Welcome to the North American Subaru Impreza Owners Club Saturday May 8, 2021
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 04-08-2019, 04:54 PM   #1
REX_WGN
Member Sales Rating: (65)
Member#: 107618
2006 WRX Wagon
2009 FXT
Default 06 WRX parts; Killer B pickup, TIC Bushings, WL RSB & bushings, Grimmspeed Exhaust
Scroll past the list for pictures
Various aftermarket and oem parts here. Full listing followed by all the pictures. All OEM parts fit a 2006 WRX unless otherwise listed. If there is no price next to the part, then let me know what your offer is. I would like to sell locally, but if you are willing to pay for shipping, then I will ship. I can meet you anywhere in or near Queens and Nassau County. Thanks for looking.
Aftermarket
Engine
1) Go Fast Bits Underdrive Pulley Kit, silver, used - $240
2) Samco Upper and Lower Radiator hoses, black, used - $100
Brakes & Suspension
1) Paranoid Fabrications OG Fender Braces, used - $55
2) Whiteline Lateral Link Bushings - ***check out posts # 6 to 11 below***
3) Superpro Lateral Link Bushings - ***check out posts # 6 to 11 below***
4) Superpro Front Trailing Arm Bushings - $55
5) Superpro Rear Trailing Arm Bushings - $50
6) Group N Front Trailing Arm Bushings - $50
7) Group N Rear Trailing Arm Bushings - $50
- offering to press these into oem trailing arms, PM to discuss
9) Whiteline Front Lower Control Arm, Front Bushings - $50
- offering to press these into any of the 04-06 STI caster-adding front LCAs I'm selling, PM for details
10) Whiteline FLCA Rear Bushings KCA375
- will press into transverse link mount for you, PM for details
11) Subtle Solutions 1"-1.5" Lift Kit - $300
- Aluminum version made for the 1998-2008 Forester models / 2002-2007 Impreza models
- used for less than 5K miles, barely a scratch on them
- Includes 2 pairs of the HDPE 1/4" spacers, BOTH front and rear, you so you can adjust the height to your liking from 1" to 1.5" - even lift, rake, super rake, etc.
- willing to entertain splitting the lift kit from the spacers but I rather sell as a complete set
12) Whiteline Rear Swaybar Mount - $70
- fits 2002-2007 WRX and STI
- universal size, meaning you keep your existing swaybar bushings
13) Whiteline Roll Center Kit, KCA313, new - $175
- fits GC, GD, SF and SG
Drivetrain
1) Cobb Front & Rear Shifter Bushings, 5 speed, used - $40
2) Group N 5MT Trans Mount, used <1K miles - $55
Accessories
1) Brand New Lisle T-70 Torx Bit for Tranny Drain Plug, Made in USA
Wheels & Tires
other non-06 WRX parts
1) 05-07 STI Lateral Links, 2 sets ***check out posts #6 to 11 below***
2) 04-06 STI front Lower Control Arms
- caster-adding version, compared to MY07 and JDM STI arms
- includes ball joint cones
- can be fitted with aftermarket front and/or rear bushings, PM me for details as I haven't had time to post pictures and info yet
- I have 3 sets available
3) JDM / 07 STI front Lower Control Arms
4) Trailing Arms - $70
- great condition, minimal rust
- with mounting brackets
- will fit all GD models: impreza, WRX, STI, sedan or wagon
- can be fitted with aftermarket bushings, PM me for details as I haven't had time to post pictures and info yet
5) 07 STI Rear Swaybar with bushings
6) 08-14 WRX/STI aluminum front Lower Control Arms
- Whiteline OG front bushing, new & superseded, Part # W0507
- Superpro rear bushing, Duroball-type, new, Part # DURO3738K
- PM for details
7) Superpro Front Endlinks, 08-14 WRX/STI, Part # TRC4142
8) Kartboy Rear Endlinks, 08-14 WRX/ STI, Part # KB-017-08REAR
9) Eibach Swaybars, 08-14 WRX/STI, Part #7718.320 $360
10) Eibach Lowering Springs, 08-14 WRX/STI, Part # 7723.140 $140
11) 2008+ GR STI power steering pump, used - $160
12) 08-14 WRX & STI Grillcraft Hood Schoop Mesh Grill Insert, black - $90
OEM parts - 06 WRX
Suspension
1) late-GD lateral links, aluminum alloy front pair, steel rear pair $100***check out posts #6 to 11 below***
2) front knuckles/spindles/uprights, 60K miles $200 for the set or $125 each
Engine
fuel pump and misc. parts from upgrade kit
Accessories & Body
1) front bumper beam
2) rear bumper beam
3) horns
4) alternator cover
Drivetrain
1) set: 5-speed Shifter, F&R stay bushings, lever pivot sleeve and bushings
2) Crossmember Bushings
3) Rear differential bushings
Whiteline Roll Center Kit KCA313
REX_WGN is online now   Reply With Quote
Old 04-08-2019, 05:00 PM   #2
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
used Cobb 5MT Shifter Front & Rear Shifter Bushings
Group N 5MT Mount
Old 04-10-2019, 09:57 AM   #3
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Superpro Front Endlinks and Kartboy Rear Endlinks, 08-14 WRX/STI
Eibach PRO-PLUS Kit, 08-14 WRX/STI
Whiteline Rear Upper Control Arm Bushings KCA326
Old 04-11-2019, 10:35 AM   #4
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
oem shifter and steering joint
Old 04-12-2019, 02:31 PM   #5
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
reserved
Old 04-15-2019, 10:52 AM   #6
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
This first post is about how I'd like to sell the links and bushings as well as all the details to make these transactions the easiest, most effective for you as the buyer / installer.
