Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 03-06-2011, 02:19 PM   #1
nhat
Member#: 140163
03 STi
hellaflunctional
Default the summer tire thread: all performance summer tire questions go here!
what most of us look for in a summer tire is tread wear. UTQG is only 1 factor to consider since ratings vary from manufacturer to manufacturer. a UTQG of 140 for one brand might be equal to a UTQG of 200 for another brand.
Uniform Tire Quality Grade (UTQG) Standards
The U.S. Department of Transportation (DOT) National Highway Traffic Safety Administration's (NHTSA) Uniform Tire Quality Grade Standards (UTQG) were originated to provide consumers with useful information to help them purchase tires based on their relative treadwear, traction and temperature capabilities. While it is required by law for most passenger car tires sold in the United States, it is not required for deep treaded light truck tires, winter/snow tires, temporary spare tires, trailer tires, tires under 12” in diameter and other select tires.
When looking at UTQG ratings it is important to realize that the Department of Transportation does not conduct the tests. The grades are assigned by the tire manufacturers based on their test results or those conducted by an independent testing company they have hired. The NHTSA has the right to inspect the tire manufacturer's data and can fine them if inconsistencies are found. While most new tire lines have their grades established when they are introduced, they are allowed a 6-month grace period to allow the tire manufacturer to test actual production tires. Once a grade is assigned it must be branded on the tire's upper sidewall and printed on its label.
Unfortunately, the rating that is of the most interest to consumers is the one that appears to be the least consistent. While the Treadwear Grade was originally intended to be assigned purely scientifically, it has also become a marketing tool used by manufacturers to help position and promote their tires.
Treadwear Grades
UTQG Treadwear Grades are based on actual road use in which the test tire is run in a vehicle convoy along with standardized Course Monitoring Tires. The vehicle repeatedly runs a prescribed 400-mile test loop in West Texas for a total of 7,200 miles. The vehicle can have its alignment set, air pressure checked and tires rotated every 800 miles. The test tire's and the Monitoring Tire's wear are measured during and at the conclusion of the test. The tire manufacturers then assign a Treadwear Grade based on the observed wear rates. The Course Monitoring Tire is assigned a grade and the test tire receives a grade indicating its relative treadwear. A grade of 100 would indicate that the tire tread would last as long as the test tire, 200 would indicate the tread would last twice as long, 300 would indicate three times as long, etc.
The problem with UTQG Treadwear Grades is that they are open to some interpretation on the part of the tire manufacturer because they are assigned after the tire has only experienced a little treadwear as it runs the 7,200 miles. This means that the tire manufacturers need to extrapolate their raw wear data when they are assigning Treadwear Grades, and that their grades can to some extent reflect how conservative or optimistic their marketing department is. Typically, comparing the Treadwear Grades of tire lines within a single brand is somewhat helpful, while attempting to compare the grades between different brands is not as helpful.
Traction Grades
UTQG Traction Grades are based on the tire's straight line wet coefficient of traction as the tire skids across the specified test surfaces. The UTQG traction test does not evaluate dry braking, dry cornering, wet cornering, or high speed hydroplaning resistance.
The Traction Grade is determined by installing properly inflated test tires on the instrumented axle of a "skid trailer." The skid trailer is pulled behind a truck at a constant 40 mph over wet asphalt and wet concrete test surfaces. Its brakes are momentarily locked and the axle sensors measure the tire's coefficient of friction (braking g forces) as it slides. Since this test evaluates a sliding tire at a constant 40 mph, it places more emphasis on the tire's tread compound and less emphasis on its tread design.
In 1997, the UTQG Traction Grades were revised to provide a new category of AA for the highest performing tires in addition to the earlier A, B and C grades. Previously the A grade had been the highest available and was awarded to tires that offered wet coefficients of traction above 0.47 g on asphalt and 0.35 g on concrete. Today the grades and their traction coefficients are as follows:
Code:
Traction     Asphalt           Concrete
Grades       g force           g force
AA	     Above 0.54	         0.41
A	     Above 0.47	         0.35
B	     Above 0.38	         0.26
C	     Less Than 0.38	 0.26
Unfortunately the immediate value of this change to tire buyers will be limited. Use of the AA grade will first be seen on new tires that are introduced after the standard was enacted and will then appear later on tires that have had the required wet traction all along, but were introduced when the single A was the highest available grade.
