Welcome to the North American Subaru Impreza Owners Club Monday November 18, 2019
Old 04-07-2019, 07:39 PM   #1
ilovedemhotrides
Member#: 326147
Default Headlight lens swap
I have been in dire need of getting my headlights redone, the problem I faced is they were done a few times previously and the plastic was just too tired. It had been sanded and re-cleared one too many times.
Unfortunately, after much searching online, no one sells replacement lenses for Subaruís! The replacement HIDs cost 4-500 for a set of used ones. So I got a new set of those projector type from eBay for 140, and went to town.
Here is the result:
Before...
After:
ilovedemhotrides is offline   Reply With Quote
Old 04-10-2019, 12:48 AM   #2
FreakyFrog
Member#: 500175
Default Looks good
That sounds like a good deal on them were they hard to install?
FreakyFrog is offline   Reply With Quote
Old 04-15-2019, 05:50 PM   #3
PrettyFlyForABlobeye
Member#: 500166
2005 WRX
Nice work. I'm in the same boat, maybe not as bad. My acrylic is cracked from UV damage and no amount of sanding and buffing will fix that. I HATE the cheap D-Spec projector headlights but never thought about buying them just for the lenses. The biggest difference I noticed and still don't like is how the OEM headlights are molding in the top corners around the side marker light whereas the D-Spec headlights are smooth on the outside.
Nice work!
PrettyFlyForABlobeye is offline   Reply With Quote
Old 04-21-2019, 01:11 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
yeah that is what i did to mine too. I wish they did sell the lenses alone but oh well
subaru_gc8 is offline   Reply With Quote
Old 10-03-2019, 09:51 PM   #5
ilovedemhotrides
Member#: 326147
Not hard. But they require patience. I used a heat gun to separate the lenses from the housing.
Old 10-04-2019, 10:18 AM   #6
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
Old school (I can say that, I've been here for a little while) way was to put the entire headlight housing in the oven at like 200F for 20 minutes to soften / melt the sealing adhesive between the cover and the housing. That's how we got them apart to remove the orange reflectors "back in the day". A little easier than a heat gun since it heats everything all at once. You also don't get the hot spots and potential melting if the heat gun stays in one place too long.
Scooby921 is offline   Reply With Quote
Old 10-07-2019, 12:07 AM   #7
ilovedemhotrides
Member#: 326147
Lol oh I remember those days. I did that back maybe 10 years ago when I turned at and got my first car (rsx).
I did end up going around the entire housing. Luckily I did have the heat gun as the factory gunk holding mine was stubborn.
Stay tuned I am almost done a front bumper crack repair and repaint
