Welcome to the North American Subaru Impreza Owners Club Wednesday November 21, 2018
Old 04-01-2017, 10:03 PM   #1
WilliHaM
Member#: 453391
Unhappy 2002 WRX Forged 2.0, 20g Hesitation/Bucking
I have had this problem in the past and clearly have not fixed it while I thought it went away at times.
The car has many aftermarket parts and more recently seems to buck and hesitate under more boost but previously was only under hard throttle.
I am using a MBC and car is tuned for around 20lbs.
Does not sputter in 1st and is less often in 2nd. Logs show no knock during
during these pulls or time of hesitation. 3rd is most prevalent wit sputtering
pretty much any time over 35% throttle and higher lbs of boost.
Tests done so far:
Swapped MAF
Fixed MAF wiring
Swapped Plugs to stock heat range copper .30 (might have made things worse)
Check Fuel pressure by driving with fuel pressure kit hooked up to the outlet of fuel filter, pressure was around 65lbs with 15lbs of boost (under the
impression that this is slightly high)
A/F seems to jump up around .3 from 11 under boost when hesitation occurs
No CEL or seemingly other problems.
Will appreciate any suggestions to get to the bottom of this. Friends and Family have subarus so I can swap parts from them if need be. Any help is greatly appreciated!
WilliHaM is offline   Reply With Quote
Old 04-01-2017, 11:33 PM   #2
andyfloyd
Member#: 87587
2002 wrx
could it be coils going bad, would make sense as the higher gears put more load on the engine.
andyfloyd is offline   Reply With Quote
Old 04-02-2017, 12:35 AM   #3
WilliHaM
Member#: 453391
No misfire codes, no blinking check engine light. Still possible?
Old 04-02-2017, 12:58 AM   #4
isurfnj1
Member#: 343367
2002 rotated gt3076
Happened to me like that on my last hybrid set up. So yes. Definitely possible.
isurfnj1 is offline   Reply With Quote
Old 04-02-2017, 01:00 AM   #5
junior1023
Member#: 223393
2015 WRX
Dark Grey Metallic
I had a similar problem. My tuner (etune) told me that he was seeing a misfire on the logs I sent. Even though it wasnt throwing a code of any kind. Replaced all 4 coil packs (they were old anyway, 125,xxx miles) and the problem went away.
junior1023 is offline   Reply With Quote
Old 04-03-2017, 12:09 AM   #6
andyfloyd
Member#: 87587
2002 wrx
On a side note, my coils are getting old and I am thinking of replacing them ( going vf48 soon). Are people just going with OEM coils new to replace? You can find a set of 4 on fleabay ( not OEM ) for 80 bucks but Im assuming they are junk.
Old 04-03-2017, 02:23 AM   #7
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
Is it possible you have a boost leak? Have you checked your grounds and battery terminal connections?
I would get new OEM coils if I was to get any.
monkeyposeur is offline   Reply With Quote
Old 04-03-2017, 11:16 AM   #8
WilliHaM
Member#: 453391
Appreciate the responses, I checked my coilpacks and one of four was the stock coilpack
(probably has the 250k miles like the car) while the others had DE DIAMONDS FK0333,
not sure how much better they actually are but apparently they are.
Replaced my #1 coilpack with another known working one from another 02 WRX and it
boosted strong to redline with higher boost levels and no hesitation. I believe this is the
problem at hand but will report back in a week to confirm.
Old 04-03-2017, 12:48 PM   #9
silvercookie
Member#: 180033
2005 WRX
If it hasn't been said, probably wouldnt hurt to get new 02 sensors and a new MAF, or at least a clean.
silvercookie is offline   Reply With Quote
Old 04-03-2017, 12:49 PM   #10
silvercookie
Member#: 180033
2005 WRX
Also definitely run OEM NGK iridiums. They are good for 400 whp or so. No reason to go with copper or platinum or anything else.
