Welcome to the North American Subaru Impreza Owners Club Thursday June 21, 2018
Old 02-19-2017, 10:18 PM   #1
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2007 1500HD
Need Brakes? 919.420.0021
Default KNS Brakes prototype Big Brake Kit
So we did a thing.
Caliper - Wilwood 6 piston Forged Superlite - radial mount.
http://www.wilwood.com/Calipers/Cali...emno=120-13235
Pad Shape - 20mm thick Wilwood shape 7420 or similar. Wide annulus versions available.
http://ecat.ferodoracing.com/index.p...FRP3116#detail
Rotor - 325x32 mm DBA rotor ring - non floating.
http://www.knsbrakes.com/c/car-serie...-+Single+Rotor
Hat - Made by TMI at the Ariel plant in South Boston VA
http://www.tmiautotech.com/
STi front rotors should also fit. If wheels clear Brembo's - then these should clear.
The second round of prototypes are due this Friday.
KNS Brakes is offline   Reply With Quote
Old 02-19-2017, 10:41 PM   #2
Crescent1101
Member#: 463252
2005 Saab 9-2x Aero
Those are pretty!
Crescent1101 is offline   Reply With Quote
Old 02-20-2017, 01:28 AM   #3
jamal
Member#: 71875
What would they offer over the existing wilwood kits?
jamal is online now   Reply With Quote
Old 02-20-2017, 09:44 AM   #4
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
More details please. Rotor size? Pad type? What will it fit?
Old 02-21-2017, 08:49 AM   #5
KNS Brakes
Member#: 125739
2007 1500HD
I added some details
Old 02-21-2017, 09:01 AM   #6
Chuckable
Member#: 447566
2017 WRX
Great to see something like this! Like Jamal asked, how are these different than existing Wilwood kits from TCE or RR Racing?
And what's the expected pricing?
Chuckable is offline   Reply With Quote
Old 02-21-2017, 09:15 AM   #7
KNS Brakes
Member#: 125739
2007 1500HD
I have not looked at those other kits much.
I think the key features are:
-20mm thick wide annulus pads. In race friction they are only about $200 per set or less depending on the brand.
-Known extremely durable KNS/DBA rotor ring. The one you are looking at is right off my 450WHP C5. C5's destroy brakes like no other.
-Fits where Brembo's do. Still need more confirmation there.
-Will work w/ a stock STi rotor. (The stock rotor is a bit too wide in the friction surface but it will work)
That's all we have for now.
Old 02-21-2017, 10:36 AM   #8
Chuckable
Member#: 447566
2017 WRX
Thanks for the reply! Looking forward to hearing on the price.
What are the rotor dimensions?
Old 02-21-2017, 11:52 AM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Says right there in post #1
Samurai Jack is offline   Reply With Quote
Old 02-21-2017, 11:56 AM   #10
Chuckable
Member#: 447566
2017 WRX
Doh 🤦 Thanks for correcting me.
Old 02-21-2017, 12:01 PM   #11
bunz559
Member#: 388585
2015 wrx base
ISM
Nice! Will this kit come with brackets? And is it expected to be more cost effective than STI Brembos?
bunz559 is offline   Reply With Quote
Old 02-21-2017, 12:09 PM   #12
jvangelder
Member#: 358395
05 STI
White with Rubber marks
Is the caliper an off the shelf unit or modified?
jvangelder is offline   Reply With Quote
Old 02-21-2017, 01:56 PM   #13
jamal
Member#: 71875
I would guess off the shelf with 1.625/1.125/1.125 inch pistons. I happen to have been working on a new brake math spreadsheet and already had this caliper in there. Brake torque would work well for an STi, LGT, or 15+ WRX, but maybe be a little forward biased for an older car.
Being able to use a stock rotor is definitely convenient. Having to safety wire all the bolts on willwood kits a few times has made me want to avoid them. I don't know if you even still have to do that.
Do the custom hat/dba rotors have any float in them
Old 02-21-2017, 11:19 PM   #14
KNS Brakes
Member#: 125739
2007 1500HD
A few links added on the pad shape and rotors etc.
Old 02-22-2017, 12:17 AM   #15
Crescent1101
Member#: 463252
2005 Saab 9-2x Aero
I want some nice brakes for my Saab
Old 02-22-2017, 09:13 AM   #16
Chuckable
Member#: 447566
2017 WRX
Question
KNS, can you comment on the differences between your prototype kit and the one from RR Racing? This time I'm providing a link: http://www.rr-racing.com/Subaru-WRX-...swrxfbk014.htm
Here's a pic of their kit:
They offer different "stages" and it appears to fit FRS/BRZ as well as WRX:
The top of the line RR Racing kit goes for $1895.
I've spoken to you guys over the phone and you've always been super helpful, and with your knowledge of brakes, I'm betting that your system will be better and/or cheaper, so looking forward to learning more details.
Old 02-23-2017, 09:38 AM   #17
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
Wow! That kit is very reasonably priced. Wonder if they're using OEM rotors on the "stage 1 and 2" kits.
uofime is offline   Reply With Quote
Old 02-23-2017, 12:58 PM   #18
jamal
Member#: 71875
Yeah, some of the kits use the stock STI rotor, others use a wilwood 328x32 part.
Old 02-23-2017, 02:11 PM   #19
KNS Brakes
Member#: 125739
2007 1500HD
Front brake kits should fit any Subaru in front. There are a few things to look out for on the knuckle like the blob on sti knuckles and the switch to bolt in bearings but that's pretty minor.
I'd rather let RR's stuff speak for itself. Looks like they have done a good job.
What we have:
DBA rotors - non floating. They are very durable and are solid mounted so you can use them anywhere. Replacement rings w/ hardware are under $200. You would have to murder an NA BRZ to hurt the rotors.
Pads - We will use a wide annulus WW shape in 20 mm thick pads. The pad has a radial depth of 50mm versus 41mm for the "WW" 7420 shape. Cobalt Friction, Carbotech and Ferodo make this shape. The 41mm pads fit as well and those are available from many other pad manufacturer's.
I want it to:
Fit
Not wear out fast
Work well
Be reasonable to maintain.
Retail goal - Still TBD but well under $2k
-Ken
Old 02-23-2017, 05:54 PM   #20
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Cool would be if any fit my 98 Legacy GT with 16 x 7" Impreza RS rims....... not likely though.
Charlie-III is online now   Reply With Quote
Old 02-23-2017, 07:32 PM   #21
KNS Brakes
Member#: 125739
2007 1500HD
You need 4 pots/2 pots.
Unless it's not a normal LGT.
Old 02-23-2017, 07:40 PM   #22
jamal
Member#: 71875
Yeah the 4-pots are about the biggest brake that will fit under those wheels. Maybe the 299mm ap racing essex kit would with some spacers.
I'd be curious if these would fit under stock 17" sti wheels. Guessing not since they are the wide calipers.
Old 02-23-2017, 09:01 PM   #23
Chuckable
Member#: 447566
2017 WRX
If it ends up fitting where Brembos do then the STI wheels should work.
Old 02-23-2017, 09:04 PM   #24
Chuckable
Member#: 447566
2017 WRX
In one of the first posts Ken says he believes they'll fit where Brembos do, but is waiting on confirmation.
Old 02-24-2017, 07:22 AM   #25
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If these are anything like the Brembos, and it sounds as if they are, then they will not fit using 16" wheels.
Won't fit 7" width either, unless of course you want to use some crazy spacers, which I would never do myself.
