Welcome to the North American Subaru Impreza Owners Club Saturday May 15, 2021
Old 03-03-2011, 04:53 PM   #251
Dutch Devotion
Member#: 145985
The gamatiwheel+shaft+billetwheel efr rotational assembly most lilely has a (much) lower inertia than a Garret total rotating assembly therefore spooling faster and being the most responsive of the both.
On the other hand, during gearshifts, you like inertia to keep the assembly spooling. With the EFR assembly lacking this inertia, this is where the special BOV comes in (and the special low friction bearings as well), alowing the compressor to directly run in a "zero delta pressure" environment, therefore taking away as much braking force on the roatting assembly as possible.
Above is my opinion and should not be read as fact
E
Dutch Devotion is offline   Reply With Quote
Old 03-03-2011, 07:21 PM   #252
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
I love all of the engineering talk. I just find it naive to assume that the BW engineers, you know the people PAID to develop this turbo, did not take all of this into account before their first mock up was even made.
aboothman is offline   Reply With Quote
Old 03-03-2011, 07:56 PM   #253
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I find it naive to assume that Garrett didn't do it either
Old 03-03-2011, 08:05 PM   #254
reid-o
Member#: 103631
2004 STI
Gray
I do agree with your implied point that a design improvement in one facet of a system (titanium/lighter wheel) may not result in a large change in outcome (spool), as there are other discrete systems at work that affect outcome.
But if you want to get technical about it, BW is not claiming a large improvement in outcome. They're just stating that there are many design improvements. The improved outcome claims are coming from elsewhere.
reid-o is offline   Reply With Quote
Old 03-03-2011, 08:22 PM   #255
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
Knowing that the turbocharger is a system and Garrett only felt the need to redisign one part of the system says something too, I just don't know what yet
Either they desigined the compressor wheels to match well with their existing turbine wheels or they just don't give a rats ass about the compressor/turbine relationship.
Old 03-03-2011, 08:45 PM   #256
Karl S.
Member#: 30871
The only reason a big manufacturer "improves/redesigns" something is because there was something majorly wrong with the part, or, (the main reason is) it will save them money by using cheaper parts (more profit) but they will keep to the "it is better" crap. It is all about the almighty $$$$$$$$
Karl S. is offline   Reply With Quote
Old 03-03-2011, 08:56 PM   #257
reid-o
Member#: 103631
2004 STI
Gray
It depends largely on the design paradigm of the company. In some agile design paradigms, companies fund experimentation and innovation and use that flexibility to improve products. They see it as investment in the company. More traditional design paradigms is as like you said...fix it if it's broke. It simply depends on the design/development paradigm.
To bring this back on topic however, I think a possible test of the EFR turbine (to look at inertia/mass) is to log deltas in turbine speed and compare that data to the GT30r (assuming you could collect it) because the spool is dependent on other systems coming into play. But then you could compare the rates of acceleration etc... and clearly say that X accelerates faster than Y. The unfortunate part is that the difference in acceleration may not have a large effect on spool. But then it would at least come closer to answering the question of whether the turbine weight affects the accel. and even then you wouldnt be attribute the difference directly to the turbine weight.
To do that youd have to replicate a heavier EFR wheel and measure.
Old 03-03-2011, 09:03 PM   #258
crashtke
Member#: 120912
Jeff is the new actuator out yet? Or are you "engineering" the existing one?
crashtke is offline   Reply With Quote
Old 03-03-2011, 09:43 PM   #259
MrLith
Member#: 274895
In terms of rpm.delta - looks a little like the EFR7670 can support the same flow/pressure ratio as a GTX3076R using a lower shaft speed.... at least from a couple of minutes of glancing over the maps. I could be wrong, but thats the initial impression.
Again, there are so so many variables to consider here and the thing most worth remembering is what defines the performance isn't what makes the turbo spin faster or what makes the boost needle climb quicker on the dyno - its what ultimately results in making the car physically go quicker. To me, thats what it looks like Borg Warner were focussing on when they developed these turbo.
I'm going to put my neck out and say my bet is that on the dyno plot the EFR7670 is going to be equal to (equal to = +/- 3hp for error) or higher than the GTX3076R for at least 80% of the dyno plot - so long as a comparable boost level can be maintained with the internal wastegate. Any other bets?
MrLith is offline   Reply With Quote
Old 03-03-2011, 11:30 PM   #260
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
The only reason a big manufacturer “improves/redesigns” something is because there was something majorly wrong with the part, or, (the main reason is) it will save them money by using cheaper parts (more profit) but they will keep to the “it is better” crap. It is all about the almighty $$$$$$$$
Those are the lower teir (aka ****ty) companies you speak of. I work in a technology driven field and if companies don't inovate, they don't get new business plain and simple. If you're not moving forward you will get passed by.
Old 03-03-2011, 11:55 PM   #261
[email protected]
Member#: 264595
...+1
raffi@full-race is offline   Reply With Quote
Old 03-03-2011, 11:55 PM   #262
piddster
Member#: 144285
1993 UHEV Legacy
Good points have been made about moment of inertia. Even though the inner race is quite large, it is close to the axis of rotation. The only real way to know the difference between Garrett and BW is to measure it, which I'm sure no one here has the capability to do. So stop bitching at each other already.
