Welcome to the North American Subaru Impreza Owners Club Monday May 17, 2021
Old 04-22-2021, 12:37 AM   #1
pugnaciouspete
Member#: 523826
Default Piston Ring and head gasket failure
Got into a perdictament today, tuner told me my 2014 STI has a #4 Piston failure and a head gasket failure. Currently my car is running an AP w/ pro tune and Cobb Turboback exhaust. They are doing a tear down to see what else is going on.
I am trying to figure out what I should do, go OEM or go with a built motor. I don't have power goals, other than wanting to have some fun with the car. My primary goal is reliability and relatively normal maintenance. Can anyone offer any advice on what I should do? Below is what my tuner recommended I do while I am in there making changes.
Start with:
IAG Stage 2.5 closed deck short block
Cobb Intake
IAG or Cobb Fuel Lines and Rails.
Cobb/ID Fuel Injectors (1050x or 1300x2 depending on power level)
Fuel Pressure Regulator
Fuel Pump
EBCS
AOS
Later:
Bigger Turbo
Turbo Inlet
MAP Sensor
Ethanol Set up
Header
External Wastegate
pugnaciouspete is offline   Reply With Quote
Old 04-22-2021, 11:06 AM   #2
wobbletop
Member#: 11652
'18 Focus RS Red
'70 Porsche 914/6
Stock block. Remove pistons to check ring gaps. Have fun.
wobbletop is online now   Reply With Quote
Old 04-24-2021, 03:14 AM   #3
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
It appears that the new RA blocks are holding up pretty well. If you have no power goal in mind and want long term reliability thats probably your best optioni.
alexmartynyuk is offline   Reply With Quote
Old 04-24-2021, 08:07 AM   #4
pcampbell
Member#: 437670
2005 2.5 SC OB
I think a valid question is why did it blow up? If you put a new stock shortblock in and it blew up your last stock shortblock, what is it going to do to the new one?
IAG Stage 2.5 closed deck short block is way overkill for anything less than ~500whp I think.
pcampbell is offline   Reply With Quote
Old 04-24-2021, 11:37 AM   #5
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
I'll take "What causes detonation and lean misfire on a tuned Subaru?"
