Welcome to the North American Subaru Impreza Owners Club Friday November 15, 2019
Old 05-24-2010, 05:58 PM   #76
fullerton
Member#: 122030
i pm'd him something more private.
but, no, I do not recall the depth off the top of my head.
fullerton is offline   Reply With Quote
Old 05-24-2010, 06:04 PM   #77
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I'm just busting your bawlz.
I just ordered some Heli-Coils for my brakes. Only one stripped out on the front, but I'm going to do all four holes to ensure I don't have this happen at another time with the other holes.
yamahaSHO is offline   Reply With Quote
Old 06-13-2010, 03:52 PM   #78
SEBBARU
Member#: 71774
2005 WRX STi
Platinum Silver
FYI: I bought the replacement bolts from my local dealer. They cost almost $45.00CAD (for all 8)
SEBBARU is offline   Reply With Quote
Old 06-13-2010, 04:18 PM   #79
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
anyone had success in eliminating this issue by applying anti-seize?
Old 06-13-2010, 04:24 PM   #80
SEBBARU
Member#: 71774
2005 WRX STi
Platinum Silver
I'll find out during my next brake service (after fixing the problem).
Old 06-13-2010, 06:42 PM   #81
thepigsti
Member#: 166215
I'm replacing a caliper due to this same problem right now, and am probably going to have to go the helicoil route because the aluminum threads in the caliper probably won't last too long when repeatedly taking them off to swap pads before/after track days.
thepigsti is offline   Reply With Quote
Old 06-14-2010, 10:59 AM   #82
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Nope. It will still happen eventually if removed enough.
Another helpful hint is to not follow the recommended torque spec as it is way too high. I torque to about 60 ftlbs.
Tony
Turn in Concepts is online now   Reply With Quote
Old 06-14-2010, 05:00 PM   #83
JiveMasterT
Member#: 116666
2011 STI Limited
Looks nice, plays dirty
Just to confirm, when doing my brakes, I should have 10Mx1.5 and 12Mx1.5 helicoils on hand... correct? I see some people saying that the threads are 1.5 "fine" but 1.5 is coarse... 1.25 is fine.
JiveMasterT is offline   Reply With Quote
Old 06-14-2010, 05:06 PM   #84
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
The line between fine and coarse changes depending on both thickness I believe. I think 1.5 is fine on a M12, but coarse on a M10.
Old 06-14-2010, 05:12 PM   #85
JiveMasterT
Member#: 116666
2011 STI Limited
Gotcha. Ok so I need a 10Mx1.5 and a 12Mx1.5 right?
Old 06-15-2010, 12:42 AM   #86
SEBBARU
Member#: 71774
2005 WRX STi
Platinum Silver
Some people have gone with the helicoil repair solution, but the timeserts are a MUCH more robust solution.
Those bolts are the only thing keeping your caliper from moving when you apply the brakes.
FWIW, that's my opinion, and that's why I'm using timeserts rather than helicoils.
Old 06-15-2010, 02:19 AM   #87
kpluiten
Member#: 120273
06 WRBWRXWGN
The timeserts are nice. The cost is a bit high for my tastes though. I've used helicoil on several standard calipers (non-brembos) and it has been VERY good when installed properly. I'm thinking about installing a helicoil insert into a block of aluminum and then threading a bolt into it. Then I'm going to take it to work and put it on our instron machine and measure the tensile strength to failure. I have a feeling it will end up maxing the machine out with the current load cells we have.
While this isn't a totally accurate test because in your braking application, the bolt is in shear, it will still yield (pardon the engineering pun ) some interesting info. I wish i had a way to test it in shear since that's closer to what's happening in you caliper application.
Old 06-15-2010, 05:01 AM   #88
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Pretty sure you can change the pads without unbolting the calipers? Do you mean the rotors?
minifreak is offline   Reply With Quote
Old 06-15-2010, 09:29 AM   #89
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I may have posted this already but:
The torque specs for the front caliper bolts for the Brembo calipers is 80Lb/ft.
The repair manual incorrectly states the torque spec at 114.3Lb/ft. Apparently the 114.3 should be Newton-Meters which converts to approximately 80Lb/ft.
