Welcome to the North American Subaru Impreza Owners Club Thursday July 19, 2018
Old 09-13-2017, 11:41 AM   #1
vic2340
Member#: 469934
Default Squeaking clutch pedal and other Issues
I have a 2002 Subaru Impreza TS stick shift. I am having some odd problems with the clutch, first of all it squeaks. Sometimes it's very loud and annoying, other times not at all. I greased the slave cylinder ball, but that didn't do anything. The noise is very frustrating and annoying, it comes and goes and makes the clutch feel not smooth. Lately it is always there.
Also sometimes about 1 in a 50 times when I shift into 1st gear it grinds very badly as if I am not depressing the clutch all the way. I don't know if this transmission related or not but a friend says it may be something with my clutch.
Finally it seems to release weirdly. When the engine is cold the engine vibratingly jerks violently when it chooses, almost as if it's about to stall but the rpms will be at 2 grand or more, the stick will be flopping back and forth to the motion of the engine. I have an old mazda 626 and when I sat in that car and pressed the pedal my foot went straight to the floor as if the pedal wasn't their. It made me want to throw that Subaru in the garbage and never drive it again. Anyways if anyone has some good pointers to why my clutch is acting so terribly please let me know. I really want to fix it. Thanks
vic2340 is offline   Reply With Quote
Old 09-13-2017, 12:04 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
How many miles on the car?
When (if) was the clutch replaced?
Clutch pedal operates a torque shaft from the pedal attach to sorta behind the gas pedal, may need lube on that but not easy to do.
Could be the ToB fork pivot, not easy to get lube there.
Could be he ToB running on a dry trans input nose, not easy to get lube there either.
Old 09-13-2017, 12:08 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
This thread should really be in AT/MT section, not really NA engine specific.
Old 09-13-2017, 12:10 PM   #4
JohnM10
Member#: 244231
2018 Crosstrek CVT
The throwout bearing can cause squeaking and squealing.
JohnM10 is offline   Reply With Quote
Old 09-13-2017, 02:39 PM   #5
GEE-OTTO
Member#: 201277
2008 08 QSM 5MT LGT
QSM
Prob the input shaft wasnt greased well enough and the PP/TOB are on the way out. When i had my 2.5i the PP made that noise and the dealer replaced the PP on both of my LGTs that happened at one point. 1 was due to a sever lack of grease the other 160K miles worth of wear. As things wear the TOB and clutch pack have to travel more as the reach the extremes of travel the squeak would happen.
Could also be air in the slave cylinder.
GEE-OTTO is offline   Reply With Quote
Old 09-13-2017, 02:41 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
The clutch fork itself might be worn enough to cause issues. I replaced mine a few years ago when the pivot point was worn through, causing disengagement issues.
Old 09-14-2017, 09:29 AM   #7
vic2340
Member#: 469934
Wow this issue seems very severe and hard to fix. What a crap box, the car has 136k miles on it. Im going to make a video of the noise I think that would be best to describe exactly what's happening. So far though it seems like the engine needs to come out of the car right?
Also I don't have info on if the clutch was replaced but it grabs fine the pedal just feels terrible, I think it's tougher than an 18 wheelers clutch.
Old 09-14-2017, 09:42 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
So, 15yo car with 136K miles on it......it will develop some issues. If it's the stock clutch, take a guess at how many times the clutch was disengaged during its life..........many many times.
Maybe get a helper to see if the noise is near the clutch or under the dash. Have them push/release the clutch while you listen.
Old 09-15-2017, 12:13 AM   #9
vic2340
Member#: 469934
Alright I will do that, I've heard that some of these cars were so poorly built that that the welds that hold the pedals to the fire wall break apart. I guess I need to make sure its not that. Thanks
Old 09-15-2017, 09:22 AM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
That appears to be 08-14.......https://forums.nasioc.com/forums/sho....php?t=2700583
Old 09-17-2017, 12:44 AM   #11
vic2340
Member#: 469934
Thanks that's a relief. I am glad to know that that is not the issue for me.
Old 09-17-2017, 01:59 PM   #12
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Cool
Does NOT mean it's not your issue.
Please......fill in basics of your car and location (state is fine).
Helps us NOT ask repetitive questions about your car.
HmmmmK?....
