Welcome to the North American Subaru Impreza Owners Club Monday February 24, 2020
Old 06-24-2008, 10:23 PM   #1
Ben v5
Member#: 130491
Default 07 STi rear subframe and front crossmember into a GC - Help
l'm installing a 2006/2007 sti front crossmember, rack, alloy arms etc and rear subframe/diff cradle into my v5 sti
what rear lateral links would l use to match the increased track at the front?
(currently have GC8 STi pink lateral links (405mm hole to hole for each link)
and are there any other items besides the front exhaust hanger and unijoint on the rack that l will need to change to get everything working?
Thanks
Ben v5 is offline   Reply With Quote
Old 06-26-2008, 10:09 PM   #2
Ben v5
Member#: 130491
bump anyone know?
Old 06-26-2008, 11:32 PM   #3
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
i think you are on the right track
are you using the 06/7 hubs as well?
Hurley 2.5 WRS is offline   Reply With Quote
Old 06-27-2008, 12:55 AM   #4
Ben v5
Member#: 130491
yep using the 06/07 sti hubs + axles
Here is the mod list for drivetrain/suspension
Drivetrain:
2006 STi Spec C Type RA DCCD 6 Speed (41:59, hellical lsd, sti short throw gearing, close gear ratio box)
2006 STi Spec C Type RA R180 plated rear diff (3.54)
2006 STi Spec C Type RA 114.3 PCD Hubs and axles
2006 STi Spec C Type RA STi Rims - 17x8 114.3pcd with RE55's
2007 STi Rear Subframe/Diff cradle
2007 STi Front Crossmember
2007 STi Steering Rack
2007 STi Alloy control arms
Spec C H17 (2007) Brembo Fronts + pads and 114.3pcd discs
Spiider DCCDPro “Deluxe” (Auto/Manual mode, OEM switch + thumbwheel, Factory DCCD dash display)
Suspension:
Cusco Zero 2 R's for 05+ STi
DMS GC8 Front Adjustable Tophats
Cusco Rear adjustable Tophats
GC8 STi Pink Laterial Link Set (full pillow, rose joints)
STi Pink Trailing arms
STi Pink H/D swaybar mounts (spherical bearing)
Whiteline Anti Lift Kit (Race)
Whiteline underbody "H" brace
Whiteline H/D Front adjustable 24m swaybar
Whiteline Front Swaybar link kit (Spherical rod end)
Whiteline H/D Rear adjustable 27mm race swaybar
Whiteline H/D Rear 24mm mounts
Whiteline H/D gearbox mounts (race)
Whiteline H/D steering rack mounts
Old 06-27-2008, 01:33 AM   #5
RA Limited
Member#: 171249
2009 Chaco Z1 flip
Black/Blue
a friend of mine has the rear lateral links off a GDB on his GC8, they appear to have widened the track a little bit.
RA Limited is offline   Reply With Quote
Old 06-27-2008, 01:54 AM   #6
Ben v5
Member#: 130491
l'm probably gonna sell the STi pinks and replace them with whiteline or cusco adjustable lateral links later down the track
l'm just wondering if the pink gc8 lateral links would be ok with the 07 sti control arms
Old 06-27-2008, 10:57 AM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
The GD body style definitely has a wider track than the GC, but I don't remember what the difference in lateral link length (say that three times fast! ) is. I want to say the newer ones are 420mm vice 405mm. I think it's something in that ballpark.
Pat Olsen
Old 06-27-2008, 12:03 PM   #8
kingsubi
Member#: 19239
2011 WRX
Pat Olsen
I could go and measure the track car but I don't recall it being that much. I don't have camber plates in the rear and with the GD pink laterals I have -3.5deg. My guess is 415mm.
kingsubi is offline   Reply With Quote
Old 06-28-2008, 02:33 AM   #9
Ben v5
Member#: 130491
well the stock version 5 sti links are 400mm
the gc8 pink lateral link set is 405mm hole to hole
l thing the gdb arms are about 415mm, l actually have a set of 06 sti alloy lateral links, l'll measure them up tonight
Old 06-28-2008, 05:33 AM   #10
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
i guess it all depends on if you want the wider rear track, as there are ways to correct the camber
everything else you listed looks great, its just the rear lateral link choice and your steering rack joint that need to be dealt with
Old 06-30-2008, 10:03 PM   #11
Ben v5
Member#: 130491
cool thanks for the info, l'll probably go for whiteline or cusco adjustable GDB 02-04 lateral links to match the track at the front
what about my 05+ GDB suspension, l've been doing abit of searching and read that GDB ride height might not work with a GC8 chassis
04-07 sti spring perch and front dust covers. JimmEh Private 'Wanted' Classifieds 0 05-21-2010 01:11 AM
fs/fl 07 sti rear diff and all 4 axles twonb1 Drivetrain 7 11-26-2008 04:27 PM
F/S 07 Sti rear seat and 07 sti doorcards vLncecast Tri-State Area Private Classifieds 11 02-06-2008 11:47 PM
Feeler: WTB '06 STI rear suspension and front brakes renob123 NWIC Private Classifieds 0 12-05-2007 02:13 AM
FS VA stock sti rear endlinks and front sway bar sti robot Suspension/Brakes/Handling 0 01-24-2007 10:16 AM
