Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 05-02-2019, 11:45 AM   #1
staylor
Member#: 220047
2010 Impreza WRX
Default Remove Interior Scratches
Hey is there a good way to remove these scratches?
If so what product would be best?
Thanks
staylor is offline   Reply With Quote
Old 05-02-2019, 12:00 PM   #2
cerbomark
Member#: 475983
2018 WRX Limited
some plastic s respond well to a light polish, but be warned, some don t and it will dull it out. A test spot is best in an unseen area. Or remove the piece and if it doesn't t work you can pre shop the replacement part to see what the cost is and if it s worth the risk.
Start out very light if you try it.
cerbomark is offline   Reply With Quote
Old 05-02-2019, 12:22 PM   #3
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Cut your fingernails and install a new trim piece.
Turpid Porpoise is online now   Reply With Quote
Old 05-02-2019, 12:33 PM   #4
RIWRXer
Member#: 481523
2017 WRX Limited
Lapis Blue Pearl
^ Heh. Beat me to it.
Just wrap it with vinyl.
RIWRXer is offline   Reply With Quote
Old 05-02-2019, 12:34 PM   #5
amiexploited
Member#: 251061
18 Trek 6mt,
garage queen 15 WRX 6mt
If you wipe it with a wet rag and the scratches disappear then you can buff it out. Remove the trim and have at it.
amiexploited is online now   Reply With Quote
Old 05-02-2019, 01:22 PM   #6
staylor
Member#: 220047
2010 Impreza WRX
Wasnt from me, been that way sense I bought but thanks though
Old 05-02-2019, 01:22 PM   #7
staylor
Member#: 220047
2010 Impreza WRX
Okay thanks I will try it.
Old 05-02-2019, 01:22 PM   #8
staylor
Member#: 220047
2010 Impreza WRX
Okay thanks I will try it out.
Old 05-02-2019, 01:23 PM   #9
gfxguy
Member#: 316583
2014 STI Hatch
ISM
Curious about how this turns out. Have similar fine scratches on my shifter surround from previous owner that Id love to get rid of.
gfxguy is online now   Reply With Quote
Old 05-03-2019, 07:10 PM   #10
user15
Member#: 486228
2015 WRX
You could try an all in one polish, put a little on a microfiber and buff. May not take them out but will lighten them.
user15 is offline   Reply With Quote
Old 05-03-2019, 07:58 PM   #11
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
I usually use a product called EZ felt purchased at Michael's Arts and Crafts to rub the scratches away. It's basically hard felt.
It works well on my WRX' center console plastic (aka garbage material Subaru used).
oichan is offline   Reply With Quote
Old 05-07-2019, 01:23 PM   #12
badogski29
Member#: 454800
2019 WRX
CWP
How about on piano black / glossy black surfaces? I accidentally scratched the HVAC control trim on my 19 wrx.
badogski29 is offline   Reply With Quote
Old 05-07-2019, 03:53 PM   #13
cerbomark
Member#: 475983
2018 WRX Limited
same rules apply.
Old 06-02-2019, 12:33 AM   #14
zxyphyr
Member#: 502786
Thanks for the tip, I'll have to give this a try
zxyphyr is offline   Reply With Quote
Old 07-20-2019, 09:03 PM   #15
vectese
Member#: 504460
2004 WRX
San Remo Red
I've seen small polishing pads to go on the ends of cordless drills and with a small bit of polish/compound I'm sure it'll make it much easier than doing it by hand.
vectese is offline   Reply With Quote
Old 07-21-2019, 04:34 PM   #16
oichan
Member#: 492327
2019 WRX / 16 STI
2017 Golf-R, etc
On my 19 WRX where the center console scratches with the smallest impact, I use hard felt dry and rub it gently against the textured plastic. It's called EZ felt and can be bought at most art supply stores.
This works like a polish, less coarse than magic eraser. If this is on painted surface, as others mentioned, I would remove the trim and wrap it.
Old 07-29-2019, 10:19 PM   #17
WRX2018VA
Member#: 471567
2018 WRX Limited
Same suggestion for the inevitable scuff marks on the bottom of the doors? EZ Felt?
I've put vinyl stickers on the bottom of the back doors (2018 WRX) - which is very hard to see so not a big deal, but not sure I want to do that on the fronts.
WRX2018VA is offline   Reply With Quote
Old 08-17-2019, 03:30 PM   #18
boxerdit
Member#: 429255
2016 WRX Premium
Lapis Blue
This is normal wear and tear. No real way to repair this. Best bet is to replace or wrap with vinyl.
boxerdit is offline   Reply With Quote
Old 08-20-2019, 04:29 AM   #19
brylemr
Member#: 414507
You can use PlastX to improve the appearance only.
brylemr is offline   Reply With Quote
