Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 04-29-2005, 02:56 PM   #1
cnsmec
Member#: 80377
Default Torque Bind - How big a problem?
Thanks to input from this forum, I've figured out that my 97 Legacy Outback with 110K is suffering from torque bind. How serious is this problem? How quickly does it need to be fixed? What damage will it do if I continue to drive it with this problem?
Also, anyone know a shop in So. California (Orange County) that you'd recommend to fix the problem?
Thanks in advance.
cnsmec
cnsmec is offline   Reply With Quote
Old 04-30-2005, 09:32 PM   #2
bobsrex
Member#: 42872
MY02 Impreza WRX
whats torque bind?
bobsrex is offline   Reply With Quote
Old 05-03-2005, 05:07 PM   #3
cnsmec
Member#: 80377
There's an article on legacycentral org site in the library. It does a much better job than I could.
Old 05-03-2005, 05:36 PM   #4
NRTmotorsports
Member#: 16517
'13 BRZ
do you feel a binding sensation on tight cornering? If so sounds like the transfer clutches in the tranny are binding up, very common on high mileage cars, I've changed quite a few at work.
NRTmotorsports is offline   Reply With Quote
Old 05-05-2005, 04:56 PM   #5
cnsmec
Member#: 80377
Exactly. It's generally limited to low-speed tight turns, like turning into a parking space.
How quickly does this need to be fixed and what does the fix entail?
Old 05-06-2005, 06:40 PM   #6
NRTmotorsports
Member#: 16517
'13 BRZ
yeah it sounds like the tranfer clucthes are going bad. The repair consists of replacing a set of clutches that in the the tail shaft of the tranny. Its not the easiest to do, but give your local dealer a call and tell them your problem and get a quote. It certainly isn't gonna get better just worse. How long has it been doing it? If i were you i would look into repairing the problem, not a MAJOR problem but i would just let it go. good luck
Old 05-07-2005, 11:08 AM   #7
avk
Member#: 17252
'06 WX8
59E
One TSB says the first thing to try is to replace AT fluid and at the same time add friction modifier, which I believe is specified as GM limited-slip additive. I don't remember the specifics, but there has to be a way to find out.
avk is offline   Reply With Quote
Cost to fix the torque bind problem on a 98 GT MaddMax Legacy Forum 18 04-08-2011 02:22 AM
How do I fix torque bind? kirbykirb Legacy Forum 3 07-23-2008 11:32 PM
Torque Bind - How to diagnose and fix the problem. w chapman Normally Aspirated Powertrain 3 10-15-2005 02:47 PM
Torque Bind - How to diagnose and fix the problem. w chapman Normally Aspirated Powertrain 0 10-10-2005 11:18 AM
Is this torque bind? BJamerican Transmission (AT/MT) & Driveline 4 05-02-2002 01:03 AM
