Welcome to the North American Subaru Impreza Owners Club Tuesday May 18, 2021
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum > South East Region Private Classifieds
Old 08-21-2018, 09:49 PM   #1
cDorch
Member Sales Rating: (11)
Member#: 301166
02 WRX V7 Swap
Default FL: Full Partout - 2002 WRX WRB FULL JDM STI Swap RUST FREE
Parting out my 02 WRX with V7 EJ207, 05 STI 6 spd, JDM R180, Brembos etc. Motor was perfect was making 385whp with a JR tune, and I had it out and apart to do ARP headstuds so I could turn up the boost, but other priorities happened. Decided to just part the whole thing to get more money out of it for a house.
If you don't see certain performance or appearance items listed that probably means they are sold, otherwise feel free to ask about anything else you might need!
Pictures of for sale items: https://drive.google.com/open?id=1Qo...2kbRCXpkInU2vE
Engine (55k miles):
- V7 EJ207 Heads – 700
- V7 EJ207 Shortblock – 700
- Full Manifold Assembly fuel rails, harness – 500
- Red Perrin Inlet – 150
- Genuine Fujitsubo Header/Uppipe – 600
- JDM Power Steering cooler w/ res - 50
- EJ207 AVCS Cam Gears – 250
- EJ207 Timing Cover set – 60
- EJ207 AC Compressor – 80
- PS pump – 75ea
- Alternator – 50ea
- 06 Sti Oil Pan/Baffle – 40
- Sti Oil Cooler – 60
- V7 EJ207 ECU – 180
- 02 WRX USDM ECU - 80
- OE Subaru Front O2 – 50
- OE Subaru Rear O2 – 30
- Sti Crank pulley – 30
- Walbro 255 – 40
- Misc AC lines – 40ea
Drivetrain/Brakes:
- 2005 Sti Transmission (w/stubs, cross members, fork, pin) - 2200
- DCCDpro manual controller (needs switch) – 120
- JDM R180 (Clutch LSD) – 500
- Sti Axles - 150ea
- 5x100 Brembo/hub swap complete – 1200
- Sti Driveshaft – 80
- Clutch Hydraulics (MC, line, SC) – 60
- Brake boost, MC - 35
Suspension/Steering:
- ISC N1 Street Comfort Coilovers w/Rear Camber plates and extenders - 750
- Sti aluminum control arms – 200
- Steering Rack – 120
- PS Res w/line – 40
- Steering column with ignition/key – 60
- Rear Subframe w/ lateral links – 100
- Front subframe – 100
Exterior:
- JDM Sti Scoop WRB – 150
- Mirrors WRB – 40ea
- Tail lights – 30ea
- JDM Sti front fenders WRB – 120ea
- 02-05 Sideskirts WRB – 100
- Doors (complete minus door cards) – 150ea
- WRB Sti Fog light covers – 150
- WRB tow hook cover – 20
- WRB Fuel door – 30
Interior:
- Ver8 Spec C steering wheel w/ clock spring - 250
- WRX embroidered floor mats – 60
- STI blue floor mats – 80
- 02-07 OEM Subaru all weather mats - 40
- 02-03 WRX seats - 180
- 02-03 Door cards - 80
- 02-07 Black carpet - 100
- Clutch/Brake pedal assembly - 70
- Gas Pedal – 40
- Autometer Boost gauge - $20
- Complete OEM Subaru “Carbon Fiber “ Trim set – 150
- Sti 6spd knob – 35
- Complete dash w/ airbag – 150
- Complete 02 WRX Chassis Harness w/ AVCS wiring – 250
- Seatbelts full set – 50
- Wiper/Signal Assembly – 40
- Ebrake Handle – 20
- Lower Driver Dash w/switches – 30
- Lower Center Dash – 30
- Glovebox – 50
- Shift boot assembly – 25
- Ebrake Console section – 30
- Full Console w/armrest extension – 40
- HVAC Controls – 40
- 6CD Changer Radio – 40
- Steering column upper/lower trim – 25
Miscellaneous:
- JDM OEM HID ballasts with pig tails – 100
- 02-03 Complete core support – 80
- 02-03 JDM lightweight bumper beam - 80
- 02 WRX Fuel Pump Controller – 40
- ABS pump – 30
- Heater Core - 50
- Front Chassis Harness withfull fuse box (partially cut) – 75
- Wiper Motor Assembly – 75
- Trunk/Gas Door release cables – 20
- Hood Latch Release Lever – Free
- Hood hinge set – 15
- Cowl Cover – 40
- Washer Bottle w/ motor – 20
- Wipers w/good blades - 25
- Evap canister and all hoses etc. – 40
cDorch is offline   Reply With Quote
Old 05-04-2021, 12:53 PM   #2
A_Bug03
Member#: 376624
2003 WRX
02-03 JDM lightweight bumper beam still available?
A_Bug03 is offline   Reply With Quote
