05-03-2013, 06:48 AM | #326 | |
Member#: 15451
Vehicle:2016 Accord EXL Navi Lunar Silver |
05-03-2013, 07:07 AM | #327 | |
Member#: 342283
05-03-2013, 09:19 AM | #328 |
Member#: 15451
Bummer for those who want to do the swap. Hopefully SVCdx will have a new connector source sometime soon... Keep the faith!
05-03-2013, 05:36 PM | #329 |
Member#: 294644
Vehicle:2011 WRX Agile Auto DGM 440whp 420wtq |
http://www.ebay.com/itm/OEM-Car-Radi...e164c5&vxp=mtr
Would this one work? Looks the same except for the ti/news button and its sc430 not sc630 |
05-03-2013, 06:58 PM | #330 | |
Member#: 321321
Vehicle:2010 Ford SVT Raptor Tuxedo Black |
http://www.ebay.com/itm/Subaru-Fores...c23862&vxp=mtr I am personally running this exact unit in my 2011. |
05-03-2013, 07:37 PM | #331 |
Member#: 352593
Just placed my order for the one above!
Thought about holding out for an hd version, but I don't have the time to dig and wait for one. |
05-04-2013, 03:07 AM | #332 | |
Member#: 294644
05-07-2013, 02:17 AM | #333 |
Member#: 335561
Vehicle:2011 WRX 5dr Limited SWP |
Mine came with all the pictured connectors. I'm not sure if any of them are functional since I just swapped out my 2011 WRX stock unit with this one. I tried to use the 8 Pin rear view camera connector, but I ended up breaking it when I tried to modify it to tap into the head unit's 6 volt power. I ended up buying one from svxdc instead.
05-07-2013, 11:37 AM | #334 | |
Member#: 321321
Also Freddy, mine only came with the extra wires because there was an exterior blemish on my radio. So they threw those in for free. They are completely unnecessary though as the install uses all the existing plugs in the vehicle. It is 100% plug and play. |
05-07-2013, 11:38 AM | #335 |
Member#: 321321
Stupid double post.
05-07-2013, 12:03 PM | #336 | |
Member#: 294644
05-07-2013, 12:49 PM | #337 |
Member#: 321321
05-08-2013, 03:46 PM | #338 |
Member#: 355741
Vehicle:2013 XV Crosstrek |
Anyone have any leads on a Cm631UD? The Chinese import is a nice alternative but I'm looking for the original HU with HD radio.
05-08-2013, 04:09 PM | #339 |
Member#: 352593
05-08-2013, 04:12 PM | #340 |
Member#: 355741
Another one on ebay is asking for $500 w/ buy it now, bidding starting at $350. Tempting to bid however $500 is too much.
05-08-2013, 08:36 PM | #341 |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
The USDM Forester HU model CP635U1, and AUDM Forester HU model CP235K1 are confirmed to include the line-level mono subwoofer output on the 16-pin socket. You can add a female RCA jack and amp remote turn-on wire to your car's 16-pin aux harness to access that sub out (e-mail me for more info).
I have not confirmed whether the EDM Forester model CP435L1 has the sub out (but it probably does, since that Chinese eBay vendor includes the sub RCA on their harness). It's easy to check: Look for +12V on pin #5 -- that is the amp remote turn-on. Viewing the rear of the HU, the pins are numbered: 8 7 6 5 4 3 2 1 16 ... 9 Aux input is on pins 3, 4, 11, 12. Mic input on pins 1, 2, 9, 10. The Impreza/Crosstrek model CM631UD does not have the sub out. Last edited by SVXdc; 05-09-2013 at 12:09 AM. |
05-10-2013, 07:37 PM | #342 |
Member#: 352593
I'm extremely happy w this radio, except I do have a question.
What in the hell is this wire, and were does it go? I'm not 100% it was plugged into the old, but I certainly don't see where it goes in the new. Everything works 100% as far as I can tell. And the sound is much much better than the old! Tia! |
05-11-2013, 03:20 AM | #343 |
Member#: 335561
You're looking at the stereo chassis redundant ground. It plugs onto the connector sticking out in the middle of the back of the head unit chassis just above the 16 pin connector.
05-11-2013, 06:37 AM | #344 | |
Member#: 352593
What is the redundant ground? And regarding its plug location, do I need to remove the screw that's pictured?? I don't see any opening where it fits pictured. |
05-11-2013, 09:36 AM | #345 |
Member#: 352532
Vehicle:2013 Impreza Sedan |
No need to remove any screws.
It should slide onto the metal tab that's sticking out horizontally from the back of the radio. |
05-11-2013, 09:49 AM | #346 |
Member#: 352593
05-12-2013, 03:51 AM | #347 | |
Member#: 9264
Vehicle:2016 BMW M235i 6MT |
It's exactly what I was looking for. More robust, deeper sound; easy install and OEM fitment; and cheap. |
05-12-2013, 07:21 AM | #348 | |
Member#: 352593
05-12-2013, 11:18 AM | #349 |
Member#: 15451
"OEM 4.3" HD Radio Hidden Menus
Radio off, ignition key to accessory, or on (radio shows "Audio Off") Hold down "6" key Spin the tune knob to the right at least 30 clicks Note that on the 4.3" unit, there are more menus "behind" the first one; in other words, repeating the same sequence after you are in the version number menu takes you to factory test menu 2 (Loudness ON-OFF), and then repeating it again takes you to factory test menu 3 (Eq ON-OFF)" Last edited by MackDaddy; 05-12-2013 at 05:58 PM. |
05-12-2013, 12:56 PM | #350 | |
Member#: 352593
So reported best sound comes w loudness and eq off? I am very pleased w this unit right out of the box, just what this car needed. |
Similar Threads | ||||
FS : 04-07 STi Turboback with hardware/new OEM Subaru gasket | SubeDooS | SCIC Private Classifieds | 1 | 04-14-2011 03:05 PM |
FS : OEM Radios, LW Crank Pulley, Forester Armrest and Rims | johnpaulm1208 | Tri-State Area Private Classifieds | 1 | 04-06-2011 10:32 PM |
Default Brand new never been installed Cobb/Stoptech 332mm BBK for sale | mug23 | Suspension/Brakes/Handling | 3 | 06-26-2008 12:35 PM |
Problems installing 07 radio with aux input and sat radio tuner into an 04 WRX? | ScoobyNubieToo! | Car Audio, Video & Security | 3 | 02-11-2008 08:26 AM |
FS:NY EGT Guage, Rims/Tires 4x100, Rims 5x100, OEM Radio, Forester Tires | singincanary | Private 'For Sale' Classifieds | 5 | 08-30-2005 08:50 PM |
