11-05-2013, 09:24 AM | #301 |
Member#: 320788
TXIC
Vehicle:2014 WRX Hatch Black |
Did you see the cam timing when Mike had the pulley off? I'll buy a breaker bar and socket tonight and check it myself.
11-05-2013, 12:10 PM | #302 | |
Member#: 33863
TXIC
Vehicle:2001 rs2.5 silver/champaign |
cam timing will not throw off compression numbers, that is either bent valves or worse, broken ringland/bad rings that is causing low compression. there is no work around for it. good luck with the car. |
11-05-2013, 12:24 PM | #303 |
Member#: 355962
Vehicle:2015 STI World Rally Blue |
Got rid of my 05 STI and now driving a new 2014 BRZ
11-05-2013, 03:47 PM | #304 |
Member#: 327664
TXIC
Vehicle:2008 Impreza OBS Obsidian Black |
I washed, clay bar'd, and waxed my car this weekend... Of course it's gonna rain all week...
11-05-2013, 05:00 PM | #305 |
Member#: 320788
TXIC
Oscar, the car is modified. I didn't expect them to accommodate me in any way and they did not. They read the code for free and that's about it. Compression test? $268. Results that look like there's a deeper root cause show up. Investigate further? Crack open the wallet because our tech's time is too valuable to look at cam timing for free. They went from compression out of spec to rebuild required with no intermediate investigating.
Have you seen compression drop on one side like that? The idle has sucked since I first cleared the code which followed what I thought at the time was the sound of a car screeching it's tires. Could have been an idler bearing but I'd think I would at least hear something if a pulley was seized or the belt would have snapped by now. The fact that the check engine light came on the day after we installed a Fluidampr crank pulley makes me think it has to be cam timing related. Car was fine before this. Did we stretch the belt torquing the pulley down? Possible. I'll know when I check the cam timing and if things are off, I can go from there. But to order a new short block solely based on those compression test results seems like buying a used Range Rover, I'd be better off setting my money on fire because the fire would keep me at least warm. And technically speaking, jumped timing could bend valves so incorrect cam timing will impact compression numbers if we have to be anal |
11-05-2013, 09:45 PM | #306 |
Member#: 320788
TXIC
Well there is something up with the AVCS whether it's P0016 and compression related or not. It's only active for the first few minutes then it drops to no more than 3 degrees advance on the drivers side and 1 on the passenger. I've seen youtube videos detailing this as a difficult to diagnose fault on 02-04 STis but that they claimed to fix the fault on later years. I'll get another thread going since this is only tangentially related as I datalogged it tonight so it's technically something I did to my car.
11-06-2013, 09:48 AM | #307 |
Member#: 33863
TXIC
yes i have seen that, when you break a piston ring land you loose compression on a cylinder badly. so i do agree.
i have some compression tools and stuff we can run some tests if you like this weekend? i can help confirm exactly what is happening/ BTW, I'm mike. i'll pm ya my # |
11-07-2013, 06:18 PM | #308 |
Member#: 174883
TXIC
Vehicle:135i 05 CGM WRX 2006 Yamaha R1 |
Dropped off my flywheel off to be resurfaced. Motor and trans going in this weekend.
11-08-2013, 08:00 AM | #309 |
Member#: 287080
11-08-2013, 08:11 AM | #310 |
Member#: 174883
TXIC
Yeah it came in yesterday.
11-08-2013, 08:14 AM | #311 |
Member#: 287080
Nice... I've got time Sunday to help if you're doing it then.. Lmk
11-08-2013, 08:45 AM | #312 |
Member#: 174883
TXIC
Will do! I plan to do it early Saturday morning but probably won't finish it all.
11-08-2013, 01:10 PM | #313 |
Member#: 268190
TXIC
Vehicle:2005 STi |
You finally installing the 6 speed bro?
11-08-2013, 01:17 PM | #314 |
Member#: 174883
TXIC
Yep! It's taken way to long but the time is now! I had to slowly buy the parts I needed at the begging of each month.
11-08-2013, 07:49 PM | #315 |
Member#: 146311
TXIC
Vehicle:Saab '05 HTA68 Built 2.5L E85 6MT > STI :) |
Got a reallllly annoying rattle taken care of. Turned out to the an O2 hole plug in my newly installed Cobb DP that I somehow missed when I looked for the rattle last weekend
Looking forward to tomorrow morning, going to do a coolant swap as well as change out the thermostat to help drain as much as I can. |
11-08-2013, 09:13 PM | #316 |
Member#: 152726
SCIC
Vehicle:The 2003 pwrFAP thing |
I dialed in my my camber last night and had a co-worker straighten out the toe today. |
11-08-2013, 11:03 PM | #317 |
Member#: 152400
TXIC
Vehicle:2010 G37x / RC 51 Black Obsidian |
11-09-2013, 06:22 AM | #318 |
Member#: 268190
TXIC
Vehicle:2005 STi |
Damn since when does everyone have meisters now lol looks great pencils, bcl wing looks crazy.
11-09-2013, 09:51 AM | #319 |
Member#: 152726
SCIC
thanks. and yup, new wheels recently came in.
i had ordered mine in late may. they didn't have anything i want in my specs (curse you 5x100) so they had to make it all. and then they ran out of material to make the wheels so i had to wait for that lol. months later and here i am. lol |
11-09-2013, 12:20 PM | #320 |
Member#: 268190
TXIC
Vehicle:2005 STi |
The wait for works is worth it though, I know you agree lol
But ya your Bugeye looks awesome, I think some 04-05 tails would do good with the same reverse tint you have going on. |
11-10-2013, 05:08 PM | #321 |
Member#: 320788
TXIC
Changed oil and checked cam timing. It is off 1 tooth. Mystery solved.
11-11-2013, 10:44 PM | #322 |
Member#: 268190
TXIC
Vehicle:2005 STi |
Finished slotting my rear camber plates
11-12-2013, 09:30 AM | #323 |
Member#: 302371
TXIC
Vehicle:2007 WRX OBP |
Installed new front rotors. No more horrible shaking from braking on the off ramp!
11-12-2013, 10:24 AM | #324 |
Member#: 33863
TXIC
Friday the car gets taken to my friend's place tpirallying.com for a flywheel, clutch and replacement of rear main seal.
i purchased an chromoly flywheel (12.5lbs) and a stage3 clutch (sprung center 8 puck ceramic disk clutch) should last me for a long time on this car. |
11-12-2013, 11:31 AM | #325 |
Member#: 152726
SCIC