1) Pick which bushings you want
2) Add to WRX Lateral Links (Front Aluminum version)
3) Pick out what hardware you want
I will install the bushings into the lateral links for you, I have a tub of Energy Suspension bushing grease. The ends of the links will be wrapped up before packaging them for shipping.
I can also provide some extra hardware so you don't run into any "oh ****" moments during installation. The long bolt that goes through the knuckle and outer ends of the lateral links are notorious for seizing to any of the bushing metal sleeves. I highly recommend you at least get that from me if you don't have any extra on hand already.
Buy-Back Program
Once you're done installing your new links and bushings , you can reach out to me and I'd be more than happy to buy your used links. Keep in mind I am only interested in the STI links or the WRX ones where the front pair are aluminum. I am also more than happy to buy back the hardware.
Prices do not include shipping.
Please click here for my NASIOC iTrader seller/buyer rating - all positive reviews going back over a decade with about 10 reviews in the last 2 months.
Message me with any specific questions or further details. If you think it may pertain to others, please post here and I will answer here.
Post #7 will list the lateral link bushings offered.
Post #8 will show the WRX lateral links.
#9 will list the available hardware.
#10 will show the work I've done to clean up the links.
#11 will show my process for the bushings installation.
Thanks for reading to this point. Scroll down for the pictures.
Old 04-15-2019, 11:27 AM   #7
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Bushings to pair with Lateral Links - PM for availability
- fits all Impreza models including WRX and STI (GD and GC platforms) from 93 to 2007
- also fits Forester Models from 97 to 2008
Group N Hardened Rubber
Superpro Polyurethane SPF1463K $100
Whiteline Lateral Link Bushings W61382A $90
TurninConcepts Graphite-Impregnated Polyurethane
Old 04-15-2019, 05:25 PM   #8
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
STI sets available - $220 each
05-07 WRX - $100
STI Lateral Links - $220
WRX Set #1 - $100
Old 04-16-2019, 08:58 AM   #9
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Hardware available to purchase
Let me know which ones you want and we can work out a price. I'm not going to charge much. Will offer to buy back.
This is what I have left:
1 x 20560aa011 inner rear washer
1 x 20560aa030 inner front washer
1 x 20550AA010 outer nut
3 x 900335056 outer washer
1 x 20540aa001 long bolt
In addition, I have the following:
2 x long bolts, each with 1 washer, used
2 x bolts and nuts, for the endlink mounting point, wrx steel links, used
Old 04-18-2019, 11:02 AM   #10
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Here's some of the work I put in to ensure the links were in good condition to sell, especially the WRX steel rears.
1) Initial cleaning of the links with a green scuff pad sponge and a solution of simple green and water
2) steel links: chipped off all flaking paint and rust with a flat head
3) steel links: filed down all rust that couldn't be easily chipped off and also filed the inner bores of the bushing housings to make sure they were smooth
4) aluminum links: deburred and filed down all sharp edges
5) washed the links again
6) steel links: sprayed 4 coats of VHT rust converter on the spots that needed them
7) steel links: sprayed them with 3 coats of Rustoleum Universal flat black paint
Next 2 pictures are after finishing the steel links with VHT rust converter
This is after finishing with the 3 coats of topcoat
Up close shot of the finished product.Notice the smoothness of the outer edge and the inner bore
I wish I had pictures of the links when I first got them so I could really show the work I've put in. I was just too busy and in the moment cleaning them up that I forgot to take pictures as I went through the process.