Temperature (Resistance) Grades
The UTQG Temperature Grade indicates the extent to which heat is generated/ or dissipated by a tire. If the tire is unable to dissipate the heat effectively or if the tire is unable to resist the destructive effects of heat buildup, its ability to run at high speeds is reduced. The grade is established by measuring a loaded tire's ability to operate at high speeds without failure by running an inflated test tire against a large diameter high-speed laboratory test wheel.
Code:
Temperature            Speeds
Grades                 in mph
A	               Over 115
B	               Between 100 to 115
C	               Between 85 to 100
Every tire sold in the United States must be capable of earning a "C" rating which indicates the ability to withstand 85 mph speeds. While there are numerous detail differences, this laboratory test is similar in nature to those used to confirm a tire's speed ratings.
Unfortunately for all of the money spent to test, brand and label the tires sold in the United States, the Uniform Tire Quality Grade Standards have not fully met their original goal of clearly informing consumers about the capabilities of their tires. Maybe it's because tires are so complex and their uses can be so varied, that the grades don't always reflect their actual performance in real world use.
when posting, please provide us with the year and model, how you intend to use your car (daily driver, autox, track, mixed), budget, desired tire size, and wheel specs.
if you have questions we can't answer, or desire more technical info, don't hesitate to give luke @ tirerack.com a call 800-428-8355 ext. 362 or send him an email.
nhat is offline   Reply With Quote
Old 03-06-2011, 06:12 PM   #2
rotorhead
Member#: 35187
2003 impreza wrx
finally! i've been so worried about starting *yet another what tire should i buy* thread, and the ubiquitous "just search" doesn't really help. days of searching, and i'm still no closer to an answer. plus, uncle scotty is just itching to layeth the smacketh down if i ask something stupid
anyways, here goes:
03 wrx, daily driver. it'll likely never see a track, but i do a LOT of highway driving with some serious mountains and curves. looking for the most tire for the dollar, or smiles per mile. stock size on stock 16's is all i'm after. i do have a winter setup (dunlop 3Ds), although we can get a totally unexpected snow storm before those get installed. basically, good grip, long lasting, and not breaking the bank... impossible, i know. but what comes close?
i keep seeing federal 595's come up, and i'm guessing the SS is the more DD oriented of the 595's. i *think* i'm aiming for summer tires, although luke has raved about a certain all season that's on sale at the moment.
rotorhead is offline   Reply With Quote
Old 03-08-2011, 01:55 PM   #3
rotorhead
Member#: 35187
2003 impreza wrx
*bump* s head against the desk, wondering why a perfectly usable dedicated thread gets passed over for several "yet another what tire....." threads. mmm, nabiscioc!
but yeah, what's the point of 80 threads that'll vanish into the ether in about 8 hours when 1 thread can handle it? case in point: the winter tire thread.
Old 03-08-2011, 07:32 PM   #4
Subydude81
Member#: 118266
2007 Lexus IS250 RWD
6MT
Hankook Ventus V12 Evo
235/40/18
Pretty good tire when I had it running on my Acura TSX on 18x8 wheels lowered with coilovers and conservative alignment. It was a daily driver but some spirited driving.
I found the tire to be pretty good overall but there was this feeling in my gut when i pushed my car that I didn't know if it could handle it. Was pretty good in the rain, pretty predictable in that weather. Sidewalls are not stiff enough. I think people who want a summer tire but a comfortable tire would like this tire.
I think I paid about $140 a piece which is a very good price.
I'm not sure if I would buy it again though.
Nitto Neogen
225/40/18, 18x7.5 wheel
Acura TSX on coilovers with conservative alignment. Daily driver but some spirited driving.
I thought for the price which was about $130 this tire was super sticky. Sure its Nitto and people bash it but I found it to be very sure footed. I didn't feel like the sidewalls were rolling when I pushed it around corners. The wet traction was pretty good. Tread life was ok but you cannot flip these tires since the inner tread is different. I would purchase these again unfortunately I want a tire with the same tread pattern so I can flip them if needed.
This tire is also supposed to have a longer lasting inner tread to handle cars with increased negative camber.
If I had to pick Neogens or the Ventus V12 I would take the Nittos.
