Welcome to the North American Subaru Impreza Owners Club Sunday November 17, 2019
Old 01-25-2012, 04:30 PM   #126
jeff618
Member#: 233963
jeff618 is offline   Reply With Quote
Old 01-25-2012, 05:42 PM   #127
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
rain x lats all day i rock slightly smaller wipers than factory spec out love them
Hedbergsuby07 is offline   Reply With Quote
Old 01-25-2012, 06:45 PM   #128
LoneDubR
Member#: 253337
Bosch Icons and Rain-x washer fluid. Perfect combo.
LoneDubR is offline   Reply With Quote
Old 01-25-2012, 06:49 PM   #129
bigfil
Member#: 143577
2006 Forester
Steel Grey Metallic
Did the Bosch Icons when they were on sale.
Have some generic ones on there right now.
Will probably switch to the piaas as they look to be the best atm.
bigfil is offline   Reply With Quote
Old 01-26-2012, 04:44 PM   #130
etownshooter2005
Member#: 202830
2004 impreza wrx
wrb
i only use rain-x products. Lattidue wippers rain x treatment and rain x washer fluid. dont even have to use the wippers a lot with the rain x but makes a great set up.
etownshooter2005 is offline   Reply With Quote
Old 01-28-2012, 03:28 PM   #131
XanRules
Member#: 157348
180+ IQ Genius
Mindset Lifestyle
Originally Posted by hella_sti View Post
I just returned my michelin wipers yesterday, they didn't even last me 4 months, pure garbage. They were obviously ok when new but they started to smear quickly.
Yep. My first set started to smear and streak after a few hours. Called Michelin, they sent me a new set... that was two months ago. They're already garbage.
XanRules is offline   Reply With Quote
Old 01-28-2012, 05:19 PM   #132
Subbiespeed
Member#: 276493
2005 STI
i think the icons and latitude are personal the best u can buy and i use rain x for everything else
Subbiespeed is offline   Reply With Quote
Old 01-28-2012, 08:33 PM   #133
jesseber
Member#: 293509
2004 WRX STI
Rain-X Latitudes. IT'S LIKE RAIN NEVER HAPPENED lol.
jesseber is offline   Reply With Quote
Old 01-29-2012, 09:31 AM   #134
Syrius78
Member#: 267996
2011 Wrx
Rallye blue
I use piaa si tech silicon wiper blade from tire rack
Impressive. I haven't use the windshield fluid since.
Syrius78 is offline   Reply With Quote
Old 01-29-2012, 02:23 PM   #135
cinnaman
Member#: 298063
2005 legacy 2.5i
DIP
Jus bought a pair of trico's from Canadian tire for 40 $. Working a lot better than my 3 year old bosch's
cinnaman is offline   Reply With Quote
Old 01-29-2012, 02:35 PM   #136
Subbiespeed
Member#: 276493
2005 STI
haha give us a review a month from now on how well those r treating ya
Old 01-30-2012, 09:48 AM   #137
jeff618
Member#: 233963
Have a Nice Day?
I have to say that I'm shocked at all the Rain-X comments... I and several people that I know have had terrible luck with them. A) They are way too stiff for many windshields and the contact is poor due to this. #2) The adapters are very cheesy and HUGE...so not only do they look like crap, they either bind (creating further contact issues) or are really loose (creating noise) depending on who you talk to. BOSCH on the other hand are pretty much good from what I hear...they're just expensive. I switched to neoforms a couple of years ago from bosch and I'd say they're slightly better than the bosch at a lower price than both the rainx and bosch. I've have great luck with them.
Old 01-31-2012, 09:52 PM   #138
Scorpion
Member#: 67956
2007 WRX Wagon
I have the bosch icons and had to pull the blade out of the drivers side wiper and flip it over to get it to wipe without smearing. It looked like blade was stuck on its side so it would only wipe cleanly in one direction. I've had them a little over a year and a half now, we'll see how much longer they last. Anyone know if refills are available for the icons?
Scorpion is offline   Reply With Quote
Old 01-31-2012, 11:39 PM   #139
ericrally
Member#: 293436
PIAA as used by Subarus WRC cars back in the day
ericrally is offline   Reply With Quote
Old 02-01-2012, 08:46 AM   #140
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
No, as they are one integral piece.
jonklein611 is offline   Reply With Quote
Old 02-01-2012, 09:24 AM   #141
Scorpion
Member#: 67956
2007 WRX Wagon
Really? I already pulled the wiper blade out and flipped it over so they do come out.