Old 04-19-2019, 09:46 AM   #11
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Here are some pictures of the installation work:
Inner bore of lateral link bushing housings were greased first followed by the inner faces of the bushings
Once both split bushings are installed in each housing, the inner bore for the crush sleeve was greased. Then the outer faces of the bushings were lubed with a thin coat of grease. In hindsight, should've did this part last.
Used a vice bench to install the crush tubes.
Here's a WRX set with Superpro Bushings greased and installed
Old 04-22-2019, 03:12 PM   #12
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Default Sold Parts Archive List
Aftermarket
Brakes & Suspension
TurninConcepts Front Trailing Arm Bushings, Race version, new - $65 SOLD!
TurninConcepts Rear Trailing Arm Bushings, Race version, new - $50 SOLD!
Whiteline Front Control Arm - Lower Inner Rear Bushings, new W53353 - $90 SOLD!
Whiteline Sway Bar Bushings, grease-free, 22mm, brand new W0406-22G SOLD!
Brand New STi Group N Rear Suspension Crossmember Bushings, set of 4 solid metal (rare, discontinued) - $155 SOLD!
Brand New TurninConcepts Front Trailing Arm Bushings, Enthusiast version (rare, discontinued) - $90 w/oem Trailing Arms SOLD!
Whiteline Quick Release Kit, KSB790 - $15 SOLD!
Kartboy Solid Rear Endlinks (KB-017-WRX-R) WITH Brand New Hardware and an extra set of replacement bushings - $110 SOLD!
Hawk HPS 5.0 rear brake pads (HB179B.630), 2,291 miles of street driving (no auto-X/track) - $50 SOLD!
Whiteline Rear Vehicle Essentials Kit - WEK081 - 08-14 WRX/STI - $280
SPC Camber Bolts, adjust up to +/- 1.75deg, #81260, new - $20
Whiteline Lateral Link Bushings, used $40
TurninConcepts Lateral Link Bushings
- race version, Shore 95A medical grade urethane
- fits all Imprezas 97-07 as well as the FXTs that have 4 rear lateral links
- $150
Superpro Front Trailing Arm Bushings - $50 8/26/20
Superpro Rear Trailing Arm Bushings - 8/30/20
TIC Front Trailing Arm Bushings - 9/21/20
TIC Rear Trailing Arm Bushings - 9/21/20
WRX Lateral Links - 9/21
Superpro LL bushings - 9/21
07 STI front LCAs - 9/21
04-06 STI front Lower Control Arms - 9/30
Whiteline FLCA bushings - 9/30
MSI Trailing Arms Motorsports MSISUB02-28-015 11/29/2020
2) Brand New Perrin Transmission Mount, Part # PSP-DRV-150 - $220
- for both 5-speed and 6-speed transmissions. will not fit autos or CVTs
- fits: 04-20 STI, 02-20 WRX, 93-19 Impreza, 04-11 FXT, 05-09 Legacy GT, 13-19 Crosstrek
Whiteline Front Roll Center Adjustment Kit, used, Part # KCA313 - $200
- great shape, 4,300 miles
- new cotter pins provided
- 2 boots were nicked during uninstallation; I replaced all 4 boots with Whiteline Service Kit W0907
- will include an additional WL Dust Boot Service Kit W0907 ($30 value)
Whiteline Rear Lateral Link Kit, new, part # KTA109 - $380 3/12/2021
Cusco Adjustable Trailing Arms, Part # 666 474 T - 3/18
Group N Trailing Arm Bushings - 3/18
MSI Trailing Arms, 1" Drop Correction MSISUB02-28-012 - 4/17/21
Superpro front TA bushings 4/17/21
Drivetrain
Group N Engine Mounts 8/26/2020
Kartboy Front and Rear shifter Bushings traded 10/6/2020
Beatrush Front Shifter Bushings 10/9/2020
Brand New STI JDM Group N Transmission Mount 6MT, part # ST410224S040 3/2/21
Group N Engine Mounts, new 3/2/21
TurninConcepts OG Transmission Crossmember Bushings, used <1K miles - $25 4/22/21
TurninConcepts Rear Diff Mount Bushings, race version, used <1K miles - $25 4/22/21
Kartboy Rear Subframe Outrigger Bushings, race version, used <1K miles - $25 4/22/21
Whiteline Steering Rack Bushings, new, KSR206 $55 4/22/21
Verus STI Billet High-Strength Steel Clutch Fork, Like-New - 4/27/21
Engine
GrimmSpeed Turbo Heat Shield, original and brand new - $55 SOLD!
