Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 05-19-2016, 10:05 AM   #1
SaltySeaRabbit
Member#: 434433
2005 Saab 9-2x Aero
Default DIY Blast Plates?
Anyone build any DIY Blast Plates for there 5 speed transmission? It seems pretty straight forward but I have a few questions for those who have done it...
Anyone know how long the fasteners that go through the case have to be?
Anyone know how far off the plate needs to sit off each of the mounting points? Do you think stacking washers to fill these gaps as needed would be sufficient or would I want to weld a spacer onto the plate?
SaltySeaRabbit is offline   Reply With Quote
Old 06-16-2016, 03:51 PM   #2
Bansheeboy11
Member#: 182415
1999 RS
Take the length of the OEM bolt, add the width of the plates/washers/nuts etc and find one that works with that length. As for spacers, id use a solid tube to space out those couple.
Bansheeboy11 is online now   Reply With Quote
Old 06-16-2016, 03:54 PM   #3
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
its not only the plates that add rigidity. the bolts used in moores kits are about 10x stronger than oem.
you could always contact ARP and see if they can make you some if you know the exact specs.
Titter is offline   Reply With Quote
Old 06-28-2016, 12:07 AM   #4
norexyet
Member#: 39149
Grade 8 bolts would be fine. Like the other guy said, take the factory bolt, add the thickness of the plates, etc. Tubing with a close ID to the bolt is fine for spacers. Pretty simple piece.
norexyet is offline   Reply With Quote
Old 06-28-2016, 08:36 AM   #5
rtv900
Member#: 428511
2016 STI
yeah a bushing (tubing that is close if you can't make a proper bushing) is way cleaner than stacking washers, although stacking washers will absolutely do the same job it will just look sloppy.
grade 8 bolts are more than strong enough, if you break them you have much bigger problems than a transmission, your spine and brain will be your priority at that point.
rtv900 is offline   Reply With Quote
Old 03-09-2018, 08:40 PM   #6
blackbeau_ty
Member#: 483156
I'm looking to make these at work on my own and don't have a transmission that is out of a car in order to measure.
What specifications are there for the bolt pattern?
blackbeau_ty is offline   Reply With Quote
