Welcome to the North American Subaru Impreza Owners Club Friday May 14, 2021
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 10-17-2006, 07:08 PM   #1
Aspen_2.5RS
Member Sales Rating: (473)
Member#: 3310
Default FS: 89 Plymouth Colt with 4g63 swap FAST!
1989 Plymouth Colt w/ 122k miles
Clean title
w/ 94 laser 4g63 engine and transmission
Wiring harness and Eprom ECU from the 94 laser also
Engine and trans had ~130k miles on them before engine was refreshened
Engine has been freshened up with new rings and bearings (torn down, baked, washed, honed, and repainted). The balance shafts were removed and the head was rebuilt. Approximately 3300 miles since the rebuild. The engine bay is almost clean enough to eat off of.
Engine:
Fidanza cam gears
ARP head studs
New OEM timing components - belts, tensioners, and water pump
New OEM headgasket
2g ported exhaust manifold
Evo III 16g turbo
RC 550cc injectors
MAF-T setup
Apexi S-AFC
Eprom ECU ready to be chipped
Fmic 26"x6"x3" (satin black)
3" GM MAS
TurboXS H34 bov
2g throttle body elbow
3" mandrel bent downpipe into a supertrapp muffler that ends just before the gas tank (it's pretty loud)
New ngk plugs, wires, and aluminum spark plug cover
New damper pulley
Audi full size radiator with slim fan
Transmission:
ACT 2100 clutch w/ resurfaced flywheel
Equal length turbo axles
New OEM shift fork, pivot ball, and plastic sleeved throw out bearing
Earlier dsm diff with proper spline count for turbo axles
Exterior:
The car was originally red, but repainted black including the engine bay, door jambs, and rear hatch. The engine was out while the engine bay was painted so everything was removed but a few hard lines and those were covered and painted behind. The antenna hole on the passenger fender has been shaved as well. The paint looks really good.
Suspension:
New KYB GR-2's on awd dsm springs
New wheel bearings and seals on all 4 corners
New front ball joints and tierod ends
Front brakes were upgraded with larger rotors and dsm calipers
Rear drums were converted over to discs from a turbo mirage/colt
All the rotors were replaced with slotted, zinc coated new rotors
Road Race Engineering stainless steel brake lines
Larger brake booster and master cylinder from a 92-95 Elantra
All calipers were torn down rebuilt and then repainted
15"x6.5" 6 spoke satin black wheels w/ Hankook 205/50/15" tires (~3300 miles)
Interior:
Turbo mirage/colt seats
Tilt column/telescoping 3 spoke turbo wheel
Canadian spec gauge cluster with the tach (odo was swapped over to keep the mileage correct)
New leather 2g dsm shift knob
Radio was removed and a Greddy Profec B Spec II and VDO boost gauge sit in it's place
The S-AFC is mounted above the center vents
Miscellaneous:
Fuel tank replaced and new Walbro 190lph pump
35% tint all around
no a/c and no p/s
The car is fast and super light. I haven't weighed it myself, but estimate ~2400lbs. Guesstimated hp is around 300. If slicks were used it should be in the high 12's, I'd think. It's going to get me in trouble if I keep it. It's not perfect, there are a few small cosmetic things wrong with it, but I won't go into detail unless someone is really interested in it.
Price: $6500 o.b.o.
Reason for selling: I need something a bit more tame for daily driving
Aspen_2.5RS is offline   Reply With Quote
Old 10-17-2006, 07:22 PM   #2
goingfor400HP
Member Sales Rating: (9)
Member#: 37375
Wow, that's different. Definitely a cool car to drive fast on weekends and scare the neighbors with.
goingfor400HP is offline   Reply With Quote
Old 10-17-2006, 07:24 PM   #3
SiNzz
Member#: 92264
Damn, if you were on the west coast I would os buy this as a cheap, fast ridiculous commuter
SiNzz is offline   Reply With Quote
Old 10-17-2006, 07:26 PM   #4
ShaggyGT
Member Sales Rating: (27)
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Now that is a SLEEPER!!!
ShaggyGT is offline   Reply With Quote
Old 10-17-2006, 08:55 PM   #5
tacomaprime
Member Sales Rating: (7)
Member#: 70572
2018 Kona
Pulse Red
dude, thats ****ing awesome. My sister used to have one of those. Didn't know you could throw a 4g63 in them.
tacomaprime is offline   Reply With Quote
Old 10-18-2006, 11:18 AM   #6
Aspen_2.5RS
Member#: 3310
ttt,
Cam
Old 10-18-2006, 02:02 PM   #7
beecha91
Member Sales Rating: (16)
Member#: 55009
Trade for a clean 99 ZX2 5spd with all the maintence done. Cars awesome on gas. Is currently my dd, I could give you lil money on top of the car. Let me know.. thanks
Don-
beecha91 is offline   Reply With Quote
Old 10-18-2006, 02:26 PM   #8
Aspen_2.5RS
Member#: 3310
I appreciate the offer, but I'm just looking for the money. I'm suppose to pick up my friend's accord as soon as this sells.
Cam
Old 10-21-2006, 01:33 AM   #9
Aspen_2.5RS
Member#: 3310
Sold.
Cam
FS: 1993 Plymouth Colt (SUPER LOW MILES!) QwikEVO AKIC Private Classifieds 5 05-07-2010 10:50 PM
FS: 2003 WRX Wagon with STi Swap/6spd jdadour SCIC Private Classifieds 6 07-29-2007 02:11 PM
FS: 2003 WRX Wagon with STi Swap/6spd jdadour Private Vehicle 'For Sale' Classifieds 115 07-28-2007 02:40 PM
EG Civic with 4G63 swap on eBay. :eek: rice h8r Off-Topic 20 06-30-2006 04:16 AM
FS: 2k Civic Si with ITR swap, AND my 1998 S10 sccaracer Private Vehicle 'For Sale' Classifieds 9 12-17-2004 08:35 AM
