Welcome to the North American Subaru Impreza Owners Club Friday February 23, 2018
Old 04-19-2005, 05:36 PM   #26
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Originally Posted by drivrswntd
Well my rears are 17x8.5 et 48 with the 255, i dunno if that helps at all.
Of course that help
I was just pointing out 17x9 +53 won't fit in the rear with the stock strut, I hope I didn't sound too mean
JDM addict is offline   Reply With Quote
Old 04-19-2005, 06:12 PM   #27
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
yup, no offence taking. It will fit with coils from what i have seen in those hyper revs. Heck there is even a car running 17x9.5 front and 17x9 rear, not sure on wheel specs though.
drivrswntd is offline   Reply With Quote
Old 04-19-2005, 06:20 PM   #28
Wrekaro
Member#: 80972
2002 Impreza WRX
So the consensus is if I run a 17x9 in the back with a 44/43 ET I will likely rub on the fender.
Wrekaro is offline   Reply With Quote
Old 04-19-2005, 06:29 PM   #29
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Thanks
I used to think that way, if I see a car with a certain set of wheels on Hyper Revs, it must fit on my stock car...... Then I go over to the Tokyo Auto Salon to check out the actual car in person, well guess what, some of those cars with crazy wide wheel and super low offset have custom hub assembly, custom suspension arms, custom lateral links, custom half shaft, custom coilover with modified strut mounting point, hollow out wheel well.......etc, you know what I mean? Some wheels that fit on those cars would never fit on a stockish car
Old 04-19-2005, 06:36 PM   #30
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
it would fit, but your fender lip have to be rolled flat with -2 degrees of camber, tire width is another critical measurement here, 255 should be fine, but remember different tire have different width, a 255 Bridgestone can be much wider then a 255 Toyo. Another thing is the ride height and suspension stiffness, if the ride height is high and the suspension is stiff, you can put 345 on and it won't rub, vice versa.......
Simply put, 17x9 +43 is very very aggressive, so every mm count.......
Good luck and have fun. These kind of things are all trial and error, every car is different because of the different set up.
Old 04-20-2005, 01:51 AM   #31
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Where is everyone finding 17x9s in the 5x100s? Or are they all custom wheels?
Originally Posted by JDM addict
the car just can't turn a whole lot
It may not count as a street car but why wouldnt it turn a whole lot?
Another note on that car is the front and rear fenders are both cut slightly, and the tires are currently 285s, though he could obviously go as wide as he wants now.
afpdl is offline   Reply With Quote
Old 04-20-2005, 01:55 AM   #32
Wrekaro
Member#: 80972
2002 Impreza WRX
Mine will be custom. There are a lot of euro wheel manufactuers who make 5x100 17x9" wheels but the offsets are in the 35-20 range.
Old 04-20-2005, 01:57 AM   #33
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
Dang, I was hoping someone found some off the shelf 17x9s.
Old 04-20-2005, 02:06 AM   #34
Wrekaro
Member#: 80972
2002 Impreza WRX
Custom forged can be had in the 1800 range. Depending how you look at it thats either really cheap or really expensive.
Old 04-20-2005, 03:26 AM   #35
Kontradictions
Member#: 56946
2004 Subaru WRX
Two Tone Grey
one of a few places i found that would make a custom sized 3-piece wheel and that was HRE. Expensive, but well worth the quality and style...
Kontradictions is offline   Reply With Quote
Old 04-20-2005, 03:36 AM   #36
Subaruist
Member#: 14875
Volk CE28 is available is 17x9 for 5x100 pattern. For the rear, you'll most definitely need to roll and flatten your fenders, the front will be OK.
Subaruist is offline   Reply With Quote
Old 04-20-2005, 09:56 AM   #37
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
Only 17x9 wheels in 5x100 in good offsets i know of, are enkei tarmac, volk ce28, and racing hart cp035
Old 04-20-2005, 12:07 PM   #38
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
A few have mention already, Volks CE28 comes in 5x100, 17x9, +43mm....... combine with Enkei Tarmac and Racing Hart cp035, that are enough choices I would say...
Old 04-20-2005, 12:11 PM   #39
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
They are available, see above posts.
I was saying if it is wide like 335, 345...... the wheel well is not big enough for the wheel to turn.
Old 04-21-2005, 12:05 PM   #40
Midnight_Gold
Member#: 37599
Comm ando Brigade..
Bring it isshes!
tires that stick outside of the fender with 1000 lbs springs suspension that don't travel at all don't count in my book. With those kind of set up, the width is limitless, the car just can't turn a whole lot
You would be amazed just how well a car can turn with a setup like that. I have done a little testing on my 17x11 CCW's with 315 V710's (Joel's car - in the pic - is on 17x10.5's and 305's), and I have had no problem getting rotation.
