Tire & Wheel Forum sponsored by The Tire Rack |
08-23-2014, 04:09 PM | #4176 | |
Member#: 260128
Vehicle:2019 WRX Limited Lapis Blue Pearl |
Sent from my GT-N5110 using NASIOC mobile app
08-24-2014, 09:44 PM | #4177 |
Member#: 128259
Vehicle:2013 Rex darkest of the grey |
the wheel fitment thread: keep it drama free
18x9 off 35 with 265/35 on a 13 wrx stock height? Im on my phone and cant really find a thread with this size. Will they fit without a roll?
08-25-2014, 12:01 PM | #4178 |
Member#: 385806
14 WRX
Stock Suspension Stock Wheel Setup could you help me find the correct wheel size? I would like RPF1's with a little wider stance at stock ride height and no tire rubbing or issues. just a proper fitting wheel. no spacers |
08-25-2014, 01:17 PM | #4179 |
Member#: 373295
08-26-2014, 06:33 PM | #4180 |
Member#: 396739
Will these wheels fit on a 2015 wrx ?
Hi, I'm new to the forum, but not to WRXs. Currently have a 2010, and ordered a 2015. The delivery date is around November so I have to make sure I have snow tires ready.
I know the 2010 wheels won't fit, but I have some from a Mitsubishi Spyder. They are 17 diameter, 7" wide, about 5 3/4" offset (146 mm ?) with I believe the correct bolt pattern. Are these ok for snows ? It doesn't seem like tire rack has steels for the 2015 WRX yet. thanks in advance Bruce |
08-27-2014, 12:54 PM | #4181 | |
Member#: 287109
SCIC
Vehicle:2008 STI SSM |
08-27-2014, 01:14 PM | #4182 |
Member#: 237565
Vehicle:I haz 06 WRB Wagon |
That's probably backspacing. I don't feel like doing the math, but it should probably be pretty close.
08-27-2014, 10:39 PM | #4183 | |
Member#: 46403
SCIC
Vehicle:2006 Hawkeye Wagon SGM |
anybody know what lip kit he is running the the sides and rear? |
08-27-2014, 11:10 PM | #4184 |
Member#: 286408
Vehicle:WFC #952 Function:error! |
08-28-2014, 07:20 PM | #4185 | |
Member#: 97135
NWIC
sideskirts required some modification as they weren't designed for the wagon (06-07 wagons had the weird factory skirt different than all the other years sedan/wagon). |
08-29-2014, 10:05 AM | #4186 |
Member#: 400262
Hey guys im looking to buy some Varrstoen Es6 18x9.5 offset35 for my Wrx 07 sedan...and running 215 tires... I have the rear fender rolled and coil overs.. Is 35 Offset to low for my car would that cause wheel bearing to fail ? And i cant find anywhere if they clear brembo brakes...! thanks
08-29-2014, 01:00 PM | #4187 |
Member#: 363697
Vehicle:2009 WRX OBP |
Sup guys,
looking into buying THESE (http://newyork.craigslist.org/wch/pts/4640294252.html) rims. 18x9.5 38 offset. Not sure of tire profile, but it seems like a 225/235 maybe. I'm dropped on ISC coils. Would I be able to fit these on a 2009 wrx? |
08-29-2014, 11:35 PM | #4188 | |
Member#: 288727
Those look like a 225/35 tire. They will fit, but you'll need a slight pull in the back and I'd roll the front fenders. |
08-30-2014, 12:10 AM | #4189 | |
Member#: 344540
Vehicle:2015 Mustang 5.0 Guard Metallic |
You need a +22 to clear Brembos. I run -3.5 camber in the rear with a mild pull to fit them. I'm also on a 225/40 tire tho. |
08-31-2014, 06:02 PM | #4190 |
Member#: 292520
Vehicle:13 WRX STI limited WRB |
will a 18x9 +43 works xd9 on stock 245 tires cause any fitment issues on a 2013 sti sedan?
09-03-2014, 02:29 PM | #4191 |
Member#: 349610
VIC
Vehicle:06 STI Blue |
year: 2006
model: STI wheel model: XXR 527 wheel size/offset: 18 X 8.75 +33 tire brand/model: BFG GFORCE KDW tire size: 255/35-18 suspension: BC RACING BR SERIES alignment: -2.5 CAMBER FRNT AND RR fender mods: ROLLED FRONTS, ROLL,PULL,CUT REARS spacers: 8MM no rubbing with spacers installed |
09-03-2014, 04:44 PM | #4192 |
Member#: 237565
09-03-2014, 09:42 PM | #4193 |
Member#: 400711
Looking to see if anyone's ran a setup close to this and about how much camber and fender work was needed.
year: 2013 model: WRX wheel model: CCW wheel size/offset: 18 X 10 +32 tire brand/model: not sure tire size: 225/40 - 245/35? Not sure. suspension: Stance super sports alignment: wouldn't want to run more then -3 fender mods: rolled fenders spacers: No |
09-04-2014, 03:21 PM | #4194 |
Member#: 328122
Vehicle:2011 STI Black |
year:2013
model:wrx hatch wheel model:drag dr-31 wheel size/offset:18x9 38et or 18x8 48et suspension:stock fender mods:would rather not roll but will if needed camber adjustment:no spacers:no What would be the best tire sizes for each wheel to fit with a complete stock setup? Looking to get rid of wheel gap and have a more aggressive look without making multiple modifications. |
09-04-2014, 04:00 PM | #4195 |
Member#: 97135
NWIC
either one of those will fit fine.
there is no such thing as reducing wheel gap without lowering the car. |
09-04-2014, 04:28 PM | #4196 |
Member#: 328122
09-07-2014, 04:32 PM | #4197 |
Member#: 399891
VIC
Vehicle:2012 WRX Silver |
I have a 2012 wrx, looking into getting a winter set up. Found some nokian hakkapeliittas on steelies locally for $500. The question is would 195/65/r15 work on my car? I've tried searching but can't come up with much or anything definitive.
Thanks in advance. |
09-07-2014, 05:41 PM | #4198 |
Member#: 237565
Probably not going to work. I doubt that 15" steelies would clear your brakes.
09-07-2014, 06:41 PM | #4199 | ||
Member#: 97135
NWIC
Both of those tires are too wide for an 8" wheel - in that case I'd consider a 245/35 or 235/40. steelies most likely wont clear your brakes. only select 15" wheels clear the wrx brakes, and they are all competition rally wheels. |
09-07-2014, 10:14 PM | #4200 |
Member#: 395987
TXIC
Vehicle:2008 Impreza 2.5i Dark metallic grey |
year:2008
model:2.5i hatch wheel looking at rota grids wheel size/offset:17 or 18, cant decide, any downfalls or benefits of one or the other?/and have no idea for offset (im new to this) what would fill my fenders up? suspension: lowered 2 inches on coilovers fender mods: nope camber adjustment:no spacers:no |
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