This was confirmed with SOA by a member of IWSTI: http://www.iwsti.com/forums/gd-braki...per-bolts.html
Old 06-15-2010, 10:28 AM   #90
fullerton
Member#: 122030
On the sti nothing is required to be removed for a pad swap, save the wheel and two pins. An entire brake job can be done on the sti with a wheel wrench and some needle nose pliers. (Plus a 10mm closed end wrench for bleeding)
Old 11-10-2010, 11:50 AM   #91
TubeDriver
Member#: 14987
Does anybody know the mm depth needed for timeserts on front (12x1.5) and rear (10x1.5) STI Brembos? Thanks.
They appear to be available in:
6.7
9.2
16.2
24.0
30.0 depths
for 12x1.5
and
9.4
11.0
14.0
17.0
20.0
22.0
24.5
30.0
40.0 depths
for 10x1.5
TubeDriver is offline   Reply With Quote
Old 12-18-2010, 01:09 PM   #92
thundercamel
Member#: 183360
2015 STi
CBS
I'm GUESSING 16.2mm front, since fleadog said the calipers are 20mm thick earlier in this thread, and 14mm for the rear. Those just happen to be the sizes marked in red on their website, that comes with the kits.
thundercamel is offline   Reply With Quote
Old 03-31-2011, 03:23 PM   #93
rallyracersti
Member#: 147522
2015 wrx
Wrb
this $hit has happened to me twice now since owning my car.first time was when i did front brakes at 45k miles.now at 69k miles i have to do a right front wheel bearing. ridiculous. both the top and bottom caliper bolts are broken.special order part from local subaru dealer. wtf!
rallyracersti is offline   Reply With Quote
Old 03-31-2011, 03:34 PM   #94
JiveMasterT
Member#: 116666
2011 STI Limited
They are cheap enough to keep some extras on hand. Just get them from any of the online subaru parts distributors. subaruonlineparts is usually among the cheapest.
It happens once and then after that you just have the stuff on hand to fix it. Last time it happened I replaced all of the bolts and cleaned up the caliper threads.
Old 03-31-2011, 06:25 PM   #95
sc00by4life
Member#: 97135
You can pick up replacement bolts from Fastenal.
Old 04-01-2011, 11:07 AM   #96
rallyracersti
Member#: 147522
2015 wrx
Wrb
ordered a helicoil kit and its about $60.hopefully it arrives today so i can attempt to fix it asap.
Old 04-01-2011, 11:14 AM   #97
JiveMasterT
Member#: 116666
2011 STI Limited
Whoa! $60?! I got mine for like $20 on Amazon.com 2 day shipped. I guess when you need to get your car on the road, shopping for prices isn't really an option.
Old 04-01-2011, 11:16 AM   #98
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
This just happened to me a couple weeks ago.
I was able to extract the bolt with a easy out, hammer, and a pick. Took 2 days.
salvaged enough of the hole that I didn't need to helicoil it. Just retapped it.
I chronicled this in a thread "what is it not ok to antiseize"
Dirty25RS is offline   Reply With Quote
Old 05-15-2011, 02:40 PM   #99
stil2stock
Member#: 51870
06 STI
This just happened to me too. Both bolts in the RF, one in the LF had to be drilled and helicoiled.
Today, I went to install speed bleeders. 7 of 8 went fine. The last one (RR, inside) has no threads left in the caliper after pulling out the stock bleeder screw.
I Fing hate these brembos. Totally not worth it.
stil2stock is offline   Reply With Quote
Old 05-15-2011, 11:42 PM   #100
gills
Member#: 11316
1988 E30S52 DD
S14VQ35 & S13KA racecarzz
wow, it's upsetting to see that such an apparent design flaw was overlooked and has caused so much angst. I was cursing the engineers responsible when it happened to me back in 2005 and started this thread!
Believe it or not I still have my car and it's been a while since I've pulled off my calipers. I will be doing a 5x114.3 conversion in a couple of weeks and I'm putting money on the fact that I will be buying some helicoils during the process. CAN'T WAIT
gills is offline   Reply With Quote
Brembo Caliper mounting bolts 12mm x 1.5 aclver1 RMIC Private Classifieds 3 04-03-2009 05:51 PM
Thread pitch for rear brembo caliper mount bolt sti robot Brakes, Steering & Suspension 2 11-10-2008 07:32 PM
ATTN:STi front brembo caliper mounting bolt torque!! The_Prodigy Brakes, Steering & Suspension 2 05-07-2008 08:35 AM
Ugh! What did I do now? Help needed...stripped threads in caliper Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 3 04-13-2003 12:53 AM
Stock caliper mounting bolts question - can anyone help?? alfriedesq Brakes, Steering & Suspension 0 02-10-2002 03:28 AM
