Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 12-29-2014, 09:43 PM   #1276
kasey
Member#: 157266
2018 WRX Sport Tec
Pure Red
I can get the messages but not reply. iPhone 4s
kasey is offline   Reply With Quote
Old 12-30-2014, 12:28 AM   #1277
MATR6
Member#: 376995
2015 WRX Limited
CWP
Same here. iPhone 6. Maybe it's bc I was using iMessage. Were you trying with SMS/text or iMessage.
MATR6 is offline   Reply With Quote
Old 12-30-2014, 12:52 AM   #1278
BURUTOO
Member#: 349400
2018 WRX Limited
Reply doesn't work on iPhones I don't think. It's bc of the iPhone and how locked down apple makes em.
BURUTOO is offline   Reply With Quote
Old 12-30-2014, 09:29 AM   #1279
subySerb
Member#: 155411
I don't have that option on Android.
subySerb is offline   Reply With Quote
Old 12-30-2014, 09:41 AM   #1280
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
Originally Posted by Squattro View Post
If you changed your front/rear turn signals and reverse lights to LEDs and have an LED blinker module, must your lights remain LEDs? Or can you put the oem bulb back in if you feel like it? Will it affect the blinker module?
It'll work just fine, but it will reduce the overall life of the module. The fine print of the TapTurn order page says:
"TapTurn is an automobile signal flasher that uses mechanical relays that click audibly for each on/off cycle. Mechanical relays wear and have a limited life expectancy subject to frequency of use and electrical load switched. StrobePack options operate at increased frequency which acclerates wear and shortens the useful life of the product. Different bulb types have different load characteristics and for maximum life expectancy LED bulbs are recommended in all signal bulb sockets around the vehicle."
nightdown fox is offline   Reply With Quote
Old 12-30-2014, 08:59 PM   #1281
katamari
Member#: 408789
Sorry if this has been addressed already, does anyone know why the fa20's use an angled conrod? like whats the science behind it, does it somehow negate a poor rod/stroke ratio?
katamari is offline   Reply With Quote
Old 12-30-2014, 10:53 PM   #1282
rkramer
Member#: 118209
2015 WRX Limitec
Official reason is for size. Allows for a longer stroke in the same size block. It also helps with strength.
http://www.caranddriver.com/news/sub...t-four-engines
"Even though the stroke is slightly longer, the FBís exterior dimensions are basically unchanged from the EJís. Subaru achieved this by employing asymmetrical connecting rods like those it used to increase the stroke of the flat-six in the Tribeca without drastically changing the engine. The lamb-chop-shaped rods also ease assembly of the bottom end. Subaru says 80 percent of the engineís cooling capacity is routed to the head, and it even added a cooling circuit to the exhaust-gas recirculation channel. By doing this, it was able to reduce NOx emissions. "
Old 12-31-2014, 01:49 AM   #1283
gerrygug
Member#: 407762
2015 WRX
Lightning Red
I've taken a lot of kidding about my Windows phone but am pleased to report that it receives and sends texts perfectly through the HK system.
gerrygug is offline   Reply With Quote
Old 12-31-2014, 03:02 AM   #1284
Jonnyfive
Member#: 395731
2015 WRX Premium
Bro do you even know what a text is
Jonnyfive is offline   Reply With Quote
Old 12-31-2014, 10:27 AM   #1285
spud
Member#: 37912
2015 WRX STI Limited
Lightning Red
I can confirm this works with my iPhone 6. Once paired via Bluetooth you need to tap the 'i' on the car multimedia line. In there turn on 'show notifications' then it will display on the nav screen and read them over the speakers if you choose to do so. I cannot get replying to work however. Than may be an iPhone 'feature' though.
Nav only right? I have the HK but no nav. I look in Bluetooth settings and the options you showed on my iPhone are not there.
spud is offline   Reply With Quote
Old 12-31-2014, 03:07 PM   #1286
kasey
Member#: 157266
2018 WRX Sport Tec
Pure Red
SMS/text I was using.
Old 12-31-2014, 06:28 PM   #1287
BURUTOO
Member#: 349400
2018 WRX Limited
Yes I have the hk+nav. Not sure on the non nav version. Try removing the connection from both your car and your phone. Then repair. I had this issue on my wife's outback and when I repaired the option showed up.
Old 12-31-2014, 06:29 PM   #1288
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
What HK with no nav?
Celery GT-5 is offline   Reply With Quote
Old 12-31-2014, 06:30 PM   #1289
spud
Member#: 37912
Lightning Red
I have a limited 2015. Has HK sound system. But no navigation.
Old 12-31-2014, 06:31 PM   #1290
spud
Member#: 37912
Lightning Red
Interesting. I'll give it a try.
Old 12-31-2014, 06:37 PM   #1291
Celery GT-5
Member#: 98210
hrm its stupid that they force you to get nav in the WRX
Old 12-31-2014, 06:39 PM   #1292
spud
Member#: 37912
Lightning Red
nevermind
Zomg. Did celery not know something about the 2015?
Do I win Internet points?
Old 12-31-2014, 06:41 PM   #1293
Celery GT-5
Member#: 98210
just didn't realize you had an sti
Old 12-31-2014, 06:42 PM   #1294
spud
Member#: 37912
Lightning Red
I assume the wrx limited has the same option of hk with no nav.
I'm annoyed that you have to have nav for push button start. Oem nav sux for all cars.
Old 12-31-2014, 06:44 PM   #1295
Celery GT-5
Member#: 98210
no the limited WRX forces you to get nav and push button start with HK for $2500, the premium gives you nav and hk with no push start for $2000 ftl
Old 12-31-2014, 06:50 PM   #1296
2006OBPSTI
Member#: 300087
2002 WRX Wagon
Johnson valve? Must be that it is so named because it is like a **** block for more boost?
Hahahahaha!
2006OBPSTI is offline   Reply With Quote
Old 12-31-2014, 07:02 PM   #1297
spud
Member#: 37912
Lightning Red
Are you 100% sure? That's odd that the STI limited lets you get HK without nav while the wrx limited you can't.
That blows.
Old 12-31-2014, 07:17 PM   #1298
Celery GT-5
Member#: 98210
yeah check the website
Old 12-31-2014, 09:36 PM   #1299
Knocka
Member#: 409738
Originally Posted by noTe View Post
Add this to the front page:
You can mute the stereo from steering wheel. If you hold MODE it will mute then you hold MODE again to unmute. Confirmed it works for the base and navi OEM units.
Does anyone know if this will work if you replace the factory H/K radio (the one with the touchscreen/NAV) with a Pioneer 4000NEX?
Knocka is offline   Reply With Quote
Old 01-01-2015, 12:50 AM   #1300
StxSti
Member#: 393322
2015 Launch Edition
World Rally Blue
Not sure. But you will have to program the steering wheel controls anyway.
StxSti is offline   Reply With Quote
