02-22-2002, 02:28 PM   #185
darmom
Member#: 15205
2002 WRX SuperWagon
Originally posted by WagonRX
Here's my entry
that's a sweet one... what wheels/springs are you running? they look like 18s...
darmom is offline
Old 02-22-2002, 11:28 PM   #186
Einherjar
Member#: 15582
2002 STi Wagon
Full STi swap
Default Check out this wagon!!!!!
Here you go
Einherjar is offline
Old 02-23-2002, 01:45 AM   #187
WagonRX
Member#: 7480
WRB WRX 5 Door
amolaver and darmom, (sounds like a sit-com)
The wheels are 18 X 7.5 Konig Tantrums. I have Whiteline springs from Brett @ Renickmotorsports. I think he's got a special on them now in the classifieds.
WagonRX is offline
Old 02-23-2002, 04:48 AM   #188
H8YNERS
Member#: 4995
2002 WRX wagon
WagonRX:
Do you get any rubbing w/the 18" Tantrums?
Stephen
H8YNERS is offline
Old 02-23-2002, 12:18 PM   #189
WagonRX
Member#: 7480
WRB WRX 5 Door
H8YNERS,
The wheels are 45mm offset so they would just touch when I hit a big bump. I had to roll the inner rear fender well slightly to allow enough clearance. I found out the hard way. Make sure to have at least 48mm offset on a wagon.
WagonRX is offline
Old 02-24-2002, 07:39 PM   #190
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Talking Thule Bike Rack
Here's a pic of my wagon with the fork mount bike rack.
Had to hack saw 7 inches off the tray
KwanDDS is offline
Old 02-24-2002, 07:41 PM   #191
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
this is why I had to cut it
KwanDDS is offline
Old 02-24-2002, 07:42 PM   #192
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
last picture
KwanDDS is offline
Old 02-25-2002, 12:15 AM   #193
WagonRX
Member#: 7480
WRB WRX 5 Door
Why couldn't you just move the tray foward ?
WagonRX is offline
Old 02-25-2002, 08:06 AM   #194
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Thats because the front edge of the tray clips on to the load bar. And the load bar sits as far forward already.
KwanDDS is offline
Old 02-26-2002, 09:53 PM   #195
sailingwagon
Member#: 15010
2002 wrx wagon
Default hitch choice
the draw-tite kit that nixima found is $50 more than the oem kit. i'm sure that any hitch that fits is sufficient. the $100 hitch that darmom found does not include the wiring adapter, so it would end up costing the same as the oem kit.
if you are just hanging a bike rack from the hitch, you don't need the wiring, so you can save $50 by going where darmom went.
i got the oem kit when i bought the car, but the dealer would not install it.
Old 02-27-2002, 01:55 AM   #196
gtcrispy
Member#: 3285
2013 Legacy Sport
Smile My stranded wagon
Here's my wagon.
gtcrispy is offline
Old 02-27-2002, 02:23 AM   #197
MGXsport
Member#: 4048
2013 Outback
Nice wagon in the snow.
Was this when it snowed about a month ago?
Chris
MGXsport is offline
Old 02-27-2002, 10:27 AM   #198
gtcrispy
Member#: 3285
2013 Legacy Sport
Yep, that was when we got a few little dumpings of snow. Drove it a little in the snow and had some fun but clearly the tires weren't made for turning or braking in the snow as I found out.
gtcrispy is offline
Old 02-27-2002, 12:56 PM   #199
GLOATLIP
Member#: 8515
2002 wrx wagon
aspen white
Great thread! more wagons!
Wagon sound system pix, anyone?
GLOATLIP is offline
Old 02-27-2002, 01:20 PM   #200
crowbar
Member#: 14262
The key is to hit
really hard, with the bat
heres a picture of when i got my mom's legacy wagon high-centered in snow, because i am an idiot.
crowbar is offline
Closed Thread
Calling All Wagons wagonmasta General Community 133 07-10-2014 07:13 PM
Calling all wagons -whos running 18's quickgtp Tire & Wheel 19 04-01-2013 02:23 PM
calling all wagons with coilovers wagonmasta Brakes, Steering & Suspension 23 01-04-2007 08:41 PM
calling all wagons subineer Brakes, Steering & Suspension 11 09-28-2002 02:23 AM