Old 02-01-2012, 11:16 AM   #142
jonklein611
Member#: 117776
WR Blue Pearl
I stand corrected, I assumed they were molded as one part or something stupid like that:
This is for those who have the new style flat blade Bosch wipers retrofitted to their 850/x70's. My set is around 2 1/2 years old or so, and in need of replacing just due to normal NE wear. I have been procrastinating over the $40 for a new set, but I really like the wipers. The other day I saw a write-up on one of these boards about taking the old rubber out of the Icon holder. Unfortunately I can't now find where I saw that, so can't give appropriate thanks. However, I did pull mine last night and found that it took maybe 10 minutes to disassemble the old blades and insert new, cheap, inserts. The only trick is pulling the end cap off the Icon holder. You only need to remove the cap at the outer end, the end that points to the passenger side. It slips off, but has a small detent that is loosened by inserting a thin blade under the cap and prying - cap is pretty flexible, not fragile. Once the cap is off, there is a small metal hook that is easily seen, and just needs to be lifted up slightly so it does not push down into the rubber insert. Then the rubber insert just slides out. Once it is out, it looks exactly like any other traditional blade insert. I bought a pair of Trico inserts, N21R (narrow, 21 inches, refills) for $5.95 at AutoZone. AZ doesn't keep the refills out in front, but they did have some in the back parts department. The new refills come with a thin holder along the top edge. This holder has to be removed from the new inserts ( you can mess it up since it is thrown away). Then you are holding a perfect match to the rubber blade you pulled out of the Icon, and it just slides back into the Icon holder. Push the hook down flat (it preses into the rubber through a small hole, to hold it in position), snap the end cap back on and done. You need the narrow style inserts, not the wide ones, to fit the narrow opening in the holder.
Not correct size for our cars, but i guess you can do it. cool!
Old 02-01-2012, 02:19 PM   #143
HinshawWRX
Medium Frank
Member#: 140114
2013 Audi
A6 3.0T
RainX Latitudes. Never had a single complaint with RainX wipers be it Latitudes or the standard blade.
Old 02-01-2012, 09:27 PM   #144
SHDemps
Member#: 299025
2007 Impreza 2.5i
Urban Grey Metallic
I use Trico, I am very happy with them, and they tend to cost a little less than Bosch. They dont streak at all, and they handle icy conditions very well, too.
SHDemps is offline   Reply With Quote
Old 02-01-2012, 11:34 PM   #145
STiSomeday
Member#: 265430
2005 OBP WRX STi
IG/FB - seriousblacksti
Valeo 900 series. Almost picked up some Icons while they were on sale at the Advance I work at but I got the Valeos on amazon for ~$23 for the pair.
STiSomeday is offline   Reply With Quote
Old 02-06-2012, 10:42 AM   #146
jeff618
Member#: 233963
Its interesting that what works for others did not work for me. Latitudes were way too stiff and faught with my arm pressure resulting in streaking and missed spots. Then tried icons and I'll say that they worked good. Then I switched from icons to trico neoforms and I think they're slightly better at a lower price. Very quiet and very smooth. No contact issues and a few bucks less than icons and latitudes.
Old 02-07-2012, 09:54 PM   #147
fengrr
Member#: 169160
08 STI
The buy one, get one free valeo's I got from tirerack lasted my about two years. Only $10 and silent as well!
fengrr is offline   Reply With Quote
Old 02-07-2012, 10:14 PM   #148
my name is joe
Member#: 171412
i use regular blades since all the highend blades left this one streak, even when brand new. i searched about it and some people had this problem. I used to work at an autozone so i tried everything they had... at LEAST twice.
my name is joe is offline   Reply With Quote
Old 02-07-2012, 10:16 PM   #149
theoutbackdream
Member#: 301179
2013 WRX Limited
on the hatchback, what rear wiper do you guys use?
I bought one, and when i tried to replace the stock wiper, It seems like its a specific one..? Or am i doing it wrong?
Thanks, and yea im a newbie
theoutbackdream is offline   Reply With Quote
Old 02-07-2012, 10:24 PM   #150
my name is joe
Member#: 171412
its specific..
Wiper blades. Is the rear blade a non-standard? K4z00 Newbies & FAQs 6 03-29-2011 04:51 PM
Wiper Blade Replacement - Aftermarket Blades Peaty Tribeca Forum 21 04-15-2010 08:29 PM
Winshield wiper blade snaps off of wiper arm? plunk10 Off-Topic 2 02-13-2007 04:50 PM
('93-'01) Where the he!! can I buy replacement wiper blades? jlyttle Impreza Forum 26 10-22-2001 07:15 PM
New wiper blades (image) cvalle-sd General Forum Archive 2 02-20-2001 08:02 PM