Subydude81 is offline   Reply With Quote
Old 03-09-2011, 12:03 AM   #5
tnhunter2
Member#: 265487
2006 Evo MR
Graphite Grey
04 sti, toxico dspec suspension, slightly lowered, 392.21 awhp 423.79 awtq, autox, hard curves driving. Not a daily driver car but probably about 400 miles a month, maybe. Also doing some drag racing. Budget doesn't matter, 17x8 or 17x8.5 rim size (still undecided, probably rota g-force). Looking for 235/40 17 unless I can get a 245/40 without rubbing/rolling fenders. I want the best! I was thinking of star specs but now im thinking of nt01 or nt05. It doesn't have to be one of these 3, I just want the best! What's your opinion?
Also it shouldnt see any rain or snow. I have a snow tire setup. Im wanting strictly summer, dry tires.
tnhunter2 is offline   Reply With Quote
Old 03-09-2011, 02:23 AM   #6
wrxSIN
Member#: 157818
did you do your
kegels today?
drag racing tires =/= autox tires
one requires stiff, others want it soft.
wrxSIN is offline   Reply With Quote
Old 03-09-2011, 02:34 AM   #7
tnhunter2
Member#: 265487
2006 Evo MR
Graphite Grey
I guess I want more of an autox tire.
Old 03-09-2011, 10:08 AM   #8
krzyss
Member#: 8365
2013 Ford Focus SE
no wet? Kumho XS may be for you.
Krzys
krzyss is offline   Reply With Quote
Old 03-09-2011, 11:08 AM   #9
tnhunter2
Member#: 265487
2006 Evo MR
Graphite Grey
Krzys
No wet, dry only, autox and hard hitting mountain curves.
Old 03-09-2011, 12:37 PM   #10
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Maybe I should know this... but I don't.
Why is the stock summer tire on the GR STi's not liked?
Ive seen many many for sale ads for them, I even thought about selling mine because I assume if everyone else is selling theirs, mine must be bad too..
new tires bad or just hype?
Old 03-09-2011, 07:41 PM   #11
dakrat
Member#: 272840
2011 STI
if I eat my turd, are you going to eat yours too?
applications, applications, applications...what is yours? autox? drag? drift? daily drive? wet weather?? what??????
dakrat is offline   Reply With Quote
Old 03-09-2011, 07:56 PM   #12
nhat
Member#: 140163
03 STi
hellaflunctional
for starters, they're too tall for the GD and an unpopular size for subarus unless you have a GR.
they're just not on par with aftermarket tires for their price as an oem tire. those selling them generally ask too much and use tirerack or dealership pricing to justify it. for the same money (or less), you can get a far better tire even though most people only use their cars for daily driving and really have no need for a max or extreme performance tire.
that's my take on it.
Old 03-09-2011, 08:01 PM   #13
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I was a light infantry medic, I've eaten worse for less of a reason.
I'm just hard on cars, its a daily drive, but will make one or two passes at a drag event as well as 1 or 2 auto-x days. If all goes well I'll do an hpde this summer too.
That makes more sense. But if I have it, no sense in bailing on it, unless I have a greater need?
Thanks guys.
*burp*
Old 03-09-2011, 11:54 PM   #14
wrxSIN
Member#: 157818
did you do your
kegels today?
all tires are terrific to one person or another.
context context context.
im sure a lot of commuters loved their RE92s. the world will end before they wear out.
Old 03-10-2011, 11:13 AM   #15
tnhunter2
Member#: 265487
2006 Evo MR
Graphite Grey
nobody got any suggestions for me aside from the xs?
Old 03-10-2011, 11:31 AM   #16
poison
Member#: 37678
Just finish the stockers out, then buy something better. I'd jump on the XS if I din't care about rain.
poison is offline   Reply With Quote
Old 03-10-2011, 01:46 PM   #17
rotorhead
Member#: 35187
2003 impreza wrx
hey, at least you got a suggestion! c'mon now, someone's gotta have some good feedback on a 16" summer tire on stock bugeye wheels that is daily driven, fun, can handle some rain, never autox'ed, has a decent treadlife, and compliments the fact that i have dedicated winter tires, so no all seasons need apply.
Old 03-10-2011, 06:11 PM   #18
poison
Member#: 37678
Rotorhead, 452's fit your bill to a t.