Now, I don't know that you will DEFINITELY have rubbing issues. I had 17x9 5zigens on the STi when the suspension was still stock and had little to no rubbing even before I modified the fenders. There was slight rubbing on hard cornering, but nothing that a little stiffer suspension couldn't fix.
I'm just looking forward to getting my current daily drivers back on the car - 18x9 OZ Superleggera's with 265 MX's.. - those did require the fender modification.
~ Miranda
Midnight_Gold is offline   Reply With Quote
Old 04-21-2005, 02:10 PM   #41
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
I wasn't referring to rotation, I was talking about the wheel not being able to turn all the way to make U-turn. I was thinking of daily driveability, not race track performance I am sure the car turn great on the track with 315
The ride height on the stock suspension is so high, I am not surprise. The tire is the main factor too, you can squeeze some 225s on the 9' and it would never rub.
~ Miranda
I like your style, wider is better I am currently on 18x8.5 with 255/35, going to 265/35 next, there are still planty of room left with the 255, I don't think 275 would clear the fender though, also 275/35 is too tall and 275/30 is too short, so I guess 265/35 is the widest I can go on this car
I would love to see a pic of your 18x9 OZ Superleggera's with 265 MX's on your car, it would be great if you can post a pic
Old 04-21-2005, 02:21 PM   #42
Midnight_Gold
Member#: 37599
Comm ando Brigade..
Bring it isshes!
I will post as soon as they're done being painted.
*Edit* BTW - When I had the 17x9's on, full lock turning wasn't a problem. With the 11 inch wheels with 315's, it's only barely a problem. I just had to push the bumper out with a support rod.
~ Miranda
Old 04-21-2005, 02:38 PM   #43
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
Thanks, I am looking forward to it! I haven't seen pics of a "street/daily driver" STi with 265s on yet I will post pics of my set up once I get the 265s on, 255s are too narrow to show off now
~ Miranda
I can't even imagine how good the car would stick with 315
Old 04-21-2005, 02:59 PM   #44
Midnight_Gold
Member#: 37599
Comm ando Brigade..
Bring it isshes!
It's just absolutely, stupidly retarded.
Old 04-21-2005, 03:31 PM   #45
JDM addict
Member#: 42976
04' Subie
Econobox Rocket
I bet
Old 04-24-2005, 02:20 AM   #46
AUTOwrXER
Member#: 5817
2005 STi
Actually I can turn lock-to-lock without any issues. Regardless, the configuration is not for daily driving. The fenders are modified so that the tires move underneath them rather than inside them. The tires are 285/30/18 on 18x10.5" wheels. Just wanted to set the facts straight.
AUTOwrXER is offline   Reply With Quote
Old 04-24-2005, 02:49 AM   #47
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
OMGHi2U
man i want to go wide (well sort of wide) , but i want to keep my drop . think i can fit some like 17x8.5's /+45 & 235/40in here? i had to modify the fender well a little with this, but no rubbing anymore. maybe if i find the right rims, raising the car won't be so bad.i have somethign good in mind :
and no, i never scrape
vtecTHIS is offline   Reply With Quote
Old 04-24-2005, 07:14 AM   #48
localsdspec
Member#: 23369
GD impreza
yes, but will the 17x9 i think its in a +43 offset, fit over the brembo's?
localsdspec is offline   Reply With Quote
Old 04-24-2005, 01:20 PM   #49
Imprezzive STi
Member#: 68706
2004 STi
of course it will... there 9 inches deep!
Imprezzive STi is offline   Reply With Quote
Old 04-24-2005, 06:53 PM   #50
STIgeorge
Member#: 22040
2016 VW Golf R
Rent-a-car White
Its not the depth that'll get ya, its the spoke design. If the spokes bulge outward, you'll be fine, if they are flat one might have a problem.
-George
STIgeorge is offline   Reply With Quote
FS:NY OEM Impreza WAGON suspension and hubs--All 4 corners singincanary Suspension/Brakes/Handling 10 03-12-2008 12:57 PM
stock STI exhaust; will it fit on ALL wrxs? oilybirdy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-02-2006 10:47 PM
Will 17x9 ET48 fit on all 4 corners?? Wrekaro Tire & Wheel 7 04-20-2005 05:42 PM
Pictures! sti v6 suspension for GC8: all 4 corners complete supermoose Private 'For Sale' Classifieds 1 11-18-2004 06:53 PM
Will a 17x9 wheels fit on the WRX? Patrick [Buffalo] Brakes, Steering & Suspension 5 10-29-2001 09:59 AM
