04-17-2003, 10:06 AM | #1 |
Member#: 4419
Vehicle:2002 S2K - 2013 ISP i don't have a wrx |
helping a friend, question on 92 legacy trans. fluid fill location
the car is supposedly a 1992 legacy, fwd, automatic. a friend of mine helped somone out by putting transmission fluid in the car for them. now they claim there is a serious problem with the car and my friend is to blame, so he called me.
i'm not knowledgeable on old legacies, so i need your help. My friend says he poured the fluid into a location similar to where the filler is on my wrx (passenger side, near the firewall). Sounds correct to me. The owner is claiming he put fluid into a "differential fluid valve" instead of the transmission, and now the "engine is shaking" I waved the BS flag, and told my friend not to worry, he wasnt responsible for anything. The owner of the car bought the trans fluid, and my friend only put 3/4 of a bottle in it. What I like best is the owner of the car cant even figure out where to put transmission fluid in the car, but they can correctly diagnose a problem with it. Any help, re-assurance is greatly appreciated. Mark |
04-17-2003, 10:43 AM | #2 |
Member#: 4083
Vehicle:2018 OB 3.6R Limited magentite gray |
the ATF fill tube is on the right side of engine - with a yellow handle.
yep, your friend put ATF in the diff filler tube. |
04-17-2003, 12:05 PM | #3 |
Member#: 4419
by right side do you mean passenger side? or, if your standing in front of the car, it would be on your right? He said the handle was a round loop.
I didnt think there was a seperate filler for differential fluid. Do you think 3/4 of a bottle of atf would do any damage? mark |
04-17-2003, 12:37 PM | #4 |
Member#: 4083
ATF is on driver side.
it too has a yellow loop handle. yes, drain the front diff - you need a 21mm socket and roughly 1.7 qts of 80w-90 gear lube. use a transmission funnel! |
04-18-2003, 03:32 PM | #5 |
Member#: 15543
Vehicle:555 Having a Subaru shop means too many cars |
04-19-2003, 02:06 AM | #6 |
Member#: 4419
thanks everyone for the replies, and thanks ciper for the link.
i have informed my friend he (or better yet someone else) should drain the front diff fluid and fill it with the correct oil. i have also informed him to always check the instructions on any car before adding any fluids to it, and to never work on a car in the dark. thanks again mark |
Similar Threads | ||||
4EAT trans fluid fill location? | Mobius118 | Newbies & FAQs | 3 | 06-01-2009 11:58 AM |
CEL questions about 92 Legacy. | Dealer Xing | Legacy Forum | 8 | 01-22-2004 10:24 PM |
0-60MPH time on 92 Legacy turbo!! | Ben | Legacy Forum | 1 | 04-02-2001 07:20 PM |
0-60mph time on 92 Legacy turbo!!! | Ben | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 04-02-2001 05:55 PM |
G-tech Pro Result on 92 Legacy Turbo!! | Ben | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 04-02-2001 09:31 AM |