What I want to see is dyno plots of both similar turbos where the engine is ran up to about 4k under vacuum, and then the throttle is stabbed. I want to see transient response that is not shown on a typical plot from 2k to 7-8k. The time it takes to get from 20 in of vacuum to 20 psi is what I'm more interested in. Power shmower. I size the wheels according to what I need.
piddster is offline   Reply With Quote
Old 03-04-2011, 02:23 AM   #263
R1Z4T
Member#: 176105
1912 Alco
Red
How about we stop talking dribble & repeating things over & over and wait for OP to post some real results ?
Sunyvale represent.
R1Z4T is offline   Reply With Quote
Old 03-04-2011, 02:55 AM   #264
Phatron
Member#: 36033
CEO PhatBottiTuning
Efr represent
Old 03-04-2011, 05:13 AM   #265
Dutch Devotion
Member#: 145985
i'm not intrested in psi times
i'm intrested in times to reach from 50 to 300hp at the crank, that's ahat counts
20 psi from the efr might flow more than 20 psi of the GTX, or vice versa off course
do "my test" a 100times for turbo and turbo b and you know something
same counts for a vacuum-fullboost-vacuum-fullboost sequence x 100 on a motor test setup, and you can just use the stopwatch to measure overall time who performs the best in this field
measure measure measure
Old 03-04-2011, 05:50 AM   #266
blakjak00
Member#: 225046
2000 2.5RS
Blue Ridge Pearl
Subscribed !
blakjak00 is offline   Reply With Quote
Old 03-04-2011, 07:52 AM   #267
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
What do you mean? I assuming you are speaking to the WGA, which BW already offers 3 variants. I don't see the need for the aftermarket to provide another solution. Perhaps you're refering to something else...
thefoos is offline   Reply With Quote
Old 03-04-2011, 08:07 AM   #268
R1Z4T
Member#: 176105
1912 Alco
Red
his post was more understandable than your abbreviations. WTF is WGA ?
You have never heard of a wastegate actuator, and since when did people speak to them ?
Stop trying to be impressive
Old 03-04-2011, 08:51 AM   #269
crashtke
Member#: 120912
I was unsure if they were released yet as we did not get any options when we purchased the two EFR turbos that we bought and have not seen them offered separately. By engineering one, I did not mean making an aftermarket solution, I meant "modifying" the one they had.
Old 03-04-2011, 09:03 AM   #270
R1Z4T
Member#: 176105
1912 Alco
Red
What is the stock EFR7670 actuator rated at ?
From a fabrication point of view, it's not impossible to make a foreign item fit.
The max achievable pressure shown is pathetic/insulting! hopefully they pull their heads in & solve this
Old 03-04-2011, 09:30 AM   #271
crashtke
Member#: 120912
20 psi max, but the issue is it starts to crack open too soon, slowing the rate which boost is made. I wonder if throwing a manual on there would change anything or if it would just blow open? My guess is the spring is just too soft and it would blow open. It would be nice to have a choice of actuators (without additional cost) when purchasing the turbo, much like when you buy an external wastegate.
Old 03-04-2011, 10:54 AM   #272
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
If you met me you would realize how impressive I am...
I have one of the high pressure WGA's on order with my 7064. I'm assuming they are available...
Old 03-04-2011, 11:05 AM   #273
iheartwrxSTI
Member#: 169824
2005 STI
red and widebody
I spoke to Raffi yesterday and he said it would take about 4 days to get.. I will probably order one today but am still in the process of break in on a new motor so it really is not a big deal. i am excited to get some 8374 numbers posted up!
iheartwrxSTI is offline   Reply With Quote
Old 03-04-2011, 11:19 AM   #274
crashtke
Member#: 120912
On order and in stock ready to ship are two totally different things Plenty of folks have the twinscroll internally gated 8374 efr on order, but I have yet to hear of one ship out yet! But good to hear these are ready to go. I will have to get one ordered for the car we have here real soon.
Old 03-04-2011, 11:40 AM   #275
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Yep, I hear you. From what I understand, the only thing holding up the TS's are the turbine housings, so I'm assuming all of the other parts are readily available.
For me, its just on order because I ordered a TS, so I don't need the high pressure WGA until I have my turbo as well...
To extend this discussion a bit, have you considered running a restrictor orifice to reduce the pressure to the WGA? The medium pressure WGA is good for ~16psi cracking pressure. Just a thought if you don't have access to a high pressure WGA...
Borg Warner Registry, post your BW setup & #'s here. UpSideDownDesi Proven Power Bragging 3174 03-07-2021 04:29 PM
Borg Warner S256 and S362 Turbos AXA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 49 12-01-2015 09:18 AM
Borg Warner Turbos. Who is running them? DemiSlayer Built Motor Discussion 48 03-22-2010 11:50 PM
small borg warner turbo vid. mattjk Off-Topic 13 07-05-2006 04:25 PM
