Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 04-22-2004, 02:27 PM   #1
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Default Cost to fix the torque bind problem on a 98 GT
For the past 1.5 years, my wife's 98 Legacy GT wagon has exhibited the infamous "torque bind" problem. It's never gotten worse. When we bought the car used from Subaru it had this problem and I demanded they fix it before I bought the car. They fixed it, but a year later it was back. I've measured the tire diameters and they're perfect. When I put the FWD fuse in, the problem disappears so it's definitely the torque bind problem. The only time the problem appears is when the car is making tight slow speed turns. The car feels a little jerky even though the throttle input is steady.
Has anyone gotten this problem fixed at Subaru and how much does it cost? My wife doesn't care, but it annoys me when I drive the car. Over 2.5 years of ownership, this will be the first item we have to fix on this car.
BTW, are Legacy GTs normally fairly rough riding cars with a good bit of road noise? The car soaks up big bumps quite nicely, but overall the road noise and general "graininess" is apparant during most driving. In the warmer months the car rides a bit better because suspension/tires loosen up a bit. I'm just wondering if this is normal or if the tires are the problem.
Dave
MaddMax is offline   Reply With Quote
Old 04-22-2004, 03:05 PM   #2
aross
Member#: 831
03 Sonic YellowWRX
03 BH Titanium
My dealer adds a can of something everytime mine gets bad - cost is under $20 and it lasts about 8 months on my 91.
I think it is a friction additive or something - Subaru specific.
And then he does a bunch of figure 8's in the parking lot.
Oh, and tires are the biggest noise makers in Legacys - well, after the mirrors...
aross is offline   Reply With Quote
Old 04-22-2004, 04:08 PM   #3
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Its a friction modifier additive.
I'v hear that it works great.
AFBeefcake is offline   Reply With Quote
Old 12-19-2010, 03:31 PM   #4
GuamSTI
Member#: 210071
04 STI
Any more information of what this friction modifier is?
GuamSTI is offline   Reply With Quote
Old 12-19-2010, 06:03 PM   #5
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
I *think* I recall Huffer had a similar problem and he fixed it by using a product called "Lube Gard". I think it took a few hundred miles of driving before the problem was "fixed". I am not sure if it was a temporary fix or a permanent one though.
Here is a link to the product being sold on Amazon :
http://www.amazon.com/Lubegard-Automatic-Transmission-Protectant-Perfomance/dp/B000F2JZ68
Just to reiterate this product can be used for fixing torque bind on AWD Subarus with Automatic transmissions. Its not for folks with manual transmissions.
Jonathan is offline   Reply With Quote
Old 12-19-2010, 07:12 PM   #6
jamal
Member#: 71875
the viscous coupling in the center diff is sealed, and is likely the cause of the binding. Adding something to the transmission isn't going to help anything. swapping the diff takes a couple hours and most and doesn't require the transmission to be removed. You can get a used one in good working condition for about $150.
edit- this applies to 5-speeds.
jamal is offline   Reply With Quote
Old 12-19-2010, 08:51 PM   #7
[email protected]
Member#: 261585
1997 95 Legacy EJ20R
Red
Dave
my 97 GT has tons of road noise
John@TA is offline   Reply With Quote
Old 12-19-2010, 10:38 PM   #8
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
Mopar LSD additive is what my mechanic (who worked in a dealership for 8 years) recommended
bangedlegacywagon97 is offline   Reply With Quote
Old 12-19-2010, 11:09 PM   #9
GuamSTI
Member#: 210071
04 STI
What you mean is that I would add this to the fluid already in my rear diff?
Old 12-20-2010, 03:21 PM   #10
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Amazon.com: Lubegard - Automatic Transmission Flush & Platinum ATF Protectant Perfomance Pack (98010): Automotive
Yup, thats it, and it ended up being a permanent fix on all Subbies I've used it on. 2 of the 3 of them are still cruising along without any issues. The 3rd I actually parted out and it went to the junkyard. But it never had torque bind again for the 30k I owned it.
Huffer is offline   Reply With Quote
Old 12-20-2010, 03:22 PM   #11
Huffer
Member#: 36735
99 GF8 Impreza 2.0
It's not the rear diff that's the problem. It's the trans.
Old 01-24-2011, 12:57 AM   #12
GuamSTI
Member#: 210071
04 STI
The kit says flush and additive, did you flush your transmission? If I cannot find lubegard on Guam can I use sea Foam?
Old 01-24-2011, 04:21 PM   #13
that one legacy
Member#: 103665
Seafoam isn't an additive, it's a carbon dissolver/cleaner. It's used to clean carbon deposits and oil sludge. If you put that in your tranny and leave it in there, it'll eventually break down all your gear oil! Just imagine what that would do to the internal components!
that one legacy is offline   Reply With Quote
Old 01-24-2011, 04:23 PM   #14
that one legacy
Member#: 103665
And just for reference, I know of a guy who put seafoam in his engine oil and left it in there (he was trying to clean out the oil sludge in his motor). About a month or two later, he was forced to shop for a new motor, if you take my meaning.
Old 01-26-2011, 12:58 AM   #15
GuamSTI
Member#: 210071
04 STI
Thanks I can't believe it lubegard is special order
Old 02-24-2011, 05:58 PM   #16
GuamSTI
Member#: 210071
04 STI
I got most of everything fixed on the Legacy except for the torque bind. I am still waiting on the Lubegard I ordered.
Old 04-05-2011, 08:00 PM   #17
GuamSTI
Member#: 210071
04 STI
Could not find dexron II so I bought dexron III and added a bottle of Lube Guard friction modifier. I just drained and did not replace the filter added about 3 qts + lube guard. Drove it around the block and the bind is gone it does not make that sound anymore maybe after a few miles on it it will be completely gone.
Old 04-05-2011, 11:24 PM   #18
Huffer
Member#: 36735
99 GF8 Impreza 2.0
And there you go.
Check back in with us in about 100 miles, but I'm confident that you're number 16 that I've suggested LubeGard to that has fixed the problem.
Old 04-08-2011, 02:22 AM   #19
GuamSTI
Member#: 210071
04 STI
And there you go.
It is okay I just noticed that on u-turns it feels that it is still binding. I guess this is just the way it is. I have driven about 15 miles so far.
Help give me an idea on labor cost to fix diff leak? DNut New England Impreza Club Forum -- NESIC 0 02-07-2008 11:04 PM
How much will it cost to fix light? Dreamer Warranty Issues & SOA Problems 5 01-25-2005 12:16 PM
2nd gear shattered - how much should it cost to fix? Mr.Freeze Transmission (AT/MT) & Driveline 2 06-26-2003 12:12 AM
Cost to fix Blown 2nd Gear jdsimpreza Transmission (AT/MT) & Driveline 2 05-13-2003 10:09 PM
How much would it cost to fix this? z31 Service & Maintenance 2 02-20-2002 02:49 AM