Old 03-10-2011, 06:31 PM   #19
nhat
Member#: 140163
03 STi
hellaflunctional
what's your budget? i was on the fence between star specs and nt05s but starspecs went up in price and we all know how good they are, so nt05s it is for me. from what i've read, starspecs heat up quicker so would be more suitable for autox.
budget? oem size or 225/50/16?
hankook v12 evo, bridgestone re760, falken fk452, yokohama s.drive, conti extremecontact dw are the tires i would look at.
Old 03-10-2011, 11:37 PM   #20
xanthus29
Member#: 118313
2007 WRX Wagon
I've got a stock 2007 WRX Wagon looking to finish my transition from all seasons to dedicated winter / summer setups. With spring approaching, I have planned to get 17x8 OZ Ultraleggera wheels with Goodyear Eagle F1 Asymmetric 215/45R17 tires.
Primary applications: mostly daily driver, but want to have the grip in the turns. I found a track 2hrs from my new house and would like to get my first track day this year. I do have about a half mile of gravel road from my house to pavement. Since this will be DD, does gravel harm the summer tires?
With all this info, is this wheel / tire setup a good choice for me?
xanthus29 is offline   Reply With Quote
Old 03-11-2011, 01:46 AM   #21
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
You would be better off running 225/45-17 tires with 8" wide wheels. I would consider more performance-oriented tire categories since you are looking for dedicated season sets. I love the Dunlop Star Specs and I think you'll find that it's one of the most recommended. It even won the 09 Car and Driver test - google it. In regards to the gravel road, as long as you don't tear down the road, you're good so go slow.
I'm running those same wheels and the star specs on my 06 WRX wagon.
kenliu84 is offline   Reply With Quote
Old 03-11-2011, 07:00 AM   #22
stuiephoto
Member#: 205742
1995 RSTI
06 sti - stage 2 on bbs'es, stock suspension.
Hard DD'ing, a couple autox days and maybe a road course for a weekend over the summer. Needs to be able to handle wet traction well as it rains a bit here and we sometimes have slick roads because of some of the chemicals they put down during the winter.
For the price, im having a hard time beating the star specs but I like the higher tread wear and relatively decent reviews (wet) i've seen of the extremecontact DW. Any other options in that price range? Should I go with a little wider than stock fitment? If so 235 or 245?
stuiephoto is offline   Reply With Quote
Old 03-11-2011, 09:15 AM   #23
ljryeaiii
Member#: 205582
07 STI
Default New Tires
I am running stock 17" BBS's on my 07 STi and I need new tires (threads are showing..damn autocross). I am currently running 225/45 17, but I want to change it up just a little bit. I have seen guys rip fender wells out at 245/45 so I want to go with 235/40 17..on the stock BBS's will I have any issues? If not what do you think of these tires?
http://cgi.ebay.com/ebaymotors/4-NEW...Q5fAccessories
Or
http://www.tirerack.com/tires/tires....Qty=4&i1_Qty=4
ljryeaiii is offline   Reply With Quote
Old 03-11-2011, 09:41 AM   #24
buki_JB
Member#: 274345
2011 STI 5dr
The Sumitomo's are a decent tire. There are better tires out there, but $88/tire is pretty cheap.
http://www.tirerack.com/tires/survey...er=17&type=UHP
http://www.tirerack.com/tires/survey...ter=17&type=EP
It takes a lot of information for someone to recommend a tire for you; there are so many variables that you have a personal preference on, that it's hard to say "this is the perfect tire for you" until you've driven on them and feel for yourself.
buki_JB is offline   Reply With Quote
Old 03-11-2011, 09:58 AM   #25
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Are those BBSs wide enough for a 235/40?
The tire spec says 8-9.5" rim width
mmiller2002 is offline   Reply With Quote
The Winter Tire thread- all winter tire questions go here !!! [email protected] Tire & Wheel 7424 Yesterday 07:45 PM
THE Chico Meet Thread: Post all Chico Meets here mrbodega15 Bay Area Impreza Club Forum -- BAIC 2066 04-10-2019 04:17 AM
Absurd science questions go here -=C=- Off-Topic 319 05-09-2011 04:20 PM
Performance All-Season Tires or Max Performance Summer Tires Skiitec Tire & Wheel 18 02-08-2010 01:53 PM
WTT: Winter wheels/tires for all-season wheels/tires igor New England Impreza Club Forum -- NESIC 7 02-02-2005 03:34 PM