Old 04-03-2017, 01:23 PM   #11
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Definitely sounds like the coil packs are your issue.
How can you make spark plug recommendations when you know nothing about his car?
Samurai Jack is offline   Reply With Quote
Old 04-03-2017, 01:26 PM   #12
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
spark blow out is my guess
Titter is offline   Reply With Quote
Old 04-03-2017, 01:31 PM   #13
silvercookie
Member#: 180033
2005 WRX
How? Because a 20g on a 2.0 isnt making more than 350-375. More so on only 20psi.
And good job telling him what his issue sounded like after he confirmed what the issue was since you are in a pissy mood it seems like.
Old 04-03-2017, 03:42 PM   #14
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Having a tantrum, are we?
No where did the OP state what his mods were other than a 20G? You have no idea what his power levels are.
STD practice is one grade colder plug for every 100HP increase.
350 - 375HP is well above the standard power levels of the EJ205
Old 04-03-2017, 05:10 PM   #15
WilliHaM
Member#: 453391
Yes it's forged internals and all with a decent 20lb+ tune but I don't agree with the idea of different sparks anyway, I'm not tracking the car and do not plan on fouling plugs.
I have seen no evidence suggesting platinum or iridium gives a better charge than copper only that a step or two colder will allow me to run better with the side effect (to my knowledge) being more fouled plugs if driving in low rpms often or for extended amounts of time.
Thanks for both of your contributions though and hope this issue doesn't resurface with a newer coilpack in. Does anyone know where to buy coilpacks?
Old 04-03-2017, 09:45 PM   #16
andyfloyd
Member#: 87587
2002 wrx
Awesome man!!! glad that was the issue. BTW for anyone looking into coils the Cosmo coils are 160 shipped and people seem to love them. They arent OEM but they are somehow cheaper and people are having great luck with them. Im gonna drop a set into my 257k ej205 haha.
Copper plus will actually work just as well, but they dont last as long, platinum will last longer and iridium will last the longest but you really dont see much difference between the 3 as far as power levels go. I do think a #7heatrange NGK is ideal at anything over 300whp.
Old 04-04-2017, 08:16 AM   #17
Samurai Jack
Member#: 21145
2002 Enemy of Aku
There is no evidence that copper / iridium / platinum are any better than the other. Choose the right plug for the application, in the same heat range, and you will get equal performance. As was mentioned, one lasts longer than the other.
Ultimately, you either buy copper ( the least expensive ) or the iridium ( the most expensive ) and you get the same overall service life. You just change copper more frequently. Some people change their plugs every 10000 miles, so copper is the better alternative for them.
I've never had any issues running one step colder plugs in a daily. Plugs run fine and look fine. This is on both 4 & 8 cylinder cars.
When I replaced my coil packs, I bought OEM Subaru from a dealer off of Amazon. I think they were ~ $350 shipped. Just had to do a little shopping around to find the best price.
Old 04-04-2017, 10:12 AM   #18
insaneimpreza
Member#: 83291
1998 RSTi
IAG Stg4 Extreme S366SXE
I had this happen once and mine was an injector clip that wasn't fully seated. Could also be a coil pack connector tho too. Go over all of them quick, at least its easy to start with.
insaneimpreza is offline   Reply With Quote
Old 08-06-2018, 04:33 AM   #19
Psycho-82
Member#: 489746
Just trying to confirm, was the solution the newer coil pack? I'm currently dealing with a similar issue on my 16 Sti... along with a heating issue... but that's for another time.
Psycho-82 is offline   Reply With Quote
Old 08-13-2018, 04:26 AM   #20
subaru_gc8
Member#: 29292
2004 WRX wagon
yep mine did that for a year before the light came on
subaru_gc8 is offline   Reply With Quote
Old 08-13-2018, 04:27 AM   #21
subaru_gc8
Member#: 29292
2004 WRX wagon
I wouldnt think you would have problems yet, the op had a 2002. I would take yours back to the dealer and have them figure it out
