Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 05-02-2002, 01:27 PM   #1
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
Default A/C Compressor Shutoff
Anyone know what can be done to keep the a/c compressor on full time?
It seems that the thing goes on and off intermittantly.
Big_Hitter is offline   Reply With Quote
Old 05-02-2002, 01:32 PM   #2
Aprilia Jon
Member#: 13394
2001 GC8 Coupe
This is so that it does not freeze your coils in the air exchanger in your car. Trust me, it will not work well at all to keep the compressor on all the time, in fact it would break something for sure. It is not a conspiracy to keep you sweating, I promise.
Jon
Aprilia Jon is offline   Reply With Quote
Old 05-02-2002, 01:37 PM   #3
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
I think he's talking about the automatic compressor cut-out at full throttle. I'm sure there's a way to disable the feature, but I don't know what it is.
bump...
Prairie Dawg is offline   Reply With Quote
Old 05-02-2002, 01:42 PM   #4
Big_Hitter
Member#: 10831
1995 Firehawk #456
2009 FXT VF52/E85
It is the air conditioning compressor.
If it is normal for one to shut off, I've only noticed it happening in this vehicle.
Old 05-02-2002, 02:10 PM   #5
Prairie Dawg
Member#: 16598
'09 Civic Si
Redline Orange
It's normal on the WRX. It's designed that way for performance reasons. It's also a feature on some other cars...mostly those with small displacement engines that would need a 2-mile stretch of open road to pass someone, otherwise.
Old 05-02-2002, 02:49 PM   #6
LoriAngel
Guest
Member#:
it's about 3.5 miles of open road with the air completely shut off in a Taurus. (if your lucky)
Old 05-02-2002, 03:20 PM   #7
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
it takes me a few hundred feet in the RS...with the air con ON probably about 1 mile... damn underdrive pulleys
ATX25RS is offline   Reply With Quote
Old 05-02-2002, 04:34 PM   #8
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The compressor cycles normally.....it is not because of performance reasons....it's just how it works. The pressure will build-up.....compressor will cycle off....when pressure decreases it will kick back on.
Usually if you have the fan on 3 or 4, it will cycle less or not cycle at all.
I believe 134a systems cycle alot more then R12 systems do.
The A/C system is designed to disengage the A/C compressor if throttle is at WOT. This is by design, performance, and safety....
Josh
Legacy777 is offline   Reply With Quote
Old 05-02-2002, 10:15 PM   #9
Aprilia Jon
Member#: 13394
2001 GC8 Coupe
Josh
That would be nice, does anyone know if it is true on the '01 RS? I guess I could just listen, but I am doing other things at WFO.
Jon
Old 05-02-2002, 10:27 PM   #10
MooBob42
Member#: 14644
2002 WRX Sport Wagon
WR Blue
Is there something different about the way the WRX compressor works versus, say, the one in the '99 Civic I used to have? I never noticed that its air conditioner cut out.
MooBob42 is offline   Reply With Quote
Old 05-03-2002, 09:22 AM   #11
Legacy777
Member#: 4800
It's the same on all subies. It's been that way since the introduction of the Legacy.
Start your car, turn on the A/C, open the hood, rev the engine at the throttle body, if you open the throttle all the way you will hear, and see the A/C clutch dissengaging.
MooBob.....is your A/C completely shutting off.....or are you just talking about the A/C clutch dissengaging?
Josh
Old 05-04-2002, 01:39 AM   #12
MooBob42
Member#: 14644
WR Blue
Err, I'm not sure. It's that issue where the A/C feels like it's working fine, but then slowly cycles to just vented air, then back to A/C, repeat, wash, rinse. I haven't had a chance to look under the hood.
WTB: 04 STi A/C Compressor TXSubieDood Private 'Wanted' Classifieds 4 06-06-2010 10:54 AM
'03 wrx - a/c compressor shutoff by...? defiancecp Service & Maintenance 1 07-02-2008 05:58 PM
ABS shutoff thing @ under say 30mph? Dakken Brakes, Steering & Suspension 6 01-21-2003 08:43 PM
Driving light shutoff? skullguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-02-2002 11:24 PM