Killer B Motorsport Ultimate Oil Pickup EJ25 $130 SOLD!
Grimmspeed EWG Uppipe w/ dump tube, 38/40mm V-band - New SOLD!
Port and Polished OEM Exhaust Manifolds - $120 local sale, $135 shipped SOLD!
Perrin lightweight crank pulley, 63K miles - $65 SOLD!
Cobb 3-Port Boost Control Solenoid #712750, new $100 shipped 7/31/2020
GrimmSpeed HiFlow Exhaust Manifold (EM) Crosspipe - Used 8/26/2020
- I will include 2 new Grimmspeed EM-to-Xpipe gaskets
GrimmSpeed HiFlow Exhaust Manifold (EM) Crosspipe - New
- with Thermal Ceramic Coating in black
Grimmspeed Electronic Boost Control Solenoid 3-Port - 08-20 STI 9/10/2020
IAG Radiator Stays, used pair, IAG-ACC-2502SL - $49 10/18/2020
- includes original SS hardware and grommets
- fits 08-14 WRX STI
Grimmspeed Used Uppipe Feb/2021
1) Killer B Motorsport Aluminum Oil Pan Package, new - $520 3/2021
Accessories
Grimmspeed Alternator Cover & Radiator Shroud w/ Tool Tray 02-07 impreza/WRX/STI SOLD!
3/16" wheel spacers - $5 SOLD!
Fumoto Drain Valve - $10 8/19/2020
08+ STI Power Steering Pump, new part # 34430FG040 - $300 9/8/20
Password JDM Dry Carbon Exhaust Shroud - 2/25/21
Defi Racer Boost Gauge, White, discontinued, new, Part # DF06503 - $150 3/22/21
Wheels & Tires
ARP 100-7716 Wheel Stud Kit, 3 packs, new - 3/16/21
OEM parts - 06 WRX
Wheels & Tires
oem wheels $90 3/22/21
Suspension
U-frame chassis brace SOLD!
Trailing Arms with upgraded bushings - $90 SOLD!
Lateral Links, set of 4, front aluminum ones $250** SOLD!
steering wheel
7/24/2020 WRX Sedan Lateral Links, set of 4, front aluminum ones $100
Engine
air pump SOLD!
Accessories & Body
Dead Pedal SOLD!
Brand New Fog Light Switch (83001FE000)
Brand New 2002-07 Impreza Rear Black Molded Rubber Floor Mats (J5010SS400) - $20
Drivetrain
5MT Shift Knob SOLD!
steering joint - 11/2/2020
other oem parts
Bugeye wagon Front and Rear Bumper Covers $80 each
05-07 STI Lateral Links, all 4 aluminum alloy late-GD lateral links $220
05-07 STI Lateral Links set #2
07 STi struts $200 8/29/2020
07 STI Rear Subframe 8/30/2020
08+ STI PS Pump 9/8/2020
08-21 STI shifter assembly - traded 3/23/21
set of 4 TPMS sensors, off of an 11-14 WRX, Model # SMD3MA4 - $100 3/23/21
Old 04-24-2019, 03:10 PM   #13
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Bump for today thanks
Old 04-25-2019, 09:42 AM   #14
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 04-28-2019, 07:12 AM   #15
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 04-29-2019, 04:41 PM   #16
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 04-29-2019, 10:59 PM   #17
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
added pictures of the Perrin pulley
Old 04-30-2019, 12:58 PM   #18
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 05-01-2019, 09:16 AM   #19
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 05-02-2019, 04:19 PM   #20
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 05-03-2019, 06:24 PM   #21
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 05-04-2019, 09:54 AM   #22
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Old 05-04-2019, 04:20 PM   #23
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
Wheel spacers sold!
Old 05-06-2019, 11:21 AM   #24
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
bump for today, thanks
Old 05-07-2019, 09:48 AM   #25
REX_WGN
Member#: 107618
2006 WRX Wagon
2009 FXT
bump for today thanks
