Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 03-08-2007, 03:42 PM   #26
bboy
Member#: 56468
04 Improved STI
Dirty White
Very cool. I'm happy to see the Supertech pistons. Did you have those custom made? I've eyed them myself. They have a substantial second ring land and the skirts look pretty short. You have to let us know how they sound on start up.
Even though you don't see them, the black looks so nice.
Old 03-09-2007, 03:31 AM   #27
3.2L AWD Turbo
Member#: 141909
2004 GOLF R32T(GT35)
Black Magic Pearl Metalik
Mmmm...A sweet-sounding six. This is a build!!!
3.2L AWD Turbo is offline   Reply With Quote
Old 03-09-2007, 10:30 AM   #28
My-STI-Rules
Member#: 62580
Default RPM Question
Jeff,
In your opinion, what is "safe" max RPM limit with a built bottom end & built head for an H6 for a car that would see a days of track duty at a road racing?
Also, what is the rod ratio with these new rods?
My-STI-Rules is offline   Reply With Quote
Old 03-09-2007, 11:37 AM   #29
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Jeff-
What did you have to do to your wife to have her allow you to build that thing on the table?!
Old 03-09-2007, 11:52 AM   #30
zavier
Member#: 141189
2007 2.5i (NBP)
2018 STI Limited (ISM)
^ this thread might get locked if he tells you :P
zavier is offline   Reply With Quote
Old 03-09-2007, 03:06 PM   #31
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by My-STI-Rules View Post
Jeff,
As far as safe RPM, I haven't really determined the limit. So far I have been reving to 7k, but I am probably not going much beyond that given the stock bearing surfaces are smaller on the H6 crank... and the H6 crank is thinner then the 2.5L one.
The rods are 5.180" long, and the stroke is 3.149", so the rod/stroke ratio is 1.64, just about the same as the EJ255/257. I do have new valve springs which should help push things, but the crank may be the limiting factor.
Originally Posted by White 2.5rs View Post
Jeff-
Well, before I had the engine parts on there I was using the table to rebuild my SKS and AK47, so I think the engine parts were an improvment.
Cheers!
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 03-09-2007, 04:46 PM   #32
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Cheers!
Jeff Sponaugle
Hah works for me. Please, PLEASE, tell me you're taking advatage of Oregon's gun laws..and that is a TRUE 47...
Old 03-09-2007, 05:13 PM   #33
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
sexy buildup!
Old 03-11-2007, 08:42 AM   #34
SPOOLN STI
Member#: 123377
2006 STI
WHITE
Sweet build and nice details. Gotta love subie porn!
SPOOLN STI is offline   Reply With Quote
Old 03-11-2007, 02:02 PM   #35
My-STI-Rules
Member#: 62580
Jeff - Thanks for the info & I greatly appreciate it!
Another question/thought, in your opinion after building a couple of H6s IF a new billet crank was used with larger bearing surfaces instead of a stock crank , could you get a H6 to spin safely and reliable to 8k or 8.5k?
Could you create a create a crank big enough to accept the 2.5 bearings?
Thoughts?
Old 03-12-2007, 03:37 AM   #36
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
I'll post a link to a vid in a bit.
Patiently waiting!
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 03-12-2007, 01:53 PM   #37
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Thoughts?
Well, the crank could be made beefier, but it would be challenging to make the surface area bigger as the case would be the limiting factor. The rod faces are the same size, but the case faces are smaller. So without making your own crank case, the best option would be the use a stronger material in the crank itself.
I think the guys at Cobb may have a new crank for the H6.. Not sure but there are rumors.
Given the rod/stroke ratio and the stock vs bore, I would assume that with proper oil control you could rev to 8k. Perhaps some mods to the oil system and the crank however. I will get my new motor broken in and then see how it performs at higher RPM.
Cheers,
Jeff
Old 03-12-2007, 02:15 PM   #38
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
How is that 07 gearing swap to prior years 6speed coming along?
Token-Negro is offline   Reply With Quote
Old 03-13-2007, 05:11 PM   #39
SQC120
Member#: 39677
2008 Land Rover
02 WRX
still waiting on the vid..
wow im so glad that this is going in a bugeye..
SQC120 is offline   Reply With Quote
Old 03-14-2007, 01:07 AM   #40
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
nice thread
eclip5e is offline   Reply With Quote
Old 03-14-2007, 11:55 PM   #41
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
If anyone has any ideas/suggestions about what tire/wheel setup to use at subiefest, comment away:
http://forums.nasioc.com/forums/show...6#post17359276
Jeff
Old 04-05-2007, 12:09 AM   #42
myliberty
Member#: 120773
1997 Liberty
3012cc H6 + GT4088
The crank is big enough to accept the 2.5L big end bearings. just.
I used 2.5L big end bearings and had custom argo rods made to suit.
myliberty is offline   Reply With Quote
Old 04-05-2007, 03:40 PM   #43
sadRS
Member#: 11328
2002 Impreza
2005 Legacy
insane build!!
sadRS is offline   Reply With Quote
Old 04-09-2007, 10:33 AM   #44
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Beautiful work~
Can't wait to see when you are 100% finished.
I'm glad you got permission to work at your dinner table. Couple of years ago, when I put together my RC Kyosho inferno together, I almost got kicked out of the house. Imagine what would have happened if I brought an engine. LMAO. Good work.
Steve
WRX4eva is offline   Reply With Quote
Old 04-09-2007, 01:15 PM   #45
IllNastyImpreza
Member#: 36333
98 RS
GT30R, closed deck madnes
what are you goals for this car? you have any new pics?
IllNastyImpreza is offline   Reply With Quote
Old 04-10-2007, 01:22 PM   #46
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
Very nice Jeff.
I will be in the 6cyl. world soon, but they will not be aposed, and i am planning on putting em in a RS coupe.
BREWPUBEAVER is offline   Reply With Quote
Old 04-13-2007, 01:00 AM   #47
wuuusaa
Member#: 92894
2015 Wrx
I second that, how is everything working out?
Old 06-05-2007, 12:44 PM   #48
kiefer
Member#: 35285
2003 WRX
color: speckled rock chip
Any updates on this project??
kiefer is offline   Reply With Quote
Old 06-07-2007, 04:57 PM   #49
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Your Build is similar to my build
Jeff:
I am in the process of doing a build up on an EG33. I have CP pistons (lower compression 8.5:1), Eagle H-beam rods, cams, valves, springs. I haven't decided or purchased bearings yet. When you installed your pistons, did you install one of the circlips first, then install the second after the piston and pin is in place? Just curious because I will be doing this soon. Thanks and I will keep tuned in. Wish the EG33 ran a timing chain instead of a belt.
Thanks
Chuck D.
cdigerlando is offline   Reply With Quote
Old 06-07-2007, 08:34 PM   #50
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default One other thing
Have any of you 3.0 builders considered sleaving, deck closing, or semi-closing?
It has begun: GC4 EJ22 to EZ30R swap. Slack Subaru Conversions 1584 01-14-2014 05:54 AM
FS: EZ30R H6 Buildup Parts.. sponaugle Engine/Power/Exhaust 4 02-24-2008 07:47 AM
H6 Turbo EZ30R tear down/build up for BE Legacy PHATsuby Subaru Conversions 2 07-04-2005 04:27 AM
Running EZ30R with Hydra? Slack Other Engine Management 16 04-07-2005 06:29 AM
B9X: EZ30R Engine, Price North of $35,000 Jon [in CT] News & Rumors 168 11-20-2004 12:32 PM
