07-20-2004, 11:55 AM | #1 |
Member#: 32339
Vehicle:02 WRX 325whp / 300wtq |
18g with modded stock injectors what to do so I can get it tuned
Hey guys i have this 18g, utec, v2 tmic, walbro fuel pump, all exhaust done with no cats, and modded stock injectors. Was wondering on what to do for tuning this thing so i can drive it to a shop like turbotrix to get tuned... Please help me out
07-21-2004, 01:42 AM | #2 |
Member#: 5362
NWIC
Vehicle:2004 OBS Green |
Without an afr it will be difficult. Set the injector scaling and that will get it close. I started from a stage4+ map and it needed a ton of work. I can't remember exactly atm but I set scaling somewhere between 750-800cc. I had to tweak the 0% column to get the idle good. Once on boost it was dead rich pegging the afr. I had to pull a ton of fuel up top and work the lower load timing. As AZscoobie has said before the txs base timing maps are unusable. I would have to agree after tuning a similar setup to yours. 18g,modded inj,APS DR650,headers,catless exh,walmart pump.
How far do you need to travel to get it tuned ? Have fun take it slow. Shawn |
07-23-2004, 12:40 PM | #3 |
Member#: 32339
ummm
prob about like 30 miles maybe less
Can anyone tell me what this is so i can fix it? | emo_tactical9 | Service & Maintenance | 6 | 05-05-2007 09:57 PM |
Local opinions: drivability of modded stock injectors prior to tune | Panic | Tri-State Area Forum | 12 | 09-29-2006 11:56 AM |
FS/ Unichip. Possibility I can get it tuned for your mods. | japslapr | Private 'For Sale' Classifieds | 0 | 03-13-2006 03:23 AM |
Help! need the name of what I'm experiencing so I can google it. | mr_yellow | Transmission (AT/MT) & Driveline | 9 | 04-20-2005 12:30 PM |
Those with modded stock injectors, how have they been so far? | 03WRXMA | Engine Management & Tuning | 45 | 04-02-2004 12:59 PM |
